| [ Total Views: 5485 | Total Replies: 60 | Thread Id: 79170 ] |
| Pages: 1 2 3 |
Racermelb
Threads: 9
| posted on November 10th, 2009 at 11:40 AM |
This is the first time i have used the Dynomat, and i have to say i have been impressed, the way in which it reduses drumming in panels is incredible,
as far as use on external surface, so long as you ensure all the edges are firmly in contact with the surface and the surface is clean i cant see a
problem, it may get dirty but thats about the ony down side I can see.
jon
colonel mustard
Threads: 51
| posted on November 10th, 2009 at 05:38 PM |
In my opinion, you would only use dynamat in area's that were going to be covered, > so that they aren't seen, but also, so it wont get dirty and
lift. Ideally you would use something like POR15 to seal everything else as it has a hard finish. As for the engine bay, the chrome covers look great
(for beetles) but just make noise, If you covered it with the original stuff, would most likely be a good option. engine bays, always get dirty.
Loving the progress Jon.
Racermelb
Threads: 9
| posted on November 10th, 2009 at 07:33 PM |
Cheers Colonel
The dynomat in the engine bay will be covered by another product from the same manufacturer which is designed for Engine bays and looks like the
original KG cover that covers the fire wall
Just bought these today for the engine
| Error |
colonel mustard
Threads: 51
| posted on November 10th, 2009 at 09:28 PM |
They loook hot! I've not seen them before, where from??
looks like twin dells or webbers going on there... 1916cc???
Scarab
Threads: 8
| posted on November 11th, 2009 at 06:31 AM |
those covers look great!! this is gonna be one wild ride I think!
Racermelb
Threads: 9
| posted on November 11th, 2009 at 08:18 AM |
Bought them out of the states.
The pic is from the seller, no not 1916cc, more like 2333cc will
be running 44 Kads initially, but might need to upsize to 51 webbers down the track, I think i might have over done it on the cam and comp front but chasing 200 ish hp, still contemplating running the
super charger as well, but gear boxes will be the limiting factor.
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
| posted on November 11th, 2009 at 08:48 AM |
Cam, CR and Heads?
Racermelb
Threads: 9
| posted on November 11th, 2009 at 09:29 AM |
| Quote: | Originally
posted by trickysimon
Cam, CR and Heads?
Cam =PRO COMP 2 = 2027 - 2332cc SUPERIOR POWER BETWEEN MID- TO HIGH-RPM (4500 - 7000) DUAL SPRINGS
20008C C65 .413" .516" .578" 309 274 W-140
CR 10.5:1
Heads
“WEDGE-PORT” 44mm intake x 37.5mm exhaust “SUPER-D” 42mm intake x 37mm exhaust
(dual valve springs & 4140 chromoly retainers)
Large port design for drag racing at high RPM (4,000 - 8,000 RPM) and lift
Swirl-polished with venturi intake and exhaust runners
Special shaped combustion chamber for big power potential
Plus new billet crank, new case, mahle forged pistons,mahle race bearings, Chromoly Lightened Flywheel, blah blah blah
Being built by a guy who builds formula Vee motors for a living.
Should make the KG a little lively
colonel mustard
Threads: 51
| posted on November 11th, 2009 at 09:50 AM |
swirl-polished combustion sounds like richard from vforce.... i may be wrong though.
Racermelb
Threads: 9
| posted on November 11th, 2009 at 10:15 AM |
No all Scat parts from the USA, he may use them as it seams that most of the parts being sold come from there
Mick058
| posted on November 11th, 2009 at 10:33 AM |
excellent work - enjoying the thread
Racermelb
Threads: 9
| posted on November 11th, 2009 at 01:22 PM |
Just waiting for another part to arrive, very essential in light of the engines willingness to Rev
| Error |
kg1962
| posted on November 11th, 2009 at 06:47 PM |
The wheels look awesome. Are they KPZs? Who refurbished them for you?
