| [ Total Views: 329245 | Total Replies: 1582 | Thread Id: 58055 ] |
| Pages: 1 .. 27 28 29 30 31 .. 53 |
dangerous
Mood: 591
| posted on March 29th, 2010 at 04:50 PM |
see stanley's handy work on his chromoly front beam on this page:
http://forums.aussieveedubbers.com/viewtopic.php?tid=68967&page=6#pid760602
| Quote: | Originally
posted by westi
That's mad Alan.
13bwagon
Threads: 9
| posted on March 29th, 2010 at 06:01 PM |
wow that is killer
and the vid makes ya laugh
BUY A REAL BUG A PRE S BUG...
tassy74ida
Threads: 14
| posted on April 8th, 2010 at 01:59 PM |
congrats dave on the 10sec time card.. Haven't been online for a while so a bit behind on whats been happening...
STOCK
Threads: 12
Mood: OK
| posted on April 9th, 2010 at 01:02 PM |
HEY DAVE
BRAD (WESTI) & I ARE TAKING THE JUNKA OUT THE 16TH
TO EASTERN CREEK FOR SOME TEST & TUNE IF ALL GOES WELL
WE'RE THINKING ABOUT GOING TO GUNEDAH
WHAT ABOUT YOU ARE YOU KEEN ?????
STOCK
dangerous
Mood: 591
| posted on April 9th, 2010 at 01:27 PM |
Hi Stock
yes I will be at Gunnedah that week end, 15th and 16th in May.
| Quote: | Originally
posted by westi
That's mad Alan.
STOCK
Threads: 12
Mood: OK
| posted on April 9th, 2010 at 02:09 PM |
| Quote: | Originally
posted by dangerous
Hi Stock
WELL PROVIDED ALL GOES WELL NEXT WEEKEND
WITH TESTING
WE'LL BE THERE , BE GOOD TO CATCH UP
STOCK
dangerous
Mood: 591
| posted on April 17th, 2010 at 04:41 PM |
| Quote: | Originally
posted by westi
That's mad Alan.
reub
VWRX is gone...
| posted on April 17th, 2010 at 05:12 PM |
Here you go Dave - on your way to a 10 sec pass.... Managed to track them down.
| Error |
| Error |
Reub
dangerous
Mood: 591
| posted on April 18th, 2010 at 08:48 AM |
THANKS REUB!!
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
Mood: not blue, pink
| posted on April 18th, 2010 at 12:58 PM |
how come your putting more weight in.are you trying to run 11.00 again.
as always nicely made and mounted,but it does look like an atempt to slow you down to stop that extra fee for the licence.
down sharon.
dangerous
Mood: 591
| posted on April 18th, 2010 at 04:18 PM |
Once the alternator is in, that is it for added weight.
It can only get lighter from now on....
Just noticed the shift light is on in that last picture.
That is 8000 rpm only car length off the line(clutch slip).
Can hear the limiter in the vid too.(8400)
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on April 30th, 2010 at 05:29 PM |
| Quote: | Originally
posted by westi
That's mad Alan.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on April 30th, 2010 at 06:26 PM |
Looks better all cleaned up , what wiring mate . Will you run a lite power source to excite it ? What amps , no more battery chargging ?
dangerous
Mood: 591
| posted on April 30th, 2010 at 06:56 PM |
Hey dude,
one big red wire to the battery + (on the starter),
one wire goes to a +12 volt source, (somewherewithin the system but not the battery best)
and the other wire to a green light to excite the whole deal.(power side of light from + on iginition switch.
No more charging up after day one of a two day event,(I hope).
It is a 40 amp alternator.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on May 8th, 2010 at 02:22 PM |
All "up and running" for Gunnedah next week end:
http://www.youtube.com/watch?v=8QWqbkcN41Q
Only glitch was the pilot light I got from super cheap is polarity sensitive
and so had to swap the connections to get the lght to come on.
I found this all before initial start up.(good old multi meter!)
Pulley ratio drives the alternator at maximum of 10,000 rpm when engine is at 8400 limit.
