[ Total Views: 2053 | Total Replies: 34 | Thread Id: 82776 ]
Author: Subject:  Will my glass Shatter?{Help}
MemberRob S
Threads: 7
Theme: UltimaBB Powder
posted on April 20th, 2010 at 09:21 PM
yes jjweb123 it is a toughened screen you have. I have over 20 years experience in the glass industry with more than half that time specialising in toughened safety glass. The colored rainbow you saw through the polarised lens is indeed proof that you have a toughened screen. Toughened glass is up to 5 times stronger than normal annealed glass of the same thickness. Most toughened screens are 5mm thick. As explained earlier toughened glass is produced by heating the glass up to around 800 degrees and cooled rapidly with compressed air, this rapid cooling is what toughens the glass causing surface tension by forcing both surfaces to permanantly push against each other. In most cases toughened glass breaks when the surface is chipped usually by a stone, and the surface tension is released and the glass shatters. In some rare cases the glass can break without any impact to the surface at all, this is called spontanious implosion of toughened glass and it is not known what causes this to happen. If i was considering changing my sreen i would certainly pick Laminated over toughened glass. Laminated screens are designed to obsorb impacts from persons in heavy impact collisions. The vinyl interlayer is desighned to stretch but not break and therefor helps to keep you in the cabin of the car in a heavy impact.
Memberjjwebb123
A.k.a.: Jason
Threads: 63
Mood: Trying to get it puring
posted on April 21st, 2010 at 09:10 AM
will windscreen obrian be able to get me a glass or will i have to get one from a VW Supplier and ask them to put it in.
Thanks:?:
Memberbnicho
A.k.a.: Brett Nicholson
Threads: 55
Mood: Usually Cranky!
posted on April 21st, 2010 at 09:44 AM
O'Briens wil most likely have one for you. Give them a call and ask. :)
Brett Nicholson
Melbourne, Victoria
1974 VW Superbug L - Olive :cool:
1971 Morris Mini Moke - Mopoke
1966 Austin Mini - Audrey
1965 Morris Mini Traveller - Trixie
2007 Land Rover Freelander 2
2009 Nissan Pathfinder
Memberjjwebb123
A.k.a.: Jason
Threads: 63
posted on April 21st, 2010 at 10:00 AM
yeh ok cool.
MemberRob S
Threads: 7
posted on April 21st, 2010 at 10:12 PM
Ob's and most independant windscreen suppliers will be able to help you. Not sure of prices but a couple of hundred should cover it.
[ Queries: 40 ] [ PHP: 13.1% - SQL: 86.9% ]
