[ Total Views: 6759 | Total Replies: 126 | Thread Id: 9392 ]
 Pages:  1  2  3  4  5
Author: Subject:  Spyder gets a rebuild*update..USDM STI 2.5 engine build 12/02/06
Memberspeedster356
A.k.a.: Peter Mcleod
Plastic not Classic Racing
Threads: 256
posted on October 1st, 2003 at 05:17 PM
Gearbox complete and ready to be mated.....
http://www.petermcleod.com/aussie/blu8.bmp
[Edited on 15-4-2004 by speedster356]
MemberAdam_C
Threads: 164
Mood: could be lower
posted on October 1st, 2003 at 11:17 PM
hahahahah i know pete . . . . jokes :P
that is going to be one hot replica . . . . fast bastard at that!
we need more pics!!
Adam
Adzslick@iprimus.com.au
MemberBoozer
Demented But Determined
Threads: 129
Mood: What the crap?
posted on October 2nd, 2003 at 08:11 PM
nice!:D:thumb Very clean unlike mine. that thing's gonna scream along when you're done! good job!
Memberspeedster356
Threads: 256
posted on December 30th, 2003 at 10:21 PM
Well the little EA82T engine has been sold to a guy in Adelaide and I'm picking up an EJ20T for the Spyder. Happy days!!! more power.........
posted on December 31st, 2003 at 06:06 AM
Did it fit in the box OK ???
Memberspeedster356
Threads: 256
posted on December 31st, 2003 at 11:43 AM
All packed and GONE......
Memberspeedster356
Threads: 256
posted on March 15th, 2004 at 01:58 PM
Been a while, but the WRX manual 1/2 cut arrived today from Brisvages. Let the fun begin. Engine and gearbox mounts are the same as the old unit, just have to convert the gear linkage on the g/box from rod to cable which looks to be a simple job using the existing Spyder bellcrank/cable system. The wiring is going to give me the shi...s but I'm running the original ECU and pollution gear..(boring) so it's just a matter of unpicking the loom and pulling the right wires. Easier said than done I think!.
It's a race against time to have it ready for Nambucca.
posted on March 15th, 2004 at 07:20 PM
Yep we can do that n we aint even electrickery people.
Memberspeedster356
Threads: 256
posted on March 15th, 2004 at 08:20 PM
Spent a few hours on the cut tonight. Engine and gearbox all disconnected and ready to pull. Spent most of the time diconnecting wiring loom plugs and pulling the dash to get access to the rest. There are a LOT of wires there.......
Tomorrow evening:
Pull engine/gearbox, steam clean, remove power steering pump and A/C.
Replace throwout bearing and spigot bearing on clutch and flywheel.
Pull twin spot front brake calipers and rotors. (anyone need a set?) rotors need replacing.
Remove rest of loom. :)
Memberspeedster356
Threads: 256
posted on March 23rd, 2004 at 08:42 PM
Was a black WRX.
Lots of wire in these things.
http://www.petermcleod.com/aussie/blu9.bmp
Memberspeedster356
Threads: 256
posted on March 23rd, 2004 at 08:43 PM
New cable shifter system.
http://www.petermcleod.com/aussie/blu10.bmp
Memberspeedster356
Threads: 256
The cat and O2 sensor need to be modified a small amount.
http://www.petermcleod.com/aussie/blu11.bmp
Memberspeedster356
Threads: 256
posted on March 23rd, 2004 at 08:46 PM
The intercooler sits high so I'll either fit an aftermarket one or adjust the mounting on the original so it sits under the 2 rear grills. The original is pretty small and being pushed for nice fresh air in the Spyder an aftermarket one might have the better legs.
http://www.petermcleod.com/aussie/blu12.bmp
Memberspeedster356
Threads: 256
posted on March 24th, 2004 at 05:23 PM
New engine mount blocks made. Should raise the engine by 25mm.
http://www.petermcleod.com/aussie/blu13.bmp
Memberspeedster356
Threads: 256
posted on April 1st, 2004 at 09:39 PM
Modified loom arrived today from Brisvegas, thanks to Al from Sunspares Subaru. See post in conversions section for info on Subaru loom service. Top job done by Al.
