| [ Total Views: 285104 | Total Replies: 905 | Thread Id: 36521 ] |
| Pages: 1 .. 22 23 24 25 26 .. 31 |
BeetleBug
Threads: 0
| posted on September 9th, 2010 at 09:15 PM |
Nice!
T4 engine and add a Holset HX50 or a 55 into the mix, 35 - 40 psi of boost, E85, 11.50 - 12.00 AF and 20 dg igniton at full boost and you`re looking
at 550 - 600hp. This is the classic mix for the guys from Turbotown Sweden, all street cars with slicks when they have fun at the track. Better hang
on!
Some of the Swedish cars here for you`re inspiration; pay especially attention to the brown and while split at 4.30: http://www.youtube.com/watch?v=LpMqqJeq930&feature=player_embedded it managed a 9.3 pass with a lift in 3rd and 4th
because he started to drift.
Best rgs
BB
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on September 9th, 2010 at 10:52 PM |
WOW...this will be a weapon
Flintstones
Threads: 69
| posted on September 10th, 2010 at 09:16 AM |
Go the T4
what numbers are you hoping to get down the qtr Wayne?
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
| posted on September 11th, 2010 at 08:56 PM |
Wayne, now all you need are some modded Deutz cylinders that will not warp, let me know.
ben
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:03 PM |
progress a little slow for Warwick but still confident that we will make it. The engine for my oval is finished ( progress pics will follow ) the
transmission with all new ratios was assembled last night , or should I say this morning ( @2am ) and the axles brakes etc will be fitted tonight so
that the engine & trans assembly can be fitted.
Ben has also been very busy on his new supercharged engine and Chris has the turbo Vee ready to fire-up . All 3 cars will go to the dyno on tuesday.
| Error |
| Error |
| Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:05 PM |
measuring and calculating spring pressures
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:07 PM |
match porting heads to the exhaust flanges and the inlet manifolds to the heads
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:10 PM |
ports are polished for better flow
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:16 PM |
heads assembled with the 53 x 41 titanium valves , chevy tripple springs & titanium retainers . to gain a compression ratio of 9.7:1 I have had
machined a lower barrel shim of 3mm and an upper barrel shim of 6mm . At TDC the piston protrudes 2.5mm out of the top of the barrel . I have decided
to go this way as in the past I have been experiencing abnormal wear at the bottom of the cylinders as the piston had been hanging too far out of the
bottom of the barrel at BDC .
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:19 PM |
heads and barrels being fitted . The top barrel fins also had to be machined off for head clearance .
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:22 PM |
pushrod tubes , dual tapered pushrods and 1.4 roller rockers fitted
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 23rd, 2010 at 01:24 PM |
oringed inlet manifolds
| Error |
| Error |
Team
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on September 23rd, 2010 at 06:11 PM |
Looking Good Wayne!! Hopefully everything will fall into place for you this year without any drama's on the drive up at the meet or on the way
home.
Will pick your brain over the weekend for some big type 4 info as well.....
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on September 24th, 2010 at 11:46 PM |
so nice as always Wayne........great to see the updates, hit us with some more if you have the time please
good luck with the as per usual tight schedule
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:08 AM |
progress pics
transmission assembly
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:12 AM |
transmission assembly with the new gear ratios . 3.44 ring & pinion , 3.3 / 1.93 / 1.59 / 1.30 gear ratios , ZF lsd , chromemoly axles
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:15 AM |
the turbo oval has been dragged from the race shed where it has been collecting dust for the past 2 years
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:18 AM |
engine is fitted to the WPVW turbo oval
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:22 AM |
started to manufactured new turbo system . new injector rails manufactured as the old ones were found to be too small
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:26 AM |
speedflow race fittings for the new plumbing . new front wide-5 disc brake conversion kit . turbo system plumbing
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:31 AM |
painting the turbo system plumbing and a new set of wheelie bars to try and keep the front down when using the new slicks
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 30th, 2010 at 03:39 AM |
flywheel fitted to engine , today manufactured all the fuel lines , mounted fuel pumps and filters
| Error |
| Error |
Team
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on September 30th, 2010 at 06:50 AM |
Great stuff Wayne, make sure you drive safely on the way up given your late nights and lack of sleep!!
Can't wait to see the oval run again.
AL
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on September 30th, 2010 at 09:56 AM |
Great effort. Looking forward to the weekend.
Hope the last little gremlins leave you alone Wayne.
| posted on September 30th, 2010 at 09:15 PM |
Hope the trip to Warwick is a safe and uneventfull one.
Flintstones
Threads: 69
| posted on September 30th, 2010 at 11:32 PM |
Mammoth effort there Wayne, glad you got it finished in time.
Get someone to drive you up whilst your getting some shut-eye
All the best for the drags, looking forward to the results
D
Beetspeed
A.k.a.: Walter
Threads: 6
| posted on October 3rd, 2010 at 04:13 AM |
Wayne,
I noticed (correct me if I'am wrong though) that you paired cylinders 1/1 and 3/4 together into the divided (twin-scroll) turbing housing.
That is not the most efficient pairing for twin-scroll set up's.
I really think more power could be made with 1/3 and 2/4 pairing in a TS turbo set-up.
Very nice fabrication nonetheless!
'75 1303 'Renner' 2.2 T4 turbo
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on October 7th, 2010 at 08:22 PM |
WPVW turbo oval progress pics .
The turbo plumbing is painted and fitted to the engine . The clutch has been set up with 210lbs breakaway , and the engine is fitted to the oval . The
new fibreglass rear guards have been painted and a bunch of mates help assemble the back end of the oval .
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on October 7th, 2010 at 08:33 PM |
got the oval finished and on the dyno at 10-30pm Wedneday night . after 4 hours of tuning and adjustments the oval produced 348bhp @ the wheels on
just 15psi boost . An electrical breakdown at 6100rpm robbed us of the opportunity to put more boost into the oval tonight , but at 2-30am we should
get it back to WPVW so that we can get home for a couple of hours sleep before we pack , wash the oval in the morning and drive to Warwick....
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on October 7th, 2010 at 08:42 PM |
arrived safely at Warwick QLD for the VW drags . The oval has been washed , but the final detailing is handled by Lana-rose Bolton ( Chris' no.1
fan)
Eager to run the oval but it is raining . Fortunately I organised a marque for TEAM WPVW
| Error |
| Error |
| Error |
Team
