[ Total Views: 4066 | Total Replies: 80 | Thread Id: 83203 ]
 Pages:  1  2  3
Author: Subject:  Who owns this Black (blue) Bug?
Membercolonel mustard
Threads: 51
posted on April 22nd, 2010 at 01:57 PM
isn't powered by a subaru ?
didnt sound like it..... but then, its a track car thats gets used.
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on May 13th, 2010 at 11:28 PM
Sides any updates ? track times ? Dyno sheets? Drags times?..........cmon its been a while !!!
MemberSTIDUB
Over it.
Threads: 57
posted on May 14th, 2010 at 12:00 AM
ive seeen it, lil red line goes like... this...
........______
_/
ignore the dots :P
MemberSides
A.k.a.: Dave Sidery
posted on May 14th, 2010 at 10:41 AM
Yeah, I know I know - work unfortunately gets in the way at times.
But I managed to scam a day off to go dyno this week.
http://m9pnqa.blu.livefilestore.com/y1pi1dxwUrEdzvl_q5auHs4ZmL2eIn3fOokmUZcLMFfEt4_bKLieZ4a_x9vdmandc4D83Ht51ve5f6hoM7b4wPcvmpBUulnY_07/Dyno_201
I'm pretty happy - engine is obviously very strong and a massive step up from the old combo. Unfortunately couldn't seem to tune out the stupidly rich area... leading theory is it's being caused by a combination of the big cam and IDF's. We knew this would happen tho - the engine has always been planned for EFI which will let us tune that area spot on. The twin plugs should also help if the theories hold true. Definitely explains the hesitation out of corners if it drops below 4000 !!!
All the same I'm going to line up some different emulsion tubes to see if might help in the interim (currently have F11's... thinking F16's or possibly F9's). Bigger vents or switching to IDA's could also help, but not really prepared to go there when the EFI is getting closer all the time.
Next track outing is Wakefield in a bit over a week... should be a lot of fun !!!
My toys
Memberreub
VWRX is gone...
posted on May 14th, 2010 at 12:55 PM
Nice work dude.
:tu:
It is interesting to see with the very minor differences in our engines the graphs are still pretty much identical.
Reub
MemberCraig Torrens
Threads: 347
posted on May 14th, 2010 at 08:56 PM
Thanks for posting the results Sides........maybe put it up in the dyno sheet section.
The results seem a tad odd for the combination though.......I can understand it having the low power below 4200rpm, but it seems odd that peak power is only at 6000rpm and then slowerly drops. You have a FK87 (drag cam !!) with 1.4's so I would have thought that peak power would have been a lot higher than that, especially with compression that high as well.
Something doesn't seem right, maybe you need to look at getting some head work done to make it breathe better in the top end ??
Good to see youre enjoying it though. :cool:
MemberSides
A.k.a.: Dave Sidery
posted on May 15th, 2010 at 09:30 AM
Yah, no probs Craig.
I know what you mean about the results. Only have 36mm vents in currently, and think that's too restrictive up top.
Heads should be plenty good enough as is I think... CNC Oval Ports to start with, which DB has put some extra work into.
The Weber vent chart I have shows 36mm only good for a bit over 6000rpm... 38mm vents would help, but to have max power at 7000 (which the cam would like) really need a 40mm vent, which means IDA's really. From what I understand the bigger vent could help with the richness down lower also... weakening the signal on the main circuit down there, causing it to run leaner.
Any carb guru's reading that care to jump in ???
My toys
MemberGracey
Threads: 17
Mood: Itchy
posted on May 15th, 2010 at 11:36 AM
I wouldn't put to much faith in that chart, it's really just a guide.
However in saying that it would probably benefit from bigger venturi's or carbs.
What size are the throttle bodies your going to use for the injection?
The other thing to look at is the exhaust system, primary pipe size and length and muffler size.
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on May 15th, 2010 at 12:04 PM
bigger vents for sure dave
If you havent played with them before, do it! Can make big improvements
MemberSides
A.k.a.: Dave Sidery
posted on May 15th, 2010 at 12:37 PM
Hey thanks for comments guys.
The throttle bodies that will be going on are 48mm Injection Perfection jobby's (IDF pattern). Had them off the shelf and out of the box the other day... look hell big compared to what's on at the moment.
It's now a race between my temptation to play with vent changes etc. and seeing when I can get the EFI conversion done. EFI is in the lead at the moment since I've just ordered the ECU, but then again if some 38mm vents turned up, who knows...
My toys
posted on May 15th, 2010 at 12:42 PM
Go the bigger vents for a try Dave, if it is your car of course???
What is your exhaust?
MemberCraig Torrens
Threads: 347
posted on May 15th, 2010 at 12:49 PM
go the vent change...easy and quick to do.
what size was Reubs injection on his motor ?
MemberGracey
Threads: 17
Mood: Itchy
posted on May 15th, 2010 at 01:01 PM
Dave, haven't you already got 38mm vents?
Memberhellbugged
A.k.a.: Daimo Pell
posted on May 15th, 2010 at 01:45 PM
a box of vents here if you want me to look
MemberSides
A.k.a.: Dave Sidery
posted on May 15th, 2010 at 02:03 PM
Matt - yup - my car, and no reason not to play with it hey. Exhaust is one of Westi's 1 5/8" stainless merged setups with a fatboy mounted on it... bit loud, but don't think any restrictiveness issues there.
Gracey - vents that are in are 36mm. I do have some 38 vents somewhere, but they use that horizontal spray bar setup.
