| [ Total Views: 3472 | Total Replies: 35 | Thread Id: 96498 ] |
| Pages: 1 2 |
snitz
Threads: 37
Theme: UltimaBB Psyche Red
Mood: "Bug"gered
| posted on December 2nd, 2012 at 09:38 AM |
So hows it running after the valve clearances have been done and new plugs?.Im running a CB Performance pump thats 2-4psi I think.It was recommended
to me by Rod Penrose to replace my Crappy one from CIP1.Its a pump with with a set pressure for carbs and comes with an inline filter.I changed to an
electric to keep by engine looking clean but was recommended to stay with a stock pump.Ring Rod Penrose direct for the pump or PM him.regards Jason
Sbug 71
Threads: 32
| posted on December 2nd, 2012 at 01:53 PM |
It's runnung sweet right now but time will tell. I'm hoping it stays that way cos I'm sick of changing plugs. If they keep fouling up I might
consider stepping up a heat grade in plugs and hope that solves some of my woes.
Thanks Snitz for the info about the fuel pump. I'll look into it. Cheers Mate.
Klaus
Threads: 100
Mood: Heavily modified
| posted on December 2nd, 2012 at 05:03 PM |
have the float levels been checked as every set of hpmx's I've pulled apart are way of the mark for what is required , stock pump should be fine
..what size jets and how many turns on mixture screws ? are the idle bypass screws all the way in ?
snitz
Threads: 37
Mood: "Bug"gered
| posted on December 2nd, 2012 at 05:14 PM |
Good to hear its running sweet now..hope it give you some trouble free motoring.Did Peter do the valve clearances etc?.Need to get ours back to him
soon..
Sbug 71
Threads: 32
| posted on December 6th, 2012 at 07:44 PM |
The float levels were way out. The guy took a photo to show me before he adjusted them. When he finds issues with carbys and other components, he
tends to take photos for his records and future reference.
Main jets increased from 115 to 125, air correctors reduced from 200 to 185. This improved the power mixtures from 3.9 to 5.8% CO. Cruise mixture is
now 0.7% CO. Idle jets reduced from 5.5 to 4.8%. Idle mixtures improved from 11% to 8.5% on light to mid throttle. I think this is still on the the
rich side though. Don't know how many turns on the mixture screws, haven't tried to count them or check the idle bypass screws.
So it lasted about 50-100 miles with new plugs before started to miss and backfire again. It's a lot better than it was but still not 100%. I guess
I'll try hotter plugs next but only got about 200 miles tops out of last 2 sets of iridium plugs.
I got volksfactory to do the valve clearances. They're close and easier to get to.
RestoKäfer
Threads: 14
| posted on December 9th, 2012 at 08:16 AM |
So you havent been to west torrens dyno then ?
| Pages: 1 2 |
