| [ Total Views: 7368 | Total Replies: 78 | Thread Id: 83840 ] |
| Pages: 1 2 3 |
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on May 24th, 2010 at 08:42 PM |
No, but I felt it!
matberry
| posted on May 24th, 2010 at 08:48 PM |
| Quote: | Originally
posted by HappyDaze
No, but I felt it!
No argument here.
Glad your still with us Greg, the car is a mess, you were very lucky. I bet you're a bit stiff today.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on May 24th, 2010 at 09:05 PM |
I feel fine thanks Matt - apart from a couple of sore spots. OK for an old bloke. That 6 point quality harness was good value, although I would rather
have not had to rely on that.
Cheers, Greg
1303Steve
| posted on May 24th, 2010 at 09:07 PM |
| Quote: | Originally
posted by johny rotten
That drum has broken during the rollover from side impact
not prior too
the axle is very bent
sorry if u disagree
Greg is a very experienced driver and has done 100s of laps of this track, he is the one person that would know if a mechanical fault preceded the
roll over.
So what makes you so sure the axle is bent? You could make a fortune in industry looking at photos and diagnosing faults.
Its a swing axle car and has just been manhandled onto a trailer, of course the axle will settle at an odd angle
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on May 24th, 2010 at 09:08 PM |
Anyone have video ?
That corner seems to always have rollovers, I've seen 5 or 6 cars go over there !
vdubrod
Threads: 3
| posted on May 24th, 2010 at 09:55 PM |
Hi Greg it was good to see you at the VW Nationals yesterday after your adventure at Wakefield park I didn't see the accident at all because I was
flagging at turn ten the last corner before the straight and as I said to you on Sunday you were really pushing that little thing onto the main
straight you would of been one of the fastest cars through that corner if not the fastest and I know on the run where you rolled your car you were
coming into ten very very fast and on your 1st and 2nd laps the wheels were braking loose and smoking the tyres and on the 3rd lap you were really on
the limit and you found it where you spun but just as quick you smoked the tyres and you were off but then I had the call over the two way red flag
red flag looked around and seen you get out of the car (turn 10 is along way from where you rolled over) and I said to my offside it greg silly bugger
spun off again little did I know that you had rolled the thing in spectacular way and when you showed me the passenger door on Sunday I realised then
how very lucky you were. And just to say in Greg's favor I have seen the man drive at very close range and if he said it is not driver error I am a
believer.
Greg do you give racing driving lesson I am about to venture into Super Sprinting and I wont to come Salt Racing I have confidence in your driving
ability.
Jeff Dunn Club Vee Dub
colin
Threads: 82
| posted on May 24th, 2010 at 10:21 PM |
Very sorry to see those pics of your car Greg, but heaps happy to hear your okay.
Cheers Col
westi
what the
Threads: 28
Mood: not blue, pink
| posted on May 24th, 2010 at 11:43 PM |
i hope you bought a lottery ticket after that one,lady luck was obviously on your side.
bad news about the car. great new's to hear you walked away.
down sharon.
vw54
| posted on May 25th, 2010 at 09:15 AM |
I understand that the Formular VEE guys have been seeing a similar problem
they apparently have designed a outer cover to help hold the drums together
( would be good to get some input for the VEE guys and how many times this has happened )
Greg remmeber what Boris and i said to you seperatly before the race we both agreed good S/Hand drums would have been better to be used
Sorry it had to destroy the car and we are all glad you able to tell the story
great advert for your door pillar center brace what gauge is that material ???
what sort of testing are you haveing done to the drum i hope there a similar thickness to the origionals
most probaly the material will vary
Craig Torrens
Threads: 347
| posted on May 25th, 2010 at 10:47 AM |
So where are the new drums manufactured ?
Can you still buy german ones or are they all aftermarket suppliers now ?
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on May 25th, 2010 at 11:37 AM |
| Quote: | Originally
posted by vw54
Would be interesting to hear of other drum failures.
You did mention your preference to the original drums, but if YOU remember, it was Sunday, not Saturday.
The centre brace is 1.6 pressed steel.
Could be a while before I have any test results, in the meantime I don't think we need to 'panic'. I know that I was working those drums far harder
than they were designed for. 'Normal' use would probably not be a problem. What we need is constructive, factual feedback here, so we can all be
aware of the limitations of the stuff that we put on our (special) cars.
Cheers, Greg
Water Boy
Threads: 19
| posted on May 25th, 2010 at 02:15 PM |
Wow. Bad luck and im glad you are ok.
At mentioned before the Formula Vee's run a plate to strengthen the drum.
vw54
| posted on May 25th, 2010 at 05:16 PM |
Greg
I remember discussing the drums with you on Saturday in the pits right after u told me you got new ones
and had fitted the alloy cooling fins as per your origionals you even mentioned the brand
I wonder who we can contact re the Formular Vee Failures
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on May 25th, 2010 at 05:57 PM |
try craig from vwma, he is in the vee scene now
johny rotten
| posted on May 25th, 2010 at 08:58 PM |
not many 1200 / drum brake vees running any more
most are 1600cc disc brakes etc now
hellbugged
A.k.a.: Daimo Pell
| posted on May 25th, 2010 at 09:10 PM |
"tassupervee" has been in vee's for a long time. he may have heard about this happening
http://forums.aussieveedubbers.com/viewprofile.php?memberid=1504
or ask here
http://www.fvee.org.au/
matberry
| posted on May 25th, 2010 at 09:54 PM |
John Alder is doing a job for me next week, he may know...I'll get his angle as his vee's are running up there with the best of em.
