[ Total Views: 1864 | Total Replies: 37 | Thread Id: 8176 ]
Author: Subject: Oran Park
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on August 1st, 2003 at 09:50 AM
Yawn :D
MemberBrad
Threads: 332
Mood: Manx Buggy Building
posted on August 1st, 2003 at 11:10 AM
well
You two are funny .....:D:D:sandrine
Brad
Meyers Manx Australia
MemberCraig Torrens
Threads: 347
posted on August 1st, 2003 at 12:28 PM
:D:D
Head temp quoted is measured in Deg Fahrenheit, so 300= 148 deg C
The VDO guage starts at 100deg F (37deg C)and goes to 600deg F (315deg C) so at 300deg F this is an average temp.Vw powered aircraft can see 450Deg F Head temps (max) under load, and this is acceptable. There is also some figures on ANDY's thread where his Kombi reached 180deg C or 350 Deg F.
:thumb
What Compression is the Kombi ?
Your right about the heads, I would use the new style 044's , they are much better, but I purchased mine in 94' and they were the best then! They still seem to work OK, well the times certainly show that !:kiss
Memberjakriz
Threads: 46
Mood: 2 headed
posted on August 1st, 2003 at 04:31 PM
My apologies for the misunderstanding on the temps, I've got the same deal with my guages. Shouldn't u be on the road the Nambucca by now?
regards
Jak
PS your times are excellent, & so they should be.:thumb
Congratulations to Ben Durie for breaking the hillclimb record at Ringwood in his stroker beetle!
Memberfullnoise
Threads: 103
Mood: Middle of the road.
posted on August 1st, 2003 at 05:28 PM
Stop the bickering.
Don't you realise we've all got a common bond?
We've all run the Pobjoy 37/68 cam in our beetles! Isn't that special?
Just trying to heal the rift.
Anyone want to argue about Rudi's gearbox?
CYA. CT:vader
esratrams
Memberjakriz
Threads: 46
Mood: 2 headed
posted on August 1st, 2003 at 06:48 PM
I don't beleive that u can have a rift with someone that u have never met before, & wouldn't know even if they popped up in your cereal.
It's one thing t be a champion, & a dominating one at that, it's another to be gracefull & an ambassador for your sport.
regards
Jak
Memberjakriz
Threads: 46
Mood: 2 headed
posted on August 1st, 2003 at 06:50 PM
Rudy's gearbox is out of a split window kombi , he even runs the reduction boxes!
How cool is that?
Jak
MemberCraig Torrens
Threads: 347
posted on August 19th, 2003 at 08:56 PM
Originally posted by jakriz
Hang on Craig, 9.5:1 compression, surely there must be some mistake, how do explain the 300degree head temps at Oran Park? or were u just telling fibs? Did u get a spec sheet when u purchased your engine or is it all top secret?
I'm running 9.0:1 compression & I rarely go over 120degrees on the track & 80degrees on the street, I'd check where u have your sender, or it could be those street eliminators, thats why no-one that does track uses them?
Just a thought.
regards
Jak
I'm confused, why is your car now running to over 130deg C, what have you changed for that increase ?
MemberCraig Torrens
Threads: 347
posted on September 2nd, 2006 at 01:13 AM
wow, 3 years since I ran at Oran park, where does the time go!
Memberbugbrained
Threads: 36
Mood: givin up cigs
posted on September 2nd, 2006 at 01:31 AM
are those temps in summer or winter lol
