| [ Total Views: 2076 | Total Replies: 44 | Thread Id: 95424 ] |
| Pages: 1 2 |
kombibob
Threads: 173
Mood: at by cows
| posted on February 23rd, 2012 at 05:50 PM |
lee i think you should go with two blue nuts a red shaft and paint the inside of the fan hole pink.
would look great.
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
vlad01
Mood: Side ways
| posted on February 23rd, 2012 at 06:03 PM |
| Quote: | Originally
posted by D-train
Lee, do u have a special lube u use for less friction? Do u also find if u don't use any, does it make it harder to screw it in?
yeah it can feel a bit dry when screwing in if you don't lube the shaft first, also good idea to get your fingers inside and lube up the hole before
you insert the shaft.
71 notchback,
kombibob
Threads: 173
Mood: at by cows
| posted on February 23rd, 2012 at 06:06 PM |
also lee i find if the hole is flogged out turn it around and put the shaft in from the rear
but make sure you use the lube or you will flog out the rear also.
hope this helps
1961 swb buggy
1960 karmann ghia
D-train
Threads: 40
| posted on February 23rd, 2012 at 06:35 PM |
| Quote: | Originally
posted by vlad01
| Quote: | Originally
posted by D-train
Very good information, finger the hole with lube as well.. It should penetrate easily then, an wont be tight or hard to screw.
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on February 23rd, 2012 at 06:42 PM |
haha, then that fan will blow nicely
(ô_!_/ô) (ô_!_/ô)
69' baja: kombi box, thing spindles, irs, disc front, type 3 rear drums, 2 inch lift kit, 31x10 rears.
D-train
Threads: 40
| posted on February 23rd, 2012 at 07:01 PM |
| Quote: | Originally
posted by bajachris88
Yes it will blow all over the engine then.
Klaus
Threads: 100
Mood: Heavily modified
| posted on February 23rd, 2012 at 07:46 PM |
and dont forget safety glasses and a hat as it may blow something in your eyes or hair
kombibob
Threads: 173
Mood: at by cows
| posted on February 23rd, 2012 at 07:48 PM |
or your mouth!
you wouldn't want it to blow in ya mouth.
1961 swb buggy
1960 karmann ghia
vlad01
Mood: Side ways
| posted on February 23rd, 2012 at 08:05 PM |
| Quote: | Originally
posted by kombibob
or your mouth!
now hang on there son, I think you went too far this time.
71 notchback,
byronbus
dsk
Threads: 119
Mood: dsk founder
| posted on February 23rd, 2012 at 08:06 PM |
I wax my nuts, i find it a cleaner surface... lube is good as well, but not on your nuts, although when waxed they are very smooth...
kombibob
Threads: 173
Mood: at by cows
| posted on February 23rd, 2012 at 08:09 PM |
| Quote: | Originally
posted by vlad01
| Quote: | Originally
posted by kombibob
or your mouth!
what?... sorry if you found that line hard to swallow
1961 swb buggy
1960 karmann ghia
Joel
| posted on February 23rd, 2012 at 09:55 PM |
Smutty thread is smutty....
Look what you started Lee.
vlad01
Mood: Side ways
| posted on February 24th, 2012 at 12:43 PM |
yeah Lee , you and your crazy yellow nuts!
71 notchback,
D-train
Threads: 40
| posted on February 24th, 2012 at 01:44 PM |
| Quote: | Originally
posted by vlad01
It's a good thing he didn't have blue nuts
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
| posted on March 4th, 2012 at 04:44 PM |
Try shaving the nuts for a smoother nstallation.
| Pages: 1 2 |
