[ Total Views: 139926 | Total Replies: 1114 | Thread Id: 67327 ]
 Pages:  1  ..  23  24  25  26  27  ..  38
Author: Subject:  Humpty's finally got off his arse and begun a real drag car project!
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on November 20th, 2012 at 09:04 PM
I reckon the box will hold up ok... Though I know it's taken a lot from me over the years... Sprints, hill climbs, autokanas and loads of drag racing... But all on radials... The issue is the tyres... I have M&H cheaters on there now... The fear is the axles will pop... But come Wednesday week that will be it... If they break then, then so be it. The new pan is getting built over the school holidays... Even if the new transaxle doesn't arrive before new year... At least I can mock the mounts up with a spare box.
FUCH your early!
http://www.noh2o.org/
Memberhumpty
Threads: 139
posted on November 25th, 2012 at 10:34 PM
Do any of you guys balance your slicks?
FUCH your early!
Memberdangerous
Mood: 591
posted on November 26th, 2012 at 05:07 AM
always!
Originally posted by westi
That's mad Alan.
Memberrose
doin it for d girls
Threads: 308
Theme: UltimaBB Pro Red
Mood: always happy
posted on November 26th, 2012 at 09:31 AM
does a wild bear shit in the woods:lol::lol:
[img][/img]
Memberdragvw2180
Threads: 33
yes.gif posted on November 26th, 2012 at 12:34 PM
Eh Rose , that wasn't a bear it was Humpty. Mike McCarthy :crazy::crazy::crazy:
Memberhumpty
Threads: 139
posted on November 27th, 2012 at 11:00 AM
That's gonna present a problem then..... Nobody does 'open centre' rim (wide 5) balancing here in Perth.
FUCH your early!
Memberrose
doin it for d girls
Threads: 308
Mood: always happy
posted on November 27th, 2012 at 11:04 AM
all tyre places do them that do trucks as similar type of rim with big hole in the middle. we take ours to Beaurepaires over here no worries at all
[img][/img]
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on November 27th, 2012 at 03:57 PM
Hmmmmm never had mine balanced for that reason too. Thanks Rose ill give them ago. I went to 4 local shops before i gave up!!!!
posted on November 27th, 2012 at 04:19 PM
Take a brake drum and lug nuts if you get stuck
MemberSuperOwen
Threads: 67
posted on November 27th, 2012 at 05:22 PM
If you do get them balanced make sure you mark the tire to the rim, assuming your not running screws or beadlocks.
Memberhypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
yes.gif posted on November 27th, 2012 at 07:39 PM
I had a local engineer machine me an adaptor plate from 12mm steel plate that I bolt to my wide-5 rims with a 72mm hole in the centre and then they can be balanced easily . If you need it Ben you can borrow it to get your wheels balanced .
I will post a pic of it tomorrow........
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
Memberhumpty
Threads: 139
posted on November 28th, 2012 at 12:43 AM
That'll be awesome to see Wayne.... I had a chat to my tyre guy here in Perth about this issue.... He's a dubber too, but works on Porsches and Merc's all day.... They also look after loads of us WA dubbers.... But he has never been able to balance 205PCD rims with the large centre hole.... Though about grabbing a front drum and using that, but all options are welcome.... Looks like I'll be machining something up next week in any case.
FUCH your early!
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
yes.gif posted on November 29th, 2012 at 12:25 AM
the steel adpator plate is the one I used to use for balancing wide-5 wheels , but now I use the alloy rear wheel adaptor plates that I had fabricated
Memberhumpty
Threads: 139
posted on November 29th, 2012 at 05:21 PM
That's the ticket.... Gonna have to make one of those suckers up I reckon.... I'm sure it would be heaps safer doing it this way, than letting a truck fitter near my light weight ERCO's!!!
FUCH your early!
Memberrose
doin it for d girls
Threads: 308
Mood: always happy
posted on November 29th, 2012 at 05:52 PM
We had one made up but don't need to use it. As people have said that no one can balance them.
But when we took it to the tyre shop he said you don't need it we balance them on this tyre balancing machine.
Our same bloke that balances our car tyres uses the truck balancer to balance our wheels no worries.
We also have in the past borrowed the one that our VW car club has to loan out. Club Vee Dub Sydney.