Craig - Reub's throttle bodies pretty sure are 48mm Injection Perfection same as mine, tho I've gone for a different ECU and ignition setup.
Damo - if you've got some 38's in that box there that'd be awesome !!!
:D
My toys
MemberSTIDUB
Over it.
Threads: 57
posted on June 8th, 2010 at 12:35 AM
http://www.boostcruising.com/database/forums/files/post-176350-12758832431775541977.jpg
looky what i found, altho dave probably knows jeff took the pics
MemberSides
A.k.a.: Dave Sidery
posted on June 8th, 2010 at 10:40 AM
Yeah, Jeff's a mate of mine who was there working as finish line flaggy... supposed to be some video coming too I think.
Had 29 runs over the weekend, and Jezzi didn't miss a beat. Managed to lower my PB on each of the 3 days, and am now down to 51.53 (before the weekend was at 53.00). Consistency I'm getting with it now is brilliant... every run where I was trying was in the mid-low 52's, and quite a few of them in the mid 51's.
So yeah - I'm pretty stoked.
Bigger vents and some different emulsion tubes are on the way, service and then back to the dyno to see if can tune out the super-rich flat spot... can't wait !!!
:D:D:D
My toys
Threads: 51
posted on June 8th, 2010 at 11:22 AM
That would have been taken up near where we were last time we went to cotton. I shall now not post images as mine are rubbish. haha.
Hey Sides, in case Sti hasn't talked to you, would you be able to take those parts for my car to the meeting on wednesday... Looks like brakes/suspension will happen this saturday, in daves garage in Ippy! (see, there was a reason why I helped him get his rolling!)
MemberSides
A.k.a.: Dave Sidery
posted on June 8th, 2010 at 12:59 PM
Nah, sorry - no can do Mustard. I'm in Perth at the moment with work, and don't get back till early Saturday morning. Can get them to him sometime after that tho no probs.
My toys
Threads: 51
posted on June 8th, 2010 at 01:05 PM
Oh. true. All good :) I may try trevor and see if he has any.... otherwise, i guess I will wait a few more days. Not a prob. :)
Memberdangerous
Mood: 591
posted on June 8th, 2010 at 03:23 PM
:D:D:D
Good work Dave,
look forward to seeing some vids of the faster runs.
29 runs!?!!
Originally posted by westi
That's mad Alan.
MemberSides
A.k.a.: Dave Sidery
posted on June 8th, 2010 at 03:40 PM
Yeah, thanks DB - will link the vids when they're up.
Heh heh yup - 29 runs... kind of a running joke at Mt Cotton how I'm always up for as many runs as possible.
Sat 15:45 they announced over the PA that entry to the track would be closing at 16:00. I jumped in and put 3 more runs in, so then at 15:55 gets announced "Practice is finishing in 5 minutes, so come down NOW if you want another run... but don't come down in a Volkswagen or you'll be shot".
:D:D:D
My toys
Membervassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on June 8th, 2010 at 04:07 PM
Well done Dave! Look forward to catching you at an event soon.
posted on June 8th, 2010 at 06:48 PM
Good stuff Dave, PB......woo hoo, careful you don't wear ot out though, you'll be first name basis with the starter dude too I bet :lol:.
MemberCraig Torrens
Threads: 347
posted on June 8th, 2010 at 09:32 PM
Good work :)..... I've never raced at this track, so what times do the other hillclimb beetles do there ?
MemberSTIDUB
Over it.
Threads: 57
posted on June 8th, 2010 at 10:44 PM
what other hillclimb beetles?
pretty sure sides is the only bug ive seen there, makes him easy to find though
Memberbat69
There is no status
Threads: 84
Mood: I'm EXCITED!
posted on June 9th, 2010 at 08:57 AM
Myself, Greg Ward, the Campbell and Durie beetle have all run at Mt Cotton for the QLD hillclimb championship. Greg ran at the QLD Hillclimb championship a few times in the past and Heath more recently. I ran there in 2007 and I know Greg was there last year in his bug. There is a local bloke who has run there in the past in a beetle but his name doesnt come to me at the moment.
what times do the other hillclimb beetles do there?
High 47's and low/mid 48's. When I ran there last, which also happened to be one and only time I ran there I managed a 48.4 I think and Heath and Greg have been into the high 47's. I love this track. A real drivers circuit where commitment either pays off or bits you hard. Im hoping to get back to have a another go sometime soon.
White Knuckle Racing Team
"Drive it like dirt"
Membervassy66T1
A.k.a.: Marcus Vass
posted on June 9th, 2010 at 09:53 AM
I've heard of other people reportedly building another beetle but that rumour was a long time ago now ....:no:
There was a green beetle running a type IV that I saw one time at the Australian titles. He was in the 40's from memory.
Dave knows who I am talking about but I can't remember the name.
posted on June 9th, 2010 at 11:28 AM
I wonder if that will ever eventuate??? :lol::lol::lol:
MemberBiX
Threads: 154
posted on June 9th, 2010 at 12:09 PM
Dave those are excellent times, you must be stocked!
For comparison, I have done I think 55/56ish in 2003 or 2004 with a stock headed 1776, stockish suspesnion and 185 street tires. But getting from 55/56 to sub 52 is a big step, and I can't think of the guys doing 47's....I was bitten though, before they upgraded the finsih line, lifted on the line and nosed the rock wall :mad: Will have to find my timeshets.
That green bug was awesome to watch, used to run a 2.7L ? type 4 as said above, and ran 17inch wheels with big brakes.....
Go hard or go home!!!!
 Pages:  1  2  3
