| [ Total Views: 13007 | Total Replies: 56 | Thread Id: 99066 ] |
| Pages: 1 2 |
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on October 7th, 2012 at 04:20 PM |
A 'Scotch key' at each end of the rotor may be worth thinking about, Steve.
steve burgess
Threads: 10
Theme: UltimaBB Vintage
| posted on October 7th, 2012 at 05:59 PM |
| Quote: | Originally
posted by HappyDaze
Yes well done greg,butto late the shaft and rotor are one,will upload photos later all went well.To incoropate scotch keys i would have designed it
slightly different ie. the shaft would have a larger centre dia. so i could drill for the pins.If this one fails i will do that.Thanks Steve
1956 judson supercharged oval
1975 kombi camper
1976 kombi panel van
steve burgess
Threads: 10
| posted on October 8th, 2012 at 06:56 AM |
The rotor has been bored for a good interference fit.I heated the rotor in the oven as hot as it would go for 1hr & the shaft was put in the
freezer for the same period.Also i heated the rotor with mapp gas but it did not quite fit 1st time round.I would hate to get it stuck half way.The
rotor was put back in the oven for another 1/2 hr.and shaft in freezer.
Next time it was success as the rotor slid all the way home and instantly struck,it took another 3 hrs to cool before i could pick it up.I feel very
confident that this will work ok,
but may see if i can put in a scotch key as Greg suggested.
Onto machining the outside dia. of rotor ,this is the easy part and i love machining aluminium because it is so soft and the finish is great.I will
close up the tolerence a bit by making the outside dia. .5mm larger because of the wear in the body and material remove during honing.Also the end
gap i will close up to .3mm it is .3 at one end and .6 at the other on the old rotor.Next will be to machine slots this will take some time as they
are deep.
| Error |
| Error |
| Error |
1975 kombi camper
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
| posted on October 8th, 2012 at 05:52 PM |
You are doing a fantastic job!!
I love your 'get to it' attitude.
Rotor is buggered you say? I'll just whip a new one up!!
Keep at it!
Smiley
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on October 8th, 2012 at 06:15 PM |
You're spot-on there, Smiley. Steve's ignored the 'knockers', and just taken on a job that's not for the faint hearted. Pity there arn't more
out there with his attitude. Good on him.
matberry
| posted on October 8th, 2012 at 06:51 PM |
^^ yep, his oval is absolutely sweet as, and he did EVERYTHING himself.
steve burgess
Threads: 10
| posted on October 8th, 2012 at 08:16 PM |
Thanks guys for the encouragement it means a lot to me .Have started cutting the slots in the rotor it is slow going as i only have a small mill but
so far have cut 3 without a stuff up,it would be a bastard to stuff it up now.Iam using a 3/16" thick(same thickness of new vanes) slitting saw i
bought of ebay cheap ,it was blunt and would not even cut the aluminium so i made a jig on my bench grinder and sharpened it.I was going to use a end
mill or slot drill originally but could not get one long enough.
First photo is tramming the rotor to get it parallel to the cutter.
Second is the slitting saw iam using
| Error |
| Error |
1975 kombi camper
steve burgess
Threads: 10
| posted on October 9th, 2012 at 07:27 AM |
Have learn't how to put a link in (pretty slow huh) This is a good read if you own a Judson and is the reason i pulled mine apart.
http://vwjudsonregister.tripod.com/jms_case_history.htm
1975 kombi camper
vw54
| posted on October 9th, 2012 at 08:03 AM |
yep good read
the rotor is coming along great do you have new vanes
steve burgess
Threads: 10
| posted on October 9th, 2012 at 08:58 AM |
| Quote: | Originally
posted by vw54
yep good read
| As they were over size vanes installed i am hoping to be able to mill them down to size as they where not too badly worn.I have
researched other materials and there is far better materials available now.I will have to look back through my notes,but can remember that it was
about $350 for enough material to make 4 vanes.I will be away for a few days as my wife is on holidays,weather is great so off to double island pt
fishing.
1975 kombi camper
steve burgess
Threads: 10
| posted on October 11th, 2012 at 01:58 PM |
I have finished machining the rotor,iam confident it will not slip on the shaft as i have a good interference fit but to be safe i have installed 2
scotch keys as Greg suggested.But instead of driving a pin in ,i have drilled and tapped 4mm grub screws with red locktight.( if i was to make
another one i would make the center of the shaft a larger dia.).
Now onto machining the vanes.It was fitted with 1/4" oversize vanes and i hope to be able to machine them to 3/16" which is the standard size.
| Error |
| Error |
| Error |
1975 kombi camper
snitz
Threads: 37
Theme: UltimaBB Psyche Red
Mood: "Bug"gered
| posted on October 11th, 2012 at 02:14 PM |
Awesome work!!...
steve burgess
Threads: 10
| posted on October 11th, 2012 at 07:03 PM |
The vanes have been machined and are a sliding fit in the slots.I will soak the vanes in Marvel Mystery Oil overnight (read somewhere to do it,plus
can't hurt).
