[ Total Views: 1648 | Total Replies: 34 | Thread Id: 76472 ]
Author: Subject:  Pertronix frustration
MemberTYPE3
Threads: 3
posted on May 25th, 2009 at 06:42 PM
hey mate you get it all sorted?
if not are you sure its all hooked up right? i have a square with 009 and pertronix and from memory there is a red and a black wire from the module and the red goes to positive on coil and the black goes to negative side of coil, the power wire should be going to the positive side of the coil. so 2 red wires going to + on coil and one black wire to - on coil. the power wire that should be goin to + side of coil should have 12v with the ignition on, if not check your engine fuse.
Current: 07' R32 Golf, 06' Passat Wagon V6 4Mo
Former: 68' type3 variant, 83' T3 Bus aircooled 2L, 65' deluxe bug
Membertrickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on May 25th, 2009 at 07:33 PM
Well I bought a petronix and a flame thrower off George at the Nationals for $195. Hope I dont have the problems you were/still are having.
Memberizac
Threads: 39
Theme: UltimaBB Powder
posted on May 25th, 2009 at 08:21 PM
got it running on friday but only with points in... so i think the pertronix module must be faulty coz both coils work with points in.
its running rough at the moment though (static timed to 7.5* BTDC) so i am going to by a strobe timing light and time it properly to 30* advance at about 3500rpm. apparently that is the only way to time a 009 properly
so now im back with my old coil and old points! dont think il get my money back :td: ... the flame thrower coil i was sold was actually a 1.5ohm (which is for drag racing or 6 & 8 cyl cars according to the Pertronix booklet) so little did iknow at the time i should have been sold a 3ohm coil...
anyway thanks for your help guys... even though i am a bit poorer now, at least the square is running! :yes:
Membereraser
Threads: 128
Theme: UltimaBB Pro Powder
posted on May 25th, 2009 at 11:25 PM
I remember importing the flamethrower from the US about 6 years ago, and getting a call from customs to find out what exactly a flame thrower was.
-M
Memberalien8
Threads: 84
posted on May 26th, 2009 at 09:31 AM
Good to hear you got it running mate.
I would try for a replacement module and coil., If you asked them for a coil to go with that module, its totally NOT your fault. Should be a straight forward warranty job if instillation was correct,which by the sounds of it were.
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
