[ Total Views: 5256 | Total Replies: 38 | Thread Id: 86711 ]
Author: Subject:  Colour codes for Australian Type Threes
Memberjedt3
Threads: 12
posted on September 7th, 2011 at 12:32 PM
Hi,
The link to the Australian colour codes no longer works. Does anyone have a copy of this?
Regards,
Jed
MemberNotch Nut
Threads: 37
posted on October 5th, 2011 at 08:15 PM
Does anyone know the colour name/code for the white used on a 1965 Type 3.
Car has Made in Germany on the build plate but would have been an Australian sold model.
Cheers.
MemberBurrelli
Threads: 4
posted on October 5th, 2011 at 09:59 PM
Hi Notch Nut,
Australian 65 type3s where Polar White and they had Made in Germany on the Vin plate.
Here is a link to Australian Volkswagen Dulux paint codes I found. I hope this helps.
http://forums.eurocca.net/showthread.php/17367-older-VW-paint-charts
posted on October 6th, 2011 at 07:21 AM
Originally posted by jedt3
Hi,
Regards,
Jed
See if this works OK
MemberNotch Nut
Threads: 37
posted on October 6th, 2011 at 08:27 PM
Originally posted by Burrelli
Hi Notch Nut,
Cheers Burrelli :cool:.
I wrecked a turquoise type 3 wagon (1965) with a colour code tab on the front behind where the spare wheel is located but on the notch is a welded tab with the numbers B3714. I am assuming that this is also reffering to a paint code of some sort. It doesn't correlate to any colour codes. I found it rather strange that for 2 cars made in the same year(ish) one is rather obvious about its colour codes and the other is rather vague. I'm going to take some photos and post them to show you what I mean.
Here we go...
http://i84.photobucket.com/albums/k35/notch_nut/Paintcodes.jpg
MemberBurrelli
Threads: 4
posted on October 7th, 2011 at 01:03 PM
Notch Nut,
The welded on plate that is on both the cars is some sort of numbering system they used in the Australian Volkswagen factory in the manufacturing of the bodies. The paint code was on a silver sticker that the Turquoise still has but the white car seems to have lost.
Make sure the white car is a 65. 65-66 models will have a 5 or a 6 as the 3rd digit on chassis number. That would make the car Polar White, If it is a 67-68 (with a 7 or 8 as the 3rd digit) it will be Lotus White as per the paint chart.
63-64 models had different numbering system and the 3rd digit thing did not apply. (I think after 64 the numbering system changed???)
Your Turquoise car must be earlier than 65 going by the colour chart.
MemberNotch Nut
Threads: 37
posted on October 8th, 2011 at 10:27 PM
The white car is a 1965 reg'd notch (been in family since 74) and never to my knowlege had a paint label on it. It is a 315 chassis no car though. Back then was the paint done by Dulux? I am curious because I have a guard that needs a respray but the paint is faded and needs to be colour matched so a general paint code/colour would be an ideal starting point to go by. The turquise car has since been wrecked but I have kept the front half intact as a "spare".
Thanks for your help BTW. :tu:
Memberjedt3
Threads: 12
posted on October 13th, 2011 at 11:29 AM
Hi,
Thanks for posting the chart. Safari Beige it is!!
Regards,
Jed
Memberdragsters for life
Threads: 51
Mood: always a happy chappy
posted on October 13th, 2011 at 05:11 PM
http://i889.photobucket.com/albums/ac94/mrspeccles/pias%20bus/297762_280812958613794_100000552763904_1075494_75148707_n.jpg
[ Queries: 40 ] [ PHP: 0.6% - SQL: 99.4% ]
