[ Total Views: 4883 | Total Replies: 33 | Thread Id: 84142 ]
Author: Subject:  Ryans MK2 GTI Golf - A/C on the way!
Memberryana89
Threads: 20
posted on October 19th, 2010 at 09:51 PM
Why not bore you all some more with updates:D
Have finally changed the drive flange seals along with a gearbox oil change.
The newer fully syn oil deffinantly helps with gear changes.
The car now has a new muffler aswell as the original decided to crack in numerous vital places.
Also replaced some suspect fuel lines leading onto the injector rail the other day aswell.
Not a bad idea considering the fuel leak was right above the exhaust manifold!
The car may be running on an Oxygen Sensor too soon if time and money permits.
2.0slow 92 MK2
Memberryana89
Threads: 20
posted on December 13th, 2010 at 08:45 PM
After realising the fuel injection system was not Digifant 2, but Digifant 1 (gold star if you know what either of those are), I started looking through many wiring diagrams trying to find out the colours of the Oxygen sensor wires.
Well in another surprise I found out that the wiring used in this car is...well unique to this one and only car?? Ill explain.
Take for example this picture of the ECU connection
http://i753.photobucket.com/albums/xx176/ryana90/VWW/DSCF0525.jpg
Wire/connection number 9 is meant to be a 'shield' for the Oxygen sensor and should be black, however the wire is yellow with a black pinstripe and is used for something completly different.
Wire/connection number 16 is meant to be the actual sensor wire for the Oxygen sensor and should be violet in colour, however it is white.
Noone in our local area is willing to look at it, thus my only option is to visit a specialist in Brisbane or Sydney....
Gotta love old cars:lol:
2.0slow 92 MK2
Memberryana89
Threads: 20
posted on January 15th, 2011 at 09:35 PM
^^Going to forget about wiring for the moment.
Got a rather large goodie from overseas yesterday
http://i753.photobucket.com/albums/xx176/ryana90/VWW/SAM_0042.jpg
A/C tech is installing this Tuesday, fingers crossed.
2.0slow 92 MK2
Memberryana89
Threads: 20
posted on January 15th, 2011 at 09:40 PM
Finished this a couple of weeks ago too, not to bad'a result either.
52mm Voltmeter and Oil Pressure gauges mounted in a piece of aluminum, coated with some wrinkle paint.
http://i753.photobucket.com/albums/xx176/ryana90/VWW/DSCF0547.jpg
http://i753.photobucket.com/albums/xx176/ryana90/VWW/DSCF0545.jpg
PS: If you ever want to steal a MK2, that key socket in the right of the top picture activates/deactivates the alarm;)
2.0slow 92 MK2
[ Queries: 40 ] [ PHP: 7.1% - SQL: 92.9% ]
