| [ Total Views: 12145 | Total Replies: 193 | Thread Id: 83581 ] |
| Pages: 1 2 3 4 .. 7 |
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
| posted on February 9th, 2011 at 07:50 PM |
These 2 photos show the bar welded up with the welds ground smooth. Also show position bar will be in when mounted to the car so I can mock up and
measure where I will be attaching the horizontal bar.
Bar sits higher as I plan to mount it level with the bottom torsion bar.
If anyone is looking at these photos, I would be keen to here some ideas on how I could attach the bar.
My thoughts are to weld some flat bar onto the bottom tube and to the mounting bracket, then weld a short piece of tubing onto the flat bar that I can
slide the bullbar onto nad bolt through. Also will have some tubing attaching to the shock towers.
What do people think?
| Error |
| Error |
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
baghall
Threads: 131
| posted on February 9th, 2011 at 08:03 PM |
This is what I mean by the a bracket on the bottom tube.
| Error |
pod
A.k.a.: paul mrvw061
Mood: could be better
| posted on February 9th, 2011 at 09:12 PM |
when i made one for the baja i was building i used the bottom beam mounting bolts to mount the bar
baghall
Threads: 131
| posted on February 10th, 2011 at 03:16 PM |
Hey Pod, do you have any photos of the brackets you made up. I like the idea just seems too easy!
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
| posted on February 10th, 2011 at 09:08 PM |
Have a look at the bottom on page 14 of my build and on page 15, shows the mounts I made up for mine.
http://forums.aussieveedubbers.com/viewtopic.php?tid=80275&page=14
The only thing I would have done differently (and will be fixing in the future) is run tubes from the the back of the mount to the floorpan under the
A-pillar area. This helps support the front beam.
Smiley
PS - Baja is looking great! Good to see you're motivated even after the setbacks with the crash.
baghall
Threads: 131
| posted on February 12th, 2011 at 03:29 PM |
Continued to modify old bar by cutting up a 2nd bar and rewelding both together.
Several holes needed filling as well.
| Error |
| Error |
| Error |
baghall
Threads: 131
| posted on February 12th, 2011 at 03:32 PM |
And here's the bar all together. Have started fabricating brackets but due to time constraints will end up taking a bit more time to make. Will
upload photos when done!
Bar is a bit heavier than I would like but beggars can't be choosers, and it would be ample strong enough to mount a 4x4 winch.
| Error |
pod
| posted on February 12th, 2011 at 03:38 PM |
no pics of brackets ,but i know i used 100 x 10 black steel,i had a pipe welded at the back of the legs with the brackets welded to this
baghall
Threads: 131
| posted on February 12th, 2011 at 03:41 PM |
Glad you like the baja. A previous owner did manage to have the brackets going back to the 'A' pillar but they used 10x40mm flat bar. Bloody heavy
and way over engineered. I may do this but will use different brackets to save on weight,
baghall
Threads: 131
| posted on April 21st, 2011 at 08:30 PM |
photo update
1st photo shows the bracket for mounting the front bar.
next 2 photos show the bar on Al.
| Error |
| Error |
| Error |
baghall
Threads: 131
| posted on April 21st, 2011 at 08:35 PM |
following photos show the condition of the brakes and what they looked like after cleaning up and preparing gearbox to install to replace the old box
with only 3 gears. Lost 4th gear.
| Error |
| Error |
| Error |
baghall
Threads: 131
| posted on April 21st, 2011 at 08:39 PM |
gearbox cleaned up. Sorry no picks of before I cleaned it, but was quite oily and dirty.
Was terribly unsuccessful today with assembling the brakes, due to brake specialist not getting the shoes religned in time. Wasn't completely happy
as was planning to go off roading for easter but now car is off the road till after easter when I can get the shoes. Oh well, hopefully I can get some
other stuff done to the car.
| Error |
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on April 21st, 2011 at 09:08 PM |
Hope you didn't get any water into the transmission through the broken axle boots.....
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
baghall
Threads: 131
| posted on April 21st, 2011 at 09:36 PM |
11cab
Yeah I assume I did but was very carefull, but will be changing out oil anyway. Oil that leaked was crystal clear though.
baghall
Threads: 131
| posted on April 26th, 2011 at 05:45 PM |
Had intended installing new master cylinder monday but rain put a stop to all work. Garage is too small for me to store gear and work on car in there.
Oh well, realised I have next weekend to complete gearbox and master cylinder, if I don't get time on after work.
baghall
Threads: 131
| posted on May 2nd, 2011 at 03:00 PM |
Well new gearbox installed, engine being difficult to get in as is 1 handbrake cable and still waiting for brake pads to be done with new linings.
