[ Total Views: 1518 | Total Replies: 31 | Thread Id: 96258 ]
Author: Subject:  Performance single port - worth the worry?
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on April 11th, 2012 at 05:27 PM
Originally posted by psimitar
also, the quality of new ))('s is completely shite compared to the original 009's of the 70-80's.
Even so, for a road engine they are just plain crap. Even a twin carb can be made to use the vac dizzy properly and give much better drivability. A lot of people are lazy when they get twin carbs and can't be arsed doing the job properly or have been told the 009 is awesome and so they just whack one in there :(
Do you have any info on modifying Kadrons for vacuum?
It's something I've been meaning to do for a long time, but as you stated I've been lazy :blush:
I've heard of modifying for vac but have no idea what's involved.
Smiley :)
Memberpsimitar
Threads: 148
posted on April 11th, 2012 at 07:00 PM
Smiley :)
Hmm, try search the samba or Volkszone forums as those guys have done pretty much everything you can think of to VW's. Some guys even built a twin scroll turbo VR6 4WD powered Caddy. Runs MegaSquirt and fully self fabricated. Mental :)
As for my knowledge of it. The vac signal needs to come from above the throttle plate but not sure if it's just anywhere or whether it needs to be near the leading upward edge of the throttle butterfly for correct vac signal. On the Kadron there may be a boss near the throttle plate that was originally meant for a brass tube to be drill and fitted. I had 34 ICT's on my old 1600 and these already had a vac can take off.
Let me know how you get on with the research :)
