[ Total Views: 112842 | Total Replies: 107 | Thread Id: 91646 ]
 Pages:  1  2  3  4
Author: Subject:  The ultimate vw engine
MemberSides
A.k.a.: Dave Sidery
posted on July 20th, 2011 at 04:33 PM
I'm not convinced it's a Volksy engine at all... the size, weight and general "chunkiness" of everything... I reckon it's from a tractor or somethin (as in a tractor puller).
:D
Frikken awesome Rod... can't wait to see and hear it run !!!
My toys
MemberRodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on July 20th, 2011 at 05:24 PM
FRONT COVER
This is what the block looks like with the front cover installed . In the 3rd pic you can see that I have threaded a hole under the Pauter signature for a camshaft sync sensor for the Motec computer .
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
Membervlad01
Mood: Side ways
posted on July 20th, 2011 at 08:46 PM
thats a pretty serious looking drag engine.
71 notchback,
Memberian.mezz
Threads: 280
posted on July 21st, 2011 at 08:32 AM
ok what sort of fuel going in this ?? and how many litres needed to go do the 1/4 mile???
:lol::crazy::lol::crazy::lol:
MemberBeetleJuice
A.k.a.: Craig Paton
Threads: 37
posted on July 21st, 2011 at 10:13 AM
The engineering at Pauter is 2nd to none. Must be a pleasure to work on!:cool:
FringeDweller
posted on July 21st, 2011 at 10:25 AM
It uses a brass VW timing gear by the look of it.
Rod the stock crank in that comparison photo looks like the one that I traded in on the stroker for Davids bug.
MemberRodPenrose
Threads: 330
posted on July 21st, 2011 at 12:09 PM
BARRELS
Here are the large head studs installed . These will be torqued to 65 ft/lb's rather than the 28 ft/lb's on the vw studs . You can now see the difference in the one piece aluminium modular cylinder assembly when compared to the std vw unit .
MemberGovernor
Threads: 23
Mood: yes please
posted on July 21st, 2011 at 01:36 PM
Great looking engine but a question?, when do we stop actually calling it a VW engine as there are no parts in this made by VW??
Member13bwagon
Threads: 9
posted on July 21st, 2011 at 06:05 PM
yeah that is true there is not stock or moded vw parts
and the same goes for a lot of bug engines not one bolt is vw
Originally posted by matara
Looking forward to reading about this build! 1000hp is Veyron territory in a Beetle!!!
Good luck with the build Rod
yes but it will be way lighter then the veyron !
BUY A REAL BUG A PRE S BUG...
MemberRodPenrose
Threads: 330
posted on July 21st, 2011 at 06:20 PM
Here are some pic's with the cylinders installed . The cylinders are installed first and then the piston and rods are installed as one unit as in a conventional engine . In the first pic I have placed a std 1600cc piston in the cylinders for a comparison . Notice how the top of the cylinders are flat and not inserted into the head like a vw cylinder . If you look close , you will notice a small groove on the top of the sleeves . This is machined here because the heads have a steel oring on them that will actually push the copper head gaskets intothe top of the cylinders to create a better seal . The system has been proven at over 50 psi boost .
posted on July 22nd, 2011 at 04:16 PM
I can spot 2 genuine VW parts
the cam lobes are nice
MemberWired1
Threads: 4
Mood: Curious
posted on July 23rd, 2011 at 09:41 PM
How do you cool the cylinders? or is it only for short runs?
Awesome, goes without saying.
1974 beetle - 1967 baja project - 1963 beetle project
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on July 23rd, 2011 at 10:08 PM
Dizzy drive and the brass gear ??
Memberfullnoise
Threads: 103
Mood: Middle of the road.
posted on July 23rd, 2011 at 10:09 PM
You are mad. But in a good way.
I am speechless. Some would argue that's good too.
We're not worthy, we're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy e're not worthy
esratrams
posted on July 23rd, 2011 at 11:13 PM
Brass drive and circlip
I reckon there are 5 more, unseen though.
MemberGovernor
Threads: 23
Mood: yes please
posted on July 25th, 2011 at 09:35 AM
What ever it's called you would have to change the title as it's not a VW engine.
MemberStanley
Threads: 270
posted on July 25th, 2011 at 09:47 AM
here we go
MemberSides
A.k.a.: Dave Sidery
posted on July 25th, 2011 at 10:46 AM
What's the line that JVL normally throws in about popcorn ???