I also saw a drum failure late last year (or early this year), but it was an aftermarket drum with a jap 6 stud off road pattern from a local
supplier. Similar break although it was more obviously a thin zone near the machined stud pattern.
1303Steve
| posted on May 28th, 2010 at 11:49 AM |
Something that I don't think has been brought up, VW went to burst proof door locks in Australia with the introduction of the 1500 Beetle.
If the doors had stayed shut on Greg's car during the rollover it may have stayed in better shape, still would have been buggered but the roof would
maybe not have collapsed as much as it did with a door still in the opening.
Joel
| posted on May 28th, 2010 at 01:23 PM |
i think it was in one of the other threads someone mentioned how bad 6 volt doors are for flying open in accidents.
my best mate and his sister rolled in her 64 and naturally both doors flew open and the windscreen pillars gave out
the latches are such a bad design when you look closely
Richard holzl has the right idea using mexican doors which have 6 volt windows but the later bear claw type latch
Steve, talk about syncroncity, did you see only yesterday someone posted that classic nurburgring vid on GL with all the vws rolling on that
corner.
theres a shot in that where a guy is ejected out of his early bug cos the door flies open and it has no seatbelts
http://www.youtube.com/watch?v=YZb7sbRFCF0&NR=1
Craig Torrens
Threads: 347
| posted on May 28th, 2010 at 02:21 PM |
| Quote: | Originally
posted by Joel
That's actually VW's idea, the shells are available new like that.
1303Steve
| posted on May 28th, 2010 at 02:58 PM |
That you tube video is scary stuff
Craig of course its VW idea, Joel was saying that Richard retro fitted Mexican doors to early bugs, the Steve MvMullan/ Alex Hozl Oval has them.
Craig Torrens
Threads: 347
| posted on May 28th, 2010 at 03:41 PM |
oh I was refering to the shells you can buy from Fermans, the mexican/brazilian ones that came like that from the factory.
matberry
| posted on May 28th, 2010 at 05:54 PM |
Like this one
| Error |
fullnoise
Threads: 103
Mood: Middle of the road.
| posted on May 28th, 2010 at 06:03 PM |
I didn't like that YouTube video
How many VWs were destroyed in that YouTube video?
I've always been worried about my beetle turning into a ball.
Sheeesh.
esratrams
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
| posted on May 28th, 2010 at 06:47 PM |
| Quote: | Originally
posted by 1303Steve
The doors would have done SFA in stopping the roof of the car from caving in. The only thing that would stop that would be a properly designed and
installed roll cage. Even with one, the impact on the roof still would have been extensive.
White Knuckle Racing Team
"Drive it like dirt"
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
| posted on May 28th, 2010 at 06:53 PM |
| Quote: | Originally
posted by fullnoise
Sheeesh.
Thats what motor sport is all about... You cant worry to much about crashing when your driving your car at 10 tenths. Other wise you will throw it off
into the trees or armco.
cb john
Threads: 6
| posted on May 28th, 2010 at 08:02 PM |
| Quote: | Originally
posted by vw54
Greg
Drum failures on early F Vees were a chronic problem...
The drums out of 1200 cars did not have this problem, the brakages started to appear with usage of 1300 drums...
( the same shape as Greg's drum )
To prevent this to happen, Frank Kleinig designed the device, which is spun 2.0 mm steel, kind of a top hat which bolts on the drum by axle nut and
wheel nuts..
If the drum brakes, it still keeps the wheel in the position ( kind of )..
I think that I have a pair in my shop , will try to take some pictures..
1303Steve
| posted on May 28th, 2010 at 08:10 PM |
| Quote: | Originally
posted by bat69
I don't agree but I'm not going to crash a car to prove my point.
This super bug had huge hit in the front, what do you think would have happened if the doors had flown open.
| Error |
Joel
| posted on May 28th, 2010 at 08:17 PM |
| Quote: | Originally
posted by fullnoise
Sheeesh.
too many
I cringe when i see that bug cabrio fly through,
if it had rolled like the others thats 4 people probably not wearing seatbelts
the vid is shot in 1970 so that cab was brand new
way to total a brand new car if it got ugly liek the others
colonel mustard
Threads: 51
| posted on May 28th, 2010 at 08:34 PM |
i always cringe at that purple bug... completely owned in the front. but you are right steve... the doors saved the driver, in a sense. the cage is
still bent at the top of the a pillars, and given enough force where the cage bolts/welds to the floor at the front, it would still be crushed. I dont
remember the speed that purple super was going, but double it and the driver would be dead.
| Pages: 1 2 3 |
