[ Total Views: 122442 | Total Replies: 1280 | Thread Id: 60666 ]
 Pages:  1  ..  18  19  20  21  22  ..  43
Author: Subject:  pimp'in the pan,it lives and dies only to be reborn again.
Memberwesti
what the
Threads: 28
Mood: not blue, pink
posted on June 17th, 2008 at 08:50 PM
cb studs 10mm
and yes yes yes for everything else
i think we have a washer problem.
we are just getting down to the heads know and it looks like a colapsed washer or two.
we will wait and see when we get down to it.
i will try to post up the vid's alittle later also.
down sharon.
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on June 17th, 2008 at 10:17 PM
Originally posted by dumone
Originally posted by LIFE IN THE LOW LANE
Are you running head gaskets at all?? Know of a few who don't run any at all..
don't know of any who do!
did you lap the barrels into the head?
what type/size/brand of head studs?
really shouldn't be a problem till you start running forced induction.
Lets just say that i was trying to get some copper head gaskets quite a while ago and went to a "Vw specialist" who stood there and argued with me that i don't need them if the compression isn't too high. Just lap the barrel into the head and tension to 28 foot pounds.
Needless to say I laughed at him and proceeded to say " I guess that's one way to get repeat business" then walked out and went somewhere else.
Memberdangerous
Mood: 591
posted on June 18th, 2008 at 05:01 AM
Head gaskets in a copper materials DO have a place , and a use in some VW situations,
but are not neccesary unless you need a specified deck height,
or are compenating for some other engine factor.
It should go without saying,
that if you choose to use them they should be located on their OD
to prevent being forced out.
I used them on one of my engines.
On my blown engine I used them as a "sacrificial lamb", and it saved my head a couple of times.
And yes, if my tune up was closer it would be un-neccesary.
Having everyting machined square including nut and washer surfaces,
as well as the case and head surfaces is normal procedure,
and Westi has all these bases covered.
When increasing the tension on head studs,
a thicker washer is a nice addition,
and I believe that is the path that Westi is headed.
Also "there is always time for lubrication".
You MUST use a minimum of oil on threads and nut faces.
I use moly paste or anti-seize.
The biggest cause of head seal failure (excluding machining error)
would have to be lean/poor tune.
The pressure spikes from detonation and/or preignition
far exceed any normal forces that should occur.
In fact any normal boost level (less than 50psi? whats normal?) , in CORRECT TUNE, would not reach the cylinder pressure of those nasty spikes.
Originally posted by westi
That's mad Alan.
posted on June 18th, 2008 at 08:08 AM
Thanks Dave for correcting us.
Guru Butler
Dangerous Muffin man....
My present engine is running 040" copper head gaskets as she has zero deck. End CR is 9.7 :1, but a bit more would be nice, but as a streeter, it'll have to do.
Good luck Westi...14:1 is certainly high, but sounds like you should be able to keep her together.
Memberwesti
what the
Threads: 28
posted on June 18th, 2008 at 09:23 AM
fucked washers.
gona pull her right down and have a good look over every thing.make sure she's all good.never built one this big before so it won't hurt to have a look see.
i have another cam i really want to try.hopefully all will be good.
it is a fk97 what do you reakon.
i will try post up those vids today or tonight.
down sharon.
Member063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
posted on June 18th, 2008 at 03:07 PM
...photos of the washers???
Man you are tolerant, patient and committed to success... keep up the good work :tu:
Membermactaylor
Mood: even my dog is german
posted on June 18th, 2008 at 05:48 PM
what washers are you using westi? cant imagine OE ones would fail like that, also what size nuts are you sporting!!!! also is he your fat controller or is he the fat controller.
EVERLAST CONCRETE TANKS
1800 552 123
Memberreub
VWRX is gone...
posted on June 19th, 2008 at 08:30 AM
Look what I found... :D ... nice :yes:
http://youtube.com/watch?v=ZNEfkS_0Iag
http://youtube.com/watch?v=4Vu-v7cw3as
Reub
Memberwesti
what the
Threads: 28
posted on June 19th, 2008 at 11:33 AM
cheers mate i think u missed a few
down sharon.
MemberStanley
Threads: 270
posted on June 19th, 2008 at 12:27 PM
kudos to your commitment westi....nice vids thanks
Can't wait to see a good pic in the daylight..
Memberdangerous
Mood: 591
posted on June 23rd, 2008 at 09:13 AM
All quiet in Westi town?