Racermelb
Threads: 9
| posted on November 11th, 2009 at 06:50 PM |
| Quote: | Originally
posted by kg1962
Yes they are KPZ's
The Chrome was done by Matt at Ferntree gully Platers, the wheels rerolled stripped and rebuilt by Mike from AJAX Wheels
and paint work and masking by myself
empi
A.k.a.: Empstar
Mood: thunderous
| posted on November 12th, 2009 at 09:06 AM |
Car looks nice , good to see Cams old car finally getting done.
Wheels suit (Bit jelous wanted the wheels to do the same to my ghia)
Whats with all the extra holes in the dash?
have to say Dynamat is great stuff just applied some to my type 3 inner decklid made a big difference.
MMMM taco , OG or repro?
"If at first you don't succeed, skydiving is not for you." - Anonymous
Racermelb
Threads: 9
| posted on November 12th, 2009 at 09:18 AM |
Cheers Empi
Hoepfully Cam will drop through and have a look one day soon to have a look, will have to take him for a spin in it when it is done
Not sure what the holes in the dash were for, but will put them to good use for something.
The tacho is OG but has been reconditioned
Racermelb
Threads: 9
| posted on November 27th, 2009 at 12:22 PM |
Just arrived today my 2332cc Race engine, ready to bolt in, just need to get the 36Hp fan shroud painted and the rest of the tin ware painted then in
it goes.
| Error |
| Error |
empi
A.k.a.: Empstar
Mood: thunderous
| posted on November 28th, 2009 at 09:42 AM |
Engine looks nice, u got the whole bad boy bubby thing going on there.
Really want to see the stroked motor with the rocker covers fit under the KG engine bay sides. I had empi alloy covers and Claudes buggies covers
that wouldnt fit my car once lowered.
Racermelb
Threads: 9
| posted on December 1st, 2009 at 05:14 PM |
Couple of update pics, engine being assembled and the tin ware painted and fitted, cant wait to hear it make some noise.
| Error |
| Error |
| Error |
Bizarre
| posted on December 1st, 2009 at 06:21 PM |
Mate LOVE your work........but 2332cc race motor and dual singles??
What sort of carbs are they - PSITs??
Just surprised thay they will feed a BIG motor
Racermelb
Threads: 9
| posted on December 3rd, 2009 at 10:09 AM |
The carbs are jetted up 44's, and I share your opinion as to if they will cope with the capacity of the engine, but they should do ok whilst it is
being run in and sorted, if they dont cut it then I will be looking at an injection set up, but the over riding thing is I dont like the chances of
175's being able to put down the power it will make even with it not making its potential using the 44's.
Racermelb
Threads: 9
| posted on December 7th, 2009 at 09:20 AM |
Nearly ready to be fitted
| Error |
| Error |
colonel mustard
Threads: 51
| posted on December 7th, 2009 at 12:18 PM |
Engine looks hot!
as long as the carbs are jetted tuned right, they should be fine for gettting the car moving. then you can go up when you want it to be more serious.
Racermelb
Threads: 9
| posted on December 14th, 2009 at 01:10 PM |
My pulley set up is ready and being posted, should be here this week this is it
| Error |
Bizarre
| posted on December 14th, 2009 at 01:25 PM |
Cool !
Is that what you are getting 2L Fuchs??
tabney
A.k.a.: Tim Abney
Threads: 4
| posted on January 1st, 2010 at 09:52 AM |
Love that steering wheel! where did you get it?
Racermelb
Threads: 9
| posted on February 15th, 2010 at 01:47 PM |
Well after much absence from the Ghia I finally plucked up corage to do some more, not much, but something.
Trial fitted the seats and bolted the pulleys on the engine.
Have been too busy having fun on the Bike
| Error |
| Error |
| Error |
Bizarre
| posted on February 15th, 2010 at 02:59 PM |
so you keeping your baby??
Its looking schweet!
Racermelb
Threads: 9
| posted on February 15th, 2010 at 03:06 PM |
Yep will see it through to the end
Wannavee
| posted on February 15th, 2010 at 10:26 PM |
Nice one Jon
Glad ya sticking with it.
Mine got inspected last week,all good,just pay the rego and I'm cruisin!
| Pages: 1 2 3 |