Was slack with the MC and have not installed it yet.
Smiley
Threads: 110
Mood: Synchro'd
| posted on May 2nd, 2011 at 06:39 PM |
| Quote: | Originally
posted by baghall
Keep at at mate! Not much left to go and you'll be looking for some nice mudholes to try her new gearbox out in!!
Smiley
baghall
Threads: 131
| posted on May 2nd, 2011 at 07:33 PM |
Yeah thanks Smiley. Will get there soon Just trying to fit engine to the bell housing but turns out gearbox was a 6V flywheel. So gotta clearance for
the 12V flywheel. Almost fitting about 5mm to go. Getting impatient though.
Bloody frustrated with the brake specialist.
baghall
Threads: 131
| posted on May 4th, 2011 at 04:25 PM |
Brake shoes are here. FINALLY. but can't fit as I forgot to get
some other parts due to damage from trying to get seized shoes to release from drum. Buggar. Hopefully I can get them tomorrow.
Engine is in but unable to star. Flat battery! Guess I should have put it onto the charger. Oh well!
baghall
Threads: 131
| posted on May 6th, 2011 at 11:07 PM |
It's ALIVE! Yeah.
Got brakes together and have also got it started finally. However the alternator pulley was running a concentric circle SO not good. Bought a new
ingot pulley to replace the original pulley. Original was badley chewed out and had twisted on the shaft. Not sure why this happened but new pulley
does look good.
| Error |
| Error |
| Error |
| Error |
baghall
Threads: 131
| posted on May 19th, 2011 at 06:33 PM |
Nice for me!
Look what arrived yesterday, side draft dellorto. Wish I was ready to put it onto Al but not yet, few more things to do and buy first.
| Error |
kaiisons
Mood: Dubbin
| posted on May 19th, 2011 at 09:34 PM |
hey man saw you driving on the great western highway towards penrith on tuesday arvo. looking and sounding good mate! wouldn't have seen me I wasn't
in my Kombi
baghall
Threads: 131
| posted on May 21st, 2011 at 08:17 PM |
Buggar attahment too large now I gotta type it all again.
Gidday kaiisons, yeah I live in Kingswood. Will keep an eye out for the kombi.
Well got off my arse this week and worked on Al.
Bought a set of sunraysias from a suzuki vitara with 139.7 PCD. Wire wheeled them clean and repainted them. Used silver hammertone paint and think
they will look good. Will be fitting some 2nd hand 205/70 all terains for now. Also got my new front rotors drilled to suit. Painted these also but in
red. Just gotta wait till next saturday when I can fit them.
'scuse the ugly mug but thought I would post a photo of my war wound from the wire wheel. Thank God for safety equipment. Got hit several times in
the face by wires. Felt like someone was throwing rocks at me.
| Error |
| Error |
| Error |
kaiisons
Mood: Dubbin
| posted on May 22nd, 2011 at 05:35 PM |
That was me at Mike's too!
baghall
Threads: 131
| posted on May 23rd, 2011 at 12:53 PM |
| Quote: | Originally
posted by kaiisons
Met a few people there recently. Were you the guy I was talking to under the orange kombi?
kaiisons
Mood: Dubbin
| posted on May 24th, 2011 at 03:44 PM |
Yeh, thats me, the young bloke haha. My kombi is like in my avatar.
baghall
Threads: 131
| posted on May 24th, 2011 at 09:37 PM |
| Quote: | Originally
posted by kaiisons
Was good to meet you today. Hope the engine runs well for you now!
baghall
Threads: 131
| posted on May 28th, 2011 at 08:38 PM |
Spent the day giving Al some TLC.
Replaced master cylinder with a new German made one. Replaced front brake lines with a new braided pair. Replaced front brake rotors with a new pair,
painted red cause as we all know it means better performance. Also cleaned up brake calipers and painted them. Red of course!
Photos are of rims before cleaning and painting and calipers before and after.
| Error |
| Error |
| Error |
baghall
Threads: 131
| posted on May 28th, 2011 at 08:44 PM |
TheTLC continues. More photos of the love.
I think the wheels look good against the red.
Just gotta bleed the brakes in the morning to complete the work.
| Error |
| Error |
| Error |
baghall
Threads: 131
| posted on May 31st, 2011 at 10:28 PM |
Seems I have an added bonus with the wheels. I knew I would get some lift at the front due to the rolling diameter being almost 2" taller, but what I
didn't expect is I have improved the ride comfort. I'm assuming its because of the higher tyre profile. Brakes have awesome feel now due to braided
line. Now to get the rear end upgraded.
I'm sick of being a swinger!