I just have to lengthen a few wires that go to the Subaru gearbox for the VSS and reversing light switch. The ECU sits nicely behind the passenger seat.:thumb
Memberspeedster356
Threads: 256
posted on April 2nd, 2004 at 12:00 AM
The radiator and twin electric fan setup, pulls air from the bellypan.
http://www.petermcleod.com/aussie/blu14.bmp
Memberspeedster356
Threads: 256
posted on April 2nd, 2004 at 12:08 AM
Fitting a thru the hood fuel filler and reproduction 550 (home made not store bought) hood locks.
http://www.petermcleod.com/aussie/blu15.bmp
Memberspeedster356
Threads: 256
posted on April 2nd, 2004 at 06:35 AM
This is the VSS (Vehicle Speed Sensor) supplied by Sunspares
that did the loom. It screws into the Subaru box speedo drive, it comes off Aust delivered Libertys.
http://www.petermcleod.com/aussie/blu16.bmp
posted on April 2nd, 2004 at 01:44 PM
Did raise it to clear the sump? Sharpbuilt is doing a nice alloy shortened sump for subies.
1302Steve
Memberspeedster356
Threads: 256
posted on April 2nd, 2004 at 04:00 PM
Raising the engine 25mm gave me a bit more sump clearance and allowed the header to be fitted a lot easier. Wires...wires ...wires and more wires. Guess what I'm doing at the moment?
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on April 2nd, 2004 at 04:33 PM
1302Steve
I've heard a bit about these but never seen one. I've spoken to Mike about them and I didn't think they were finished yet?
You wouldn't happen to have any pictures or something? What's the latest?
Mike
[Edited on 2-4-2004 by MikeM]
Memberspeedster356
Threads: 256
posted on April 2nd, 2004 at 09:46 PM
Do you know if they are cast or fabricated?
Memberspeedster356
Threads: 256
posted on April 14th, 2004 at 08:52 PM
Exhaust just about complete.
http://www.petermcleod.com/aussie/blu17.bmp
Memberspeedster356
Threads: 256
posted on April 14th, 2004 at 08:53 PM
spaghetti anyone?
http://www.petermcleod.com/aussie/blu18.bmp
Memberspeedster356
Threads: 256
posted on April 22nd, 2004 at 09:37 AM
There is an engine in there...I think!
http://www.petermcleod.com/aussie/blu19.bmp
MemberChe Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
posted on April 23rd, 2004 at 12:57 AM
dammit why do u have to have all the cool cars!
Jon
MemberThe_Bronze.
A.k.a.: Bronze
Minister of Volkswagenism
Threads: 238
Mood: Enlightened.
posted on April 23rd, 2004 at 03:36 AM
Green Voyer
Following with envy. Awesome :cool:
The Bronze.
[size=4]Bronze.[/size]
Memberspeedster356
Threads: 256
posted on April 26th, 2004 at 03:25 PM
Yeahhhhhh, finished the cable shifter today. Just need to adjust it a small amount as it seems to be a bit stiff shifting into 5th and reverse. It might be the bellcrank length.
http://www.petermcleod.com/aussie/subi60a.jpg
:thumb
Memberspeedster356
Threads: 256
posted on April 27th, 2004 at 07:35 PM
Wiring will be complete tomorrow after I do a small loom for the 2 radiator cooling fans and the 1 intercooler fan. Do you think I can use an old mechanical temp switch (bulb type) from a radiator setup to switch the intercooler fan? will it work on air temp if I slip it in the IC inlet ?
Memberspeedster356
Threads: 256
posted on April 28th, 2004 at 07:45 PM
Yehaaaa, another milestone, I've mastered the dark art of auto electrickery. All fans are working as they are supposed to, well at least the radiator twins with a forced earth switching signal from the ECU. The car has not running so there is no temperature to signal the relays from the computer. The fans are "twin brush" so I'm running one set of brushes of each fan from one relay and the other set of brushes from the other relay, this means there will be some degree failsafe if one circuit goes down.
I'm happy........:thumb
 Pages:  1  2  3  4  5
[ Queries: 40 ] [ PHP: 11.1% - SQL: 88.9% ]