:lol:
Keep the pics coming Rod... hopefully no veil of secrecy coming down on this baby as Warwick gets closer !!!
My toys
MemberRodPenrose
Threads: 330
posted on July 25th, 2011 at 07:31 PM
O'RINGS
Here in these pics you can see how the sump has been machined with a groove for an o'ring seal . The base of the cylinders are also machined for an o'ring so no sealant is required . You can also see a pic of the piston and rod assembled and ready to be installed into the cylinder . I have had a venturie ring made to the size of the bore to make the piston easy to install .
MemberRodPenrose
Threads: 330
posted on July 25th, 2011 at 07:37 PM
HEAD GASKETS
In these pic's you can see the one piece .040 copper head gasket . You can also see the steel o'ring in the head that will push the head gasket into the barrel groove .
MemberVolksVair
Threads: 32
posted on July 25th, 2011 at 07:45 PM
Its going to need one hell of a tuff drive train to transmit all that HP to the ground, thats one sick puppy, I am enjoying this assembly, thankyou
Adventure Before Dimentia
MemberPaulc1964au
posted on July 25th, 2011 at 08:00 PM
Rod,
Looks awesome so when are you planning installing it in my car since you have it at the moment :)
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on July 25th, 2011 at 08:53 PM
here we go
My thoughts exactly Stanly. Who cares what engine it is!!! Its based on a VW engine, Its going in a VW based car and will be way better than any thing most of us can ever imagine building!!!! Lets cut all the crap and just look at the photos and read Rods posts. Sorry Rod couldnt help myself:grind::grind:
MemberCamo
A.k.a.: Kev
Threads: 209
posted on July 26th, 2011 at 08:41 AM
Rod,
is there a steal o-ring that goes on either side of that copper head gasket, I just cant see in the photos ??
Kev
MemberSides
A.k.a.: Dave Sidery
posted on July 27th, 2011 at 09:54 AM
btw - possibly a dumb question Rod... but is this the actual assembly of the engine we're seeing, or are you just test fitting parts at this point ???
My toys
posted on July 28th, 2011 at 08:38 AM
Keep smiling Rod
Those V8 comparisons.....at least the crank, heads and most of the components will 'fit' a production engine. Not the case with the Pauter. Vw based, yep all the way for me. VW....well not much really, but lets face it, who can make 1000hp from a 1600 with a mag case????????
Thanks for sharing the build Rod.
MemberDaveCarter
Threads: 16
Mood: has the super bug
posted on July 28th, 2011 at 02:09 PM
This thing is ridiculous. Can't wait to see it in action at Warwick
MemberRodPenrose
Threads: 330
posted on August 3rd, 2011 at 08:54 PM
I have been waiting on some more fittings to arrive as I have confirmation from the guys @ Pauter to redesign the oiling system to suit my specific needs . The fuel that I will use will be methanol with a shot of nitrous oxide/sunoco racing fuel for some extra kick . This engine only uses 1 genuine VW part , that being the brass distributor drive gear on the crankshaft , and even that has to be modified . I still call it a VW engine as it will bolt to any VW transmission , and with a bit of machining the crank could be installed into a std case , the cam could be used and almost every other part as well . The engine is going together for the final time and when the new components arrive I will continue with the assembly . I have also ordered the new components from Lenco that will allow me to monitor the clutch slippage . I also need to mount the vacuum pump , alternator and the strater motor that is mounted from the engine side now , ROD.
MemberRodPenrose
Threads: 330
posted on August 25th, 2011 at 08:35 PM
LIFTERS AND PUSHRODS
I have received the parts I have been waiting for and can now finish the final assembly . Here is a comparison between a std VW lifter and the Pauter roller lifter . In the last pic is a std VW pushrod and the Pauter dual tapered moly unit .
MemberRodPenrose
Threads: 330
posted on August 25th, 2011 at 08:40 PM
PUSHROD TUBES
Here is the Pauter aluminium pushrod tube . It is a 2 piece spring loaded deal that can be adjusted to suit any width engine by re-positioning the circlip in a different groove . These use a std type 1 seal at the engine end , and a larger t3 seal in the centre and head end .
 Pages:  1  2  3  4
[ Queries: 40 ] [ PHP: 4.2% - SQL: 95.8% ]
