| [ Total Views: 1405 | Total Replies: 33 | Thread Id: 90061 ] |
| Pages: 1 2 |
68AutoBug
| posted on May 6th, 2011 at 11:51 PM |
that is 175 degrees Farenheit NOT celsius
130F = 55C [far as My thermometer goes.. lol]
as the USA still use farenheit - Gallons - Quarts - pints etc..
and MIles per Hour... lol
aussie260z
Threads: 24
| posted on May 7th, 2011 at 08:56 AM |
Yeah I know :-)!
However, apparently the yanks have started using Litre's a lot more frequently then quarts, but I still think they buy their fuel by the
Gallon.............which is a Yank Gallon too, not our version of a Gallon :-)!
1303Steve
| posted on May 7th, 2011 at 12:54 PM |
The only problem with a full flow setup is that they often blow oil filters, mostly in cold areas.
aussie260z
Threads: 24
| posted on May 8th, 2011 at 01:10 AM |
Yeah, read about that.
But I came across a GeneBerg product that apparently gets around that.
They do an Oil Pump cover for a full flow system which apparently keeps that pressure through the lines at 125psi, which, if true, should hopefully
stop me blowing apart oil filters.....................that sounds messy :-)!
# GB 241 from memory.
HOWEVER.................really looks like the only way to do this properly, is to drill and tap an oil gallery if I am looking at a full flow
system...............As I am not overly keen on tearing down my engine to drill and tap it, as it is really not needed right now - think I will
probably just go something like this for the moment so I can at least add an oil filter.
http://vwparts.aircooled.net/Bugpack-32mm-Bypass-Filter-Oil-Pumps-p/3030-10_3...
| Pages: 1 2 |
