[ Total Views: 2138 | Total Replies: 40 | Thread Id: 86662 ]
Author: Subject:  Best Battery manufacturer
Memberpsimitar
Threads: 148
posted on October 25th, 2010 at 07:13 PM
Looks like a Century then. Now just to see if anywhere is cheaper than Supercheap @ $150 :)
posted on October 25th, 2010 at 07:41 PM
WHAT SIZE BATTERY?
How many CCA's..??
Recessed posts??
how long a warranty?
I always get my EXIDE from Big W...
Memberpsimitar
Threads: 148
posted on October 28th, 2010 at 07:32 PM
WHAT SIZE BATTERY?
How many CCA's..??
Recessed posts??
Size - biggets that'll fit
CCA - much as possible
Recessed posts - I'd rather not
EXIDE - only if bought for me as my experience has tarnished their name beyond ever spending my own money on them again until faith is restored by an EXIDE freebie :)
Memberwaveman1500
Also rides a Honda
posted on October 28th, 2010 at 07:40 PM
If it's going into a Beetle then you definitely should have a battery with recessed posts. Many Bugs have caught fire due to the owners fitting batteries without recessed posts. When the posts stick up they can come into contact with the seat springs and short out the battery, potentially causing battery damage and/or fire. Either way, make sure you have something non-conductive over the top of the battery.
MemberMickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on October 28th, 2010 at 08:32 PM
DEKA....8 years and still going strong!!!
tssnq.com.au
Memberpsimitar
Threads: 148
posted on October 30th, 2010 at 02:43 PM
Doesn't matter if the posts are recessed as if someone sits there arse down hard enough it'll still short across them. I just fitted a polycarbonate cover over the battery and job done :)
Memberancientbugger
Threads: 191
posted on October 30th, 2010 at 04:54 PM
Or change the terminal ends (?) on the cables for the quick release type from a boat shop, as I did on my sons baja, they have plastic covers on them and even the Qld Transport guys said it was a good idea.
Memberwaveman1500
Also rides a Honda
posted on October 30th, 2010 at 05:48 PM
That does sound quite a good idea. You only really need to change the positive one though, doesn't matter what the earth strap hits. Most beetles still have the braided non-insulated earth straps anyway.
Memberancientbugger
Threads: 191
posted on October 31st, 2010 at 10:20 AM
I think I changed both so when he wants to take the earth cable off it's easier or they came in a pack of two:crazy:
Memberpsimitar
Threads: 148
posted on November 2nd, 2010 at 06:55 PM
I have a positive terminal that allows seperate Starter, regulator, Ignition relay and Starter relay.
I've a modern modular fusebox with relays to take the strain from the 50 yr old switches ;)
MemberFastback
Threads: 1
posted on November 30th, 2010 at 10:34 AM
While I do not usually recommend manufacturers, I have had very good experience with Odessey batteries, while they cost over $100 more they are smaller and can be placed in any orientation. The two I have had have been extremely reliable.
My old RX7 used to kill batteries until I switched to these