Picked up new bearings and seals from CBC today (were in stock)the old bearings and seals looked and felt ok,but new is better.All to do now is
assemble which is straight forward.
| Error |
| Error |
| Error |
1975 kombi camper
Gracey
Threads: 17
Mood: Itchy
| posted on October 11th, 2012 at 08:30 PM |
Great stuff!!
Bizarre
| posted on October 11th, 2012 at 08:44 PM |
WOW
Absolutley unbelievable
Brillant work
steve burgess
Threads: 10
| posted on October 14th, 2012 at 07:56 AM |
Before i fitted new bearings and seals i faced off the end plates as they had a bit of scoring,this then meant i had to readjust the clearance of the
rotor.This was done by machining the spacer which is shown in picture #2
| Error |
| Error |
1975 kombi camper
steve burgess
Threads: 10
| posted on October 14th, 2012 at 08:19 AM |
Installed on car yesterday and fired her up,the difference is amazing i can actually here the motor run,before all you could hear was the supercharger
making a scraping noise (i was going to take it off because i could not stand it).Can't road test which is the real test(it is not reg. as have too
many regs. one day ) but should run ok as every thing is right.
Next is to make up the fittings and oil lines for the fram bypass oil filter,i know i can buy oil lines made up but I have the equipment and the
time.
Thanks for the support and encouragement guys.
| Error |
| Error |
1975 kombi camper
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on October 14th, 2012 at 11:40 AM |
That's a credit to you, Steve. Nice car, too......can we see more?
steve burgess
Threads: 10
| posted on October 14th, 2012 at 05:17 PM |
Thanks Greg,Have added a few of car ,i can only attach 3 photos at a time,will have to find out how to do more at once.
| Error |
| Error |
| Error |
1975 kombi camper
D-train
Threads: 40
| posted on October 14th, 2012 at 07:48 PM |
Awesome work steve, might get u to make me one when the time is right..
we had a chat at valla about mmo, where in briso was it stocked again?
steve burgess
Threads: 10
| posted on October 14th, 2012 at 08:05 PM |
| Quote: | Originally
posted by D-train
| Hi,Thanks for the comments,i have been watching your build also and yours is looking good.Here's a link to the oil
http://www.skyshop.com.au/shopdisplayproducts.asp?id=305&cat=lubricants
1975 kombi camper
Ian 68
Threads: 14
| posted on October 14th, 2012 at 09:11 PM |
Steve,
I'm a turner by trade and have to say I'm impressed with the quality of your work.
Good on you mate, brilliant work, if you ever need measuring equipment, give me a shout, I have it all here. Rick has my number.
Keep up the good work.
Ian
Hello, my names Johnny Cash...
steve burgess
Threads: 10
| posted on October 15th, 2012 at 06:47 AM |
| Quote: | Originally
posted by Ian 68
Steve,
Ian
| Thanks Ian,Rick has mentioned that you have a lot of tools etc.,I will take you up on that offer and if you ever need to use a small
lathe or mill , your welcome to use it.
1975 kombi camper
steve burgess
Threads: 10
| posted on November 2nd, 2012 at 11:01 AM |
A fram filter model no.F3-P was used on the 36 hp motors.
In keeping my oval period correct and seeing as the oval came with one .Iam going to make the fittings for it.
The oil outlet uses a t piece on the oil press. switch and returns through a hollow bolt on the dist. bracket.
| Error |
| Error |
| Error |
1975 kombi camper
steve burgess
Threads: 10
| posted on November 2nd, 2012 at 11:14 AM |
In keeping period correct i don't think fittings would have been made in aluminium as most are today.So i chose 4AN size and steel 1/8" npt x4an
fittings.The hoses are 4an stainless steel and came ready made at 24" long.
I machined the t piece out of hex and is 10x1 to suit oil press. gauge with 1/8npt for oil line.The return fitting i also made and it replaces the
stud that holds the dissy. A 2 mm hole is drilled through and a 4AN thread was machined on one end and 8mm thread on the other.
I also made another set while i was at it and is listed in the for sale section.
| Error |
| Error |
| Error |
1975 kombi camper
DieSchnelleKafer
Threads: 22
Theme: UltimaBB Pro Brown
Mood: hungry for metal
| posted on November 12th, 2012 at 07:25 PM |
so can you feel a power increase aswell? awesome job man.
steve burgess
Threads: 10
| posted on November 13th, 2012 at 07:51 PM |
| Quote: | Originally
posted by DieSchnelleKafer
| yes you can feel the extra power,and with the stock 36hp any improvement is welcome.
1975 kombi camper
| Pages: 1 2 |
