| [ Total Views: 2938 | Total Replies: 43 | Thread Id: 93465 ] |
| Pages:  1  2 |
|  stifler001
A.k.a.: Brad
Threads: 15
Theme:  UltimaBB Pro Blue ( Default )
| posted on November 29th, 2011 at 07:21 PM |  |  |
 Hi again, looking for advice on these webers yet again. So I have the manifolds mounted and the webers now fit great (after I replaced the old fan
housing) with the chokes on, but I wanted to check a couple of things. As mentioned previously in this post i got the webers off a mate of mine who
had them on a gemini and one of the carbys has a straight through fuel line (as they were mounted side by side), can i just put some hose on one end
and block it off or does there need to be a primary carby?
 Also it seems to have vacuum outlet or maybe they're return fuel out lets (don't know too much about them) do I need to run a return line from these
carbys? Anyone with photo's of a wbers setup on a type 1 would be much appreciated (as much detail as possible please).
 Thanks in advance
 Brad
|  Camo
A.k.a.: Kev
Threads: 209
| posted on November 29th, 2011 at 08:07 PM |  |  |
 Sorry, but can I conform that the webers when on the Gemini were not side draft webers.  As I think you are now setting them up as down draft.
 Sorry if mentioned earlier.
 Kev
|  Gracey
Threads: 17
Mood:  Itchy
| posted on November 29th, 2011 at 08:28 PM |  |  |
 All the Gemini's I've seen with weber's had IDF downdrafts, this I believe, was due to there not being enough room for side draft weber's.
|  Gracey
Threads: 17
Mood:  Itchy
| posted on November 29th, 2011 at 08:34 PM |  |  |
 | Quote: |  | Originally
posted by stifler001 Hi again, looking for advice on these webers yet again. So I have the manifolds mounted and the webers now fit great (after I replaced the old fan
 Thanks in advance
 Brad
 As far as the fuel inlet/outlet goes, you can either block it off as you suggested or you can run one fuel line from the pump straight to that carb
and then a fuel line from that carb to the other carb.
|  stifler001
A.k.a.: Brad
Threads: 15
| posted on November 29th, 2011 at 09:15 PM |  |  |
 they are down drafts Camo. Thanks Gracey, I am still confused about the other outlets (i think they are returns)
|  Gracey
Threads: 17
Mood:  Itchy
| posted on November 29th, 2011 at 10:16 PM |  |  |
 Can you take a picture of them, that might make it easier for people to answer the above question.
|  stifler001
A.k.a.: Brad
Threads: 15
| posted on December 1st, 2011 at 05:56 PM |  |  |
 ok so here you can see the pipe at the base of the carby, i think it is a vacuum line, any thoughts?
| Error |
| Sorry, you must be a registered user in order to download attachments. |  |  |
|  stifler001
A.k.a.: Brad
Threads: 15
| posted on December 1st, 2011 at 05:57 PM |  |  |
 and here you see the straight through fuel line and the return
| Error |
|  Gracey
Threads: 17
Mood:  Itchy
| posted on December 1st, 2011 at 07:09 PM |  |  |
posted by stifler001 ok so here you can see the pipe at the base of the carby, i think it is a vacuum line, any thoughts?
 Looks like a vacuum port, I'd say these carbs probably came off an Alfa or a Fiat as original equipment.
 Just put a rubber cap on it and forget it.
|  Gracey
Threads: 17
Mood:  Itchy
| posted on December 1st, 2011 at 07:18 PM |  |  |
posted by stifler001 and here you see the straight through fuel line and the return
 It's not really a return, it's just there to make it easy to connect the fuel lines up when the carbs are set up in line, like on an inline 4
cylinder. You just connect the fuel line from 1 carb to the other.
 You can connect it up like that on your dub, 1 line from the pump to this carb and then a line from carb to carb, or you can just use a tee piece
after the pump and then block the outlet on the carb pictured.
|  stifler001
A.k.a.: Brad
Threads: 15
| posted on December 1st, 2011 at 09:40 PM |  |  |
 thanks for that! I spoke to a guy tonight who told me to cut the fuel pipes off and hammer a lead slinker into them to seal them. will that work, is
it worth it?
|  matberry
Mood:  enjoying waving at all my Kombi buddies from my T3
| posted on December 1st, 2011 at 11:08 PM |  |  |
posted by stifler001 cut the fuel pipes off and hammer a lead slinker into them to seal them. will that work, is it worth it?
 Crikey, a bit rough!!! Remove the barb and tap a thread and seal with a threaded plug might be a little more reliable.
|  stifler001
A.k.a.: Brad
Threads: 15
| posted on December 2nd, 2011 at 06:27 AM |  |  |
 thanks matt, I thought it sounded a bit rough
|  Klaus
Threads: 100
Mood:  Heavily modified
| posted on December 3rd, 2011 at 12:26 PM |  |  |
 check your emulsion tubes aswell f11 is what you want you might have a f57 in those carbs if they were on a gem , gemini's had single or dual side
draught, manifolds are crap.. too many bends as i have a few off them , and as mat said plug the side holes, looks like they are early carbs with cam
pump jet set up
| Pages:  1  2 |