[img][/img]
Memberhumpty
Threads: 139
posted on November 30th, 2012 at 11:16 PM
Hhhmmmmm..... Truck fitters hey?
FUCH your early!
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on December 1st, 2012 at 01:56 PM
Some shops just don't want to spend the time , as you have to keep turning tyre on rim , so you can find the sweet spot.
Most tyre's have heavy spots in them .
You'll end up with lots of weights , in the end ( stick on ). Put race tape over the weights to , helps hold them on .
Memberhumpty
Threads: 139
posted on December 2nd, 2012 at 10:41 PM
It just gets better and better!.... Cheers for the advise Pete.
FUCH your early!
Memberhumpty
Threads: 139
posted on December 8th, 2012 at 02:48 PM
Next little chalenge....
http://i27.photobucket.com/albums/c181/Humptydub/POS60T/IMG_8525.jpg
Some time back I was looking at methods of fitting aircleaners to the Holley.... Now that I have the car running really nicely and AFR's are nice and constant, the idea of running an aircleaner has popped up again.... My question is simple on the surface, but in reality very challenging...
http://i27.photobucket.com/albums/c181/Humptydub/POS60T/IMG_8522.jpg
As you can see, there's not a lot of room in there....
http://i27.photobucket.com/albums/c181/Humptydub/POS60T/IMG_8520.jpg
I don't want to cut the engine cover to fit a funnel as Barry has, and I can't really fit an aircleaner as Rose and Ian have on the Nude Bug.... And then there is the other idea of fabricating a scoop arrangement much like Nick has on the Junka.... This idea is nice, but I'm not exactly sure how a Holley actually works.... Does it require a neutral atmosphere above the carb or can I have a positive/pressurised space above the intake?
FUCH your early!
MemberBoostn
Threads: 28
posted on December 8th, 2012 at 04:51 PM
Looking good Simon, I can smell that car Holley from here....hahaha
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
Memberhumpty
Threads: 139
posted on December 8th, 2012 at 06:06 PM
Hahahahaa.... Funny guy.... I know how you love'em!!!!
Good to see you back here mate... Looking forward to seeing what you get up to.....
FUCH your early!
Memberwhathaveidone
Threads: 98
posted on December 8th, 2012 at 06:17 PM
You could always put one of there on your roof.With some flexible pipe flatened out to go through the gap between your deck lid!!!!!!!
Would work a treat!!!!!!!
http://www.ebay.com.au/itm/Donaldson-type-air-cleaner-Toyota-Landcruiser-HJ47...
Memberhumpty
Threads: 139
posted on December 9th, 2012 at 12:48 AM
That's what I like about you Ben.... Always thinking outside the box.... ;)
FUCH your early!
Memberwhathaveidone
Threads: 98
posted on December 9th, 2012 at 06:26 AM
:tu::lol::tu::tu:
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on December 9th, 2012 at 08:39 AM
Make your boot lid stand offs a bit longer to allow room for air cleaner. Fabricate up a base that fits on the carb that comes to a tee and run a pod filter on either side of the tee low down beside the carb body itself if there is enough room.
Memberian.mezz
Threads: 280
posted on December 9th, 2012 at 10:43 AM
https://shop.rocketindustries.com.au/products/KN61-2000
:lol::crazy::lol::crazy::lol:
Memberhumpty
Threads: 139
posted on December 9th, 2012 at 03:55 PM
A conventional aircleaner wont fit Ian... And I don't really want to prop the engine cover anymore Brennden.... But I guess I might have to... Another option is one of these beasts...
http://img.tapatalk.com/43db52d5-58d5-c8d0.jpg
Which I have and is ideal, and it would fit without some internal mods, but it's bloody heavy.... Been thinking of pulling a mold off it and making a fibreglass version.
FUCH your early!
posted on December 9th, 2012 at 04:53 PM
Hi Humpty
Maybe look around for neck like the one you have from a carby LPG conversion but it may not be any lighter. Could you not fabricate a sheet alloy one up.
Memberwhathaveidone
Threads: 98
posted on December 9th, 2012 at 05:16 PM
Whats wrong with my idea????:(
Membermorgan
A.k.a.: morgan smith
Threads: 30
Mood: excited
posted on December 9th, 2012 at 07:03 PM
stop thinking street car and start cutting
[ Queries: 40 ] [ PHP: 12.3% - SQL: 87.7% ]
