[ Total Views: 3933 | Total Replies: 40 | Thread Id: 80286 ]
Author: Subject:  Circut car Corner Weights
Memberdangerous
Mood: 591
posted on March 23rd, 2010 at 05:36 AM
Some interesting reading here related to Volksies.
Drag racing, but still relevent.(page 11)
http://ultimateaircooled.com/simplemachinesforum/index.php?topic=6102.150
Originally posted by westi
That's mad Alan.
MemberRodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on April 18th, 2010 at 12:26 PM
Dave , thanks for the link . Some of the theories seem good and some sound like they are full of shit . It is always good to look at doing things in a different direction than what I would normally go in , ROD.
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
MemberRodPenrose
Threads: 330
posted on April 20th, 2010 at 07:11 PM
New Engine
Well , after killing another engine due to a lack of lubrication I have rebuilt it again . I disassembled the old 2276cc engine and found a really shitty conrod bearing and the other 3 were pretty well stuffed as well . The conrod was a throw away item and the crank needed to be ground on the mains and rods . I cannot find a major problem with the oiling system , but I did find a few things that I did not like in the pick-up area and the oil pump is now in the bin .
I have now rebuilt the engine with a new 84mm crank and new set of rods . The engine is now 2332cc and the compression has gone from 10.3 to 10.7 . I had a dyno session last Saturday and now the engine output has gone from 121.2 hp to 143.8 hp and the torque has also increased from 223.8 ft/lbs to 263.9 ft/lbs . These are readings are on a chassis dyno and are @ the wheels . Engine hp is now a stout 186 . I still have the 37mm venturies in it and did try the 42mm units and the power was up to 148 and the torque was 270.2. With the larger venturies the max power was @ 5354 rpm and held it to 5929 rpm . The max torque is now @ 5044 rpm . I will be using the smaller venturies as the torque curve is a lot better for what I want to do . I will now have a test day @ Wakefield park next Monday on the public holiday and try to kill this one , ROD.
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on April 20th, 2010 at 07:24 PM
will be in goulburn will try to drop in
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on April 20th, 2010 at 07:28 PM
what size pump now Rod?..........not interested in the ole hellbug theory of less volume and quicker returning to the pick up?
MemberRodPenrose
Threads: 330
posted on April 23rd, 2010 at 09:17 AM
Damo , I was using one of the CB performance in/out oil pump and was supprised to see that it was 34mm wide . I have now gone for a melling steel 29mm pump and a convential full flow deal by returning the oil into the gallery . I now have 80psi of pressure when I first start it , and 140 psi at 7000 rpm . I am now using the ACE syn-x 4 oil . This is a 5-40 full synthetic deal with 6 litres of oil capacity , ROD.
Memberbigrudi
Threads: 118
posted on April 24th, 2010 at 06:18 PM
GEEZE Rod thats a shit load of oil pressure better take some spare oil filters concrete and a broome , ur also not supposed to be using synthetic oil they cant clean it up, why so much pressure ? good luck with it cheers Rudi
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on April 24th, 2010 at 09:01 PM
will be interesting to read this thread on Monday night :D
MemberRodPenrose
Threads: 330
posted on April 29th, 2010 at 03:48 PM
Well , after a long day on Monday the engine is still together . I was too lazy to swap back to the smaller venturies , so I left the larger 42mm units in . The power and torque of the engine is increadible . I am using 4th gear all the way , and only use 3rd to help get into 3 of the corners . I am doing 142km/h on the 7000 limiter before the start line on the straight . I turned probably 40 + laps and would make a change to the car on every session . I must say a big thanks to Greg Mackie for his help and knowledge and am now looking forward to the nationals in 3 weeks time . I did not get any lap times , but I have actually passed a car for the first time . I actually passed a car on almost every lap and feel more confident in the car . It still amazes me on how hard you can drive a car around a corner and it will do what you want it to . The oil pressure seems to be good at around 10-12 psi per 1000 rpm's when hot and after a 12-13 lap stint the temps are all good . I will now give the car another wheel alignment and put it back on the corner scales and make any necessary adjustments . I have gone from tyre temps in the 75 degree range to 130 now , and the brakes are now opperating in the 340 degree range instead of the 200 degree last time , ROD .
Memberhellbugged
A.k.a.: Daimo Pell
posted on April 29th, 2010 at 04:24 PM
nice
Taller 4th on the cards now?...i cant remember how far from the braking area the start line is?
MemberPAZZAN
Threads: 113
posted on April 29th, 2010 at 05:16 PM
I was hitting the limiter 7500 in third just at the end of the straight at the first kink not sure what kph that was..???
[ Queries: 40 ] [ PHP: 15.9% - SQL: 84.1% ]
