| [ Total Views: 122424 | Total Replies: 1280 | Thread Id: 60666 ] |
| Pages: 1 .. 23 24 25 26 27 .. 43 |
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on September 2nd, 2008 at 11:49 AM |
Vees now run a finned alloy sump extension to stop oil surge. Also extend the pick up down into the extension as Dave mentioned.
We are running Penrite mineral based oil in Troy's type 3. Once it has some K's on it we'll prolly switch to a semi synthetic.
mactaylor
Mood: even my dog is german
| posted on September 2nd, 2008 at 04:21 PM |
westi at least yours is bigger than dave's, 26mm vs 30mm.
EVERLAST CONCRETE TANKS
1800 552 123
Eeyore Freak
Threads: 3
Theme: UltimaBB Pro Pink
Mood: gloomy but sweet!
| posted on September 2nd, 2008 at 05:11 PM |
im glad you liked the canadian clubs. we wouldnt buy them for just anyone!
tell stocko that hes a funny bastard!!
my driving offenders course is going just grand by the way
Gotta love PINK BITS!
1959 Beetle (Eeyore)
1979 Kombi (Oscar)
byronmcmanus59
A.k.a.: Jono punton
Threads: 22
| posted on September 2nd, 2008 at 10:11 PM |
| Quote: | i have a tech
question though.were on the dipstick can you run the oil level so that there is minimal crank slap in the oil.
we noticed that the oil is airated quite a bit.so having a deep sump i thought i might be able to run the oil alittle lower.
what's your thoughts.
old mans says, first thing to work out is why your getting airation in your oil.. that shouldnt be happening. cause that causes cavitation in your oil
pump and oil surge issues.
Stanley
Threads: 270
| posted on September 3rd, 2008 at 07:20 AM |
cavitation and airation are to different things. Airation gives you an oil smoothy and ultimately poor lubrication where as cavitation is a result of
say having too small a pump inlet or blocked filter. This results in bubbles which implode and can actually start pulling metal out of the suction
side of your inlet.
Mick058
| posted on September 3rd, 2008 at 08:11 AM |
Can cavitation occur from the 'smoothy' effect though? If smoothy is aerated oil, then air within a pump will cause cavitation. I guess it depends
on how well the pump is being fed by the aerated water - gurgling etc...
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on September 3rd, 2008 at 08:37 AM |
We run Rods car about 5mm on dip stick from bottom but the motor has a 4qrt sump ,cooler,filter and oil is 10/30 mobil 1 synthetic . Volume is about
6ltrs .
westi
what the
Threads: 28
Mood: not blue, pink
| posted on September 3rd, 2008 at 09:32 AM |
thanks pagey,near the bottom line or 5mm above that.
down sharon.
Stanley
Threads: 270
| posted on September 3rd, 2008 at 10:27 AM |
| Quote: | Originally
posted by Mick058
No....cavitation is caused by negative pressure (sucking).Aeration and cavitation will both ultimately end in failure, however aeration will have an
affect almost immediately whereas cavitation takes some time to show up. The warning signs for each are slightly different. Aeration will show the
usual signs of lack of lubrication (blueing/galling) where cavitation shows up as contamination damage due to metal contamination from the erosion of
the pump at the inlet.
Aeration also shows up immediately with the "smoothy effect" whereas cavitation usually won't unless it's an extreme case.
I have seen cavitation so bad that it erodes hydraulic pumps to the point the inlet fittings fall out. Usually caused by dirty inlet filters or
inadequate suction line size.
Mick058
| posted on September 3rd, 2008 at 10:43 AM |
im just talking from a pump point of view, i haven't got the engine knowledge you lads have. I know that valving and blockages can cause cavitation,
inadequate suction lines but also air (depending on the other mentioned causes). A simple air bubble between an impeller and a one way valve can cause
cavitation and loss of prime - sorry, probably not quite related anyways
westi
what the
Threads: 28
| posted on September 3rd, 2008 at 12:42 PM |
cheers boy's for getting all technical on me.lol.
thanks for the help.
i am going to lower my oil level tonight and do some testing.lets see what happens,once this is all sorted it will finally be of to the dyno and then
the track.fingers crossed.
down sharon.
Eeyore Freak
Threads: 3
| posted on September 3rd, 2008 at 12:44 PM |
Kev will come and help. Hes always there anyway, allthough he never actually does anything.
