[ Total Views: 2318 | Total Replies: 36 | Thread Id: 91079 ]
Author: Subject:  rubber stops type 3
MemberMatty v
posted on October 18th, 2011 at 02:51 PM
stevedel
Looks sweet, good height for driving around, see some so low i wouldnt get out of my driveway. What work did you do to get that height?
Membervlad01
Mood: Side ways
posted on October 18th, 2011 at 07:25 PM
I think thats 2 splines down on the front by the looks, mine is that height. But rear I have no idea? All the type 3s I have owned were already sagged to that level on the rear :lol:
71 notchback,
Memberstevedel
Threads: 6
Mood: Loving Life
posted on October 18th, 2011 at 09:09 PM
Hi Mattyv,
I haven't actually done anything to the front other than to put the low profile tyres onto the original Empi Riviera rims. I did however completely replace all suspension components - shocks rubbers etc. Result, a very pleasing stance, great handling, a squeaky front left bush from a dry joint, and the need to have the speedo recalibrated. (replaced the original with KPH a few years ago). The comparison photo of the standard size tyre and rim compared to the low profile on the Riviera tells it all. :)
1916 Fastback - Hammer down! Retired!
Memberhaz77
Threads: 6
posted on October 20th, 2011 at 02:58 PM
Thats sure the easiest way to lower a car!!
I had a v-low fasty before with 145's on steels up front & no bump stops, also the steering had to be reduced to stop arching out.
Looked good but thats about where it stopped, if you want a car to drive around freely & without major worry's then sorry but you cant go that low.
Steve, how do you find your gear ratios now?, i checked online an rivieras with 175 65 15's as Ive got on reduce the speedo reading by about 2.8% & therefore the gear ratios so Im looking to go back up to 175 75/80 15's on the rears to get the top end back up.
Speedos easy, just run a GPS and then put small markers such as red tape V's where the key speeds are, no need to re calibrate TBH.
May turn the rears down a touch if it lifts her up to much, but should only be 10-15mm higher so nice nose rake if anything.
Memberstevedel
Threads: 6
Mood: Loving Life
posted on October 21st, 2011 at 06:52 AM
Initially I had the low profiles all round, and found I was wringing the neck out of the 1600 motor to get anywhere, that's when I swapped the rear tyres out to the 60 profiles. Since I had the motor rebuilt I was revving to 3250 - 3300 at 105kmh (GPS) but last week, had a new gearbox built as I couldn't stand the whine from the old one, and in the rebuild had 1800cc Kombi 3rd and 1600cc Kombi 4th (.82) included. Dropped the revs by about 250rpm, doesn't sound much, but very noticeable on the highway, (engine pitch). The ratios are fine for the motor, as it has loads of torque and the gap between gears isn't really noticeable.
Speedo, even though it has been recalibrated is still about 5% low when compared to GPS readout, which is technically within the Australian specs and a hidden safety measure! That's why when your driving around using your GPS as the speedo, everyone else is going that bit slower than you. They are probably sitting on the speed limit by their speedo, even in the newer cars. My brand new Golf GTD is around 5% under. (110 GPS = 115-6 speedo!)
Memberhaz77
Threads: 6
posted on October 22nd, 2011 at 06:24 PM
Hats off to you steve,
Sounds like you've got it set up very nicely.
Even my 65's make it sound like its thrashing at 100k's so can imagine what the 45's would be like!!
Got my hands on a set of 175 80's now so will get them on this week, just checked online the 175 65's actually lost me 5.7% on my speedo so I guess the same on the gears and the 175 80's will add 2.5% which im sure will be fine as 1st and 2nd are short anyway!
No rev counter so I can only go buy the comparison charts, cant see why that cant work.
Membervlad01
Mood: Side ways
posted on October 22nd, 2011 at 08:49 PM
haha yeah my notch has 65 on it. I remember my mate (support lol) in his VY driving with me and he said after a while is there something wrong with the engine......No why? you driving slow like 100 not 110...... I was like.. wtf? it says im doing just over 70mph and the engine is screaming!
the small tires was like extra high ratio diff effectively :rolleyes:
so I bumped it to 77ish mph, geebus! engine going to scatter soon :spin:
71 notchback,
[ Queries: 40 ] [ PHP: 3.5% - SQL: 96.5% ]
