Poll: urgent tuning HELP....still cant find the problem....
-- 0 (0%)
[ Total Views: 1836 | Total Replies: 42 | Thread Id: 90318 ]
Author: Subject:  urgent tuning HELP....still cant find the problem....
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on July 23rd, 2011 at 09:18 PM
I run 140mains, 175 airs if that helps ?
Maybe yours is running rich in the top end ?
Membercnfabo
Threads: 140
posted on July 23rd, 2011 at 09:44 PM
is it a leaning out effect im getting....
MemberCraig Torrens
Threads: 347
posted on July 23rd, 2011 at 09:48 PM
over rich can make the car feel bad in the top end as well.
Membercnfabo
Threads: 140
posted on July 23rd, 2011 at 09:55 PM
cheers craig....
ill update in a week or so,just moverd house ....
MemberCraig Torrens
Threads: 347
posted on July 23rd, 2011 at 09:56 PM
moving is a PITA !
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on July 24th, 2011 at 09:18 AM
Chris, just a thought..........did you 'bed' the cam and followers in PROPERLY? Have you checked valve timing?
The mains seem a bit big, as Craig says, but that would only drop the power a bit.
Membercnfabo
Threads: 140
posted on July 24th, 2011 at 10:11 AM
greg, the cam got bed in years ago and we did it properly...i got a pm of fa dude on ultimate aircooled and he thinks my spring pressures are too low......they are currently 125 pounds on the seat and 275 pounds at 534' lift "full lift"..he suggested trying to shim them up.....i have plenty of room to bind....
posted on July 24th, 2011 at 10:13 AM
Those spring pressures are definately too low.
What was the cam and rpm your using?
Membercnfabo
Threads: 140
posted on July 24th, 2011 at 10:36 AM
engle fk8,i run up too 6500- 7000rpm........these are the new springs i instaled so the ones just taken out even had less......and this problem had only occured after i instaled the 1.4 rockers......
Membercnfabo
Threads: 140
posted on August 5th, 2011 at 11:27 PM
ok here is the update...........still cant find this farkin problem.....i just took my maganaspark dizzy to some dudes to run it up and see if there was something wrong.the only thing they could find was the air gap was too large,30 thou, so they re-gaped it to 5 thou......took it for a spin,poop 4500rpm it starts pooping on me again......it must be the springs......
a mate said disconect all wires to the coil coming from any gauge.as he thinks i might be having some sort of short or something?????
im over it,off to by a horse & cart......
Membercnfabo
Threads: 140
posted on August 6th, 2011 at 07:17 PM
holy, we have a brake through.....i knocked the plug gap down too 28 thou from 40 thou "thanks stan"....but now happening at 6100 up.......so i think im chasing a ignition problem....
Membercnfabo
Threads: 140
posted on August 10th, 2011 at 10:29 PM
mystery solved.....stan pobjoy helped me hit the nail on the head....thanks stan....
..it was the leads or coil.....i installed a msd blaster 2 coil and magnaspark leads......i have not checked which one was the problem as i was too happy that it reved cleanly past 6500rpm so i parked it in the garage then had a beeerrr.......
hope this helps others...
posted on August 10th, 2011 at 10:33 PM
Well done ..... happy days
(C) 2001-2024 Aussieveedubbers
[ Queries: 41 ] [ PHP: 2.6% - SQL: 97.4% ]