A bit like stocko really
1979 Kombi (Oscar)
byronmcmanus59
A.k.a.: Jono punton
Threads: 22
| posted on September 3rd, 2008 at 07:14 PM |
yeah too true, but the aeration in the oil will be a large contributing factor, that will in term cause suction problems, and lead to cavitation..
which will destroy your engine. he's been working with performance and industrial engine for a good 30 years and has seen this many times.. most
ending badly
the point im trying to make/the question im asking is why is your oil aerating..?? thats bad
Eeyore Freak
Threads: 3
| posted on September 6th, 2008 at 09:49 AM |
its been a few dya ssince tour last post, so i thought id make it look beeter!!
when am i cummin 2 do bo????
1979 Kombi (Oscar)
mactaylor
| posted on September 6th, 2008 at 06:07 PM |
I wonder if that driving course was for a dui?
1800 552 123
westi
what the
Threads: 28
| posted on September 6th, 2008 at 09:23 PM |
me thinks you may be right.luckily it was after the aa meeting.
freak, i hope you mean his hair .
down sharon.
Eeyore Freak
Threads: 3
| posted on September 7th, 2008 at 02:05 PM |
yes!! i definatly ment his hair!!!! (his back actually) although now my mind is wandering!
1979 Kombi (Oscar)
| posted on September 7th, 2008 at 09:21 PM |
So some news Westi??
westi
what the
Threads: 28
| posted on September 8th, 2008 at 09:15 AM |
dyno and then the track.
we went to a rat rod show on fathers day,forgot to take pic's, but the car got so much attention everyone loved it,it was realy cool to see that a vw
can get all that appreciation from all different walks of life.nice pat on the back for all that have helped.
trying to organize a few power runs for tommorrow before hopfully hitting the track for a few wednesday street meets before warwick.
i will keep you all posted.
down sharon.
Eeyore Freak
Threads: 3
| posted on September 8th, 2008 at 03:28 PM |
hey bo
meowwww
1979 Kombi (Oscar)
westi
what the
Threads: 28
| posted on September 8th, 2008 at 03:44 PM |
here puss,puss.
mmmeeeeeooooooowwwwww
down sharon.
Stanley
Threads: 270
| posted on September 8th, 2008 at 07:20 PM |
c'mon westi that's not being productive....you've got a dyno or a T&T to organise.
Eeyore Freak
Threads: 3
| posted on September 8th, 2008 at 09:41 PM |
theres no harm in a bit off fun!
tell bo ill just change the day im gonna pop up to visit. hows friday for him? or is he a chicken as well as a pussy
1979 Kombi (Oscar)
westi
what the
Threads: 28
| posted on September 10th, 2008 at 01:37 AM |
well it was yet another long night as per usual.
worth it you will agree,well maybe.
did some minor jet changes to get us started after the last dyno run.
with were alittle fat down low and lean up top,
but we cracked 172 atw i was devistated,then we realized that it was still set in kilo watts.wooofuckin hoo.
230.1 rwhp.holy crap batman.stone cold engine and oil temps the heads were only just reading on the gauge.
then we spent the rest of the night trying to get it leaner down low and fatter up top.
all the changes resulted in power drops,so we went back to my first setting on a warmish engine which is 215.3 hp,
i think we might be at the end of the fuels capabilities after all it is only 100 octane.
but after all that it might be the limits of the carbies/venturies,we are stumped and over the moon all at the same time.
i will post up the dyno sheets tomorrow.as we are pretty tierd and need some sleep if we are going to take her out to the track tommorrow night.
we will have to do some checks before i am confident enough to tackle the track.i think i am going to have to take a few pairs of undies out with
me.me thinks i might soil a few.
down sharon.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on September 10th, 2008 at 06:14 AM |
| Quote: | Originally
posted by westi
wooofuckin hoo.
230.1 rwhp.
X2...............
dangerous
Mood: 591
| posted on September 10th, 2008 at 06:26 AM |
Wow man!
That's awesome!
| Quote: | Originally
posted by westi
That's mad Alan.
Stanley
Threads: 270
| posted on September 10th, 2008 at 06:41 AM |
Top stuff westi....will look forward to the track results
| posted on September 10th, 2008 at 06:52 AM |
well done mate. top job!!
Hopefully this will be the week of positive results for everyone!! (Troy's car at the dyno this week too)
Eeyore Freak
Threads: 3
| posted on September 10th, 2008 at 08:46 AM |
wow!!! could eeyore do that??!!!!!!! lol
1979 Kombi (Oscar)
Mick058
| posted on September 10th, 2008 at 09:33 AM |
yeehaa Westi - When you hitting the track, might try and make it to watch.
