| [ Total Views: 3065 | Total Replies: 33 | Thread Id: 83264 ] |
| Pages: 1 2 |
JVLRacing
Threads: 30
| posted on May 4th, 2010 at 10:49 PM |
wat pete and steve said is the way cheaper way...my concern with exhaust pipe would be corrosion in the long term...alittle heavier to...
I went alloy piping lighter and knowin no corrosion shit will end up in motor or rad...
gerrelt
Threads: 3
| posted on May 5th, 2010 at 04:20 AM |
I used exhaust tubing too. I don't worry about corrosion. Rust prevention is normally part of the coolant.
There are iron parts in the coolant system, my Alfa engine has a cast iron crankcase, partially (pully side, clutch side and heads are alloy). Plus
the water pump rotor is cast iron too (maybe with a subaru too?).
Just use a well known brand coolant, and exhaust pipe will work fine. It's handy to be able to weld the pipes together too.
Joel
| posted on May 5th, 2010 at 10:08 AM |
geez you guys must have some cheap muffler shops around
it was cheaper for me to use stainless than exhaust tube
not real upset though, they will outlast the car and you cant beat stainless for its conductive properties
JVLRacing
Threads: 30
| posted on May 5th, 2010 at 11:51 AM |
| Quote: | Originally
posted by Joel
u made the right choice joel
| Pages: 1 2 |