What did you do for studs/washers?
That's mad Alan.
Memberwesti
what the
Threads: 28
posted on June 23rd, 2008 at 10:06 AM
studs gone,washers gone.
started fresh with new.
pulled it down,to have a look see.
lifters all good
cam all good
bearings for crank all good
when i say all good i mean no unusual wear and tear so to speak.
rod bearings not all good
some one was on the piss when they shouldn't have been.
there was no bearing crush,but there was no problem with them yet, but there would have been in the near future i pressume.
so i am happy that i pulled it down.
all my bit's and pieces should be in buy the end of the week i hope ,so we will most likely be missing a few hours sleep between now and the dyno day.
i am going to stick the heads back on the bench.so i will take some footage show you what i have done.
other than that i have been flat out with customers stuff,
thanks for all the support boy's. still haven't heard a good plate sugestion yet.
down sharon.
MemberFlintstones
Threads: 69
posted on June 24th, 2008 at 12:04 AM
STRIPD as in its been stripped down to it's bare essentials all 686.5 kg's worth, or stripped naked showing off it's pink bits LOL:smilegrin:
posted on June 24th, 2008 at 08:15 AM
And STRIPD ie set up for the strip
I like
as long as you dont put stripes on it, could confuse the plebs!
Memberwesti
what the
Threads: 28
posted on June 24th, 2008 at 08:44 AM
i am not sold yet
down sharon.
Member063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
posted on June 24th, 2008 at 09:01 AM
"annorxic" - annorexic
"pwr2wt" - power to weight
"redy2fly" - ready to fly
"sprfly" - super fly
some are lame but they might aid discussion......
Member555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
posted on June 24th, 2008 at 09:09 AM
8ball
http://members.optusnet.com.au/s0411400342/555bug.jpg
MemberkombiPILOT
Threads: 0
Mood: floaty
posted on June 24th, 2008 at 10:05 AM
i know its not that tricky but how about "UFO" , Im shaw it looks like 1 flyin down the road in the early hours in the mornin....
One loud ass UFO !:starhit: ......Im shaw its probably taken anyway , my opioion is i would rather a new part or sum more
go go juice over a flash plate ... P.S really enjoyed keeping up with your build , you really keep us readers invovled
and hope to see more threads as good as this.... CHEERS !:smirk:
MemberStanley
Threads: 270
posted on June 24th, 2008 at 12:08 PM
Hey westi, by between now and the dyno day are you talking your dyno or are you coming up to dynomania?
Memberwesti
what the
Threads: 28
posted on June 24th, 2008 at 01:28 PM
dynomania my friend,but i do need to finish off the fine tunning before then.
thanks 063/555 they are some of the best ones so far.still not sold though.
ufo .naahhh.but nice try.
cheers for the nice comments .much appreciated.
down sharon.
MemberTurbo54
Mood: Boost'n
posted on June 24th, 2008 at 02:47 PM
Westi, how about 02COOLD?
T54
C'mon kids gather round,
Memberwesti
what the
Threads: 28
posted on June 24th, 2008 at 08:12 PM
not bad,pretty clever actually.still not sold yet.
picking a plate is harder than i thought.
i am waiting for just the right one.
down sharon.
posted on June 24th, 2008 at 08:28 PM
BADASS
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on June 24th, 2008 at 09:24 PM
SHTYEH (shit yeah?)
GDYUP (giddyup?)
you are right, choosing a plate is hard....I got nothin!
MemberLUFTMEISTER
Threads: 119
posted on June 24th, 2008 at 09:33 PM
AVW-WTF
A VW WHAT THE F@#K =)
Memberreub
VWRX is gone...
posted on June 24th, 2008 at 09:36 PM
JUNKA
Reub
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on June 25th, 2008 at 05:44 AM
NOREGO :smilegrin:
Memberrocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on June 25th, 2008 at 07:27 AM
VWESTI
Memberkoolkarmakombi
enkarmarising
Threads: 158
Mood: do you see the bats?
posted on June 25th, 2008 at 07:46 AM
BYEBYE
Member063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
posted on June 25th, 2008 at 09:57 AM
"snzulz" - snooze you loose
"sleeper" - grasping at straws
"roids" - steroids
"brn2run" - born to run
"help" - just being stupid :)
[ Queries: 40 ] [ PHP: 8.0% - SQL: 92.0% ]