Most alternators I found specs for, did not like any more than 14000,
and with this ratio the light goes out at around 900 rpm.(engine idles at 2000 once all cylinders running).
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on May 8th, 2010 at 02:46 PM |
Here are some details of the wires.
I fitted a fuse to the primary large 12 volt wire that went from the stud/nut teminal on the back of the alternator
to the +ve on the starter,(which goes straight to the battery +ve).
That is the thick orange wire and fuse, which splices into a fat red one.(blue arrow in pic below).
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on May 8th, 2010 at 02:50 PM |
The yellow wire connects to the "L" on the alternator,
and the pilot light on the dashboard.(green arrow above).
The thin red wire connects to the "R" on the alternator,
and goes up to the front, where I found a 12 Volt source at the fuse box.
Tried to take a pic from inside the enine bat showig the back of the alternator:
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on May 8th, 2010 at 02:52 PM |
The pilot light gets a 12 volt supply from the ignition switch: red wire from the ignition switch.
(yellow wire is the one from the back from the back).
| Quote: | Originally
posted by westi
That's mad Alan.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on May 8th, 2010 at 06:08 PM |
Good work dave.
Crazy collection of snakes in that motor now ...
It was a bit worrying that every youtube video that supposedly related to your was of crash compilations???
dangerous
Mood: 591
| posted on May 8th, 2010 at 06:18 PM |
| Quote: | Originally
posted by vassy66T1
Good work dave.
Yeah, not sure whay that was.
Probably related to the orginal title that was the numbers off my camera,
and the "tags" and "categories" it originally had when uploaded.(since edited).
| Quote: | Originally
posted by westi
That's mad Alan.
colonel mustard
Threads: 51
| posted on May 8th, 2010 at 06:36 PM |
Dave, Tag your own name, or Dangerous dave butler muffin man ... or similar, then the related video's would be... maybe the dyno day vids.
Looking sweet mate!
andrewmurphy
Threads: 22
| posted on May 8th, 2010 at 07:56 PM |
hey Dave, the missus loves the engine in the wardrobe. i looks almost too good to install!
dangerous
Mood: 591
| posted on May 18th, 2010 at 09:25 AM |
Gunnedah was a fun event.
The track locals were very friendly,
and a special thanks must to Ross and Pauline Freestone for their hospitality,
and to Ross' mate, and regular crew guy, Gary for his help on the day.
The track surface was a challenge to take off from,
with no prep other than 'past rubber'.
But this is why i like to experiment with different conditions.
You work with the cards you are dealt.
In the end, a combination of
tyre pressure,
launch rpm,
wheely bar settings,
and driving style,
all culminated in times equal to my best.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on May 18th, 2010 at 09:34 AM |
Runs:
7.285@94.66 (1.648 sixty with wheel spin).
6.931@96.96 (1.406 sixty was probably bogus given the wheel spin). best ever 1/8 mile time.
7.174@ 96.33 (1.585 sixty felt better)
7.035@97.09 good clean run using lower tyre pressure and dropped start rpm down from 7100 to 6000.(1.517 sixty)
Sunday:
7.310@94.56 alwys get the crap run out of the way first thing in the morning.
7.087@96.62 (1.523 sixty) that's better.(pumped the tyres up to 15psi and raised the wheely bars as high as they'd go)
7.001@97.53 (1.468 sixty) beet 500 cu in V8 falcon(just-hehe).(tyres at about 13.5)
6.949@97.32 (1.409 sixty) broke out on 7.05 dial in...best sixty foot since when I was supercharged.
(very close to my previous best 1/8 mile time when I ran the Ten, of 6.941)
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on May 18th, 2010 at 09:38 AM |
Oh yeah,
alternator worked fine and belt stayed on, and tight, all week end.
Battery voltage this morning was still above 13 volts, (cold morning)
when normally it would be below 12 volts after that many runs.
Does not seem to have cost much in power either.
| Quote: | Originally
posted by westi
That's mad Alan.
rose
doin it for d girls
Threads: 308
Theme: UltimaBB Pro Red
Mood: always happy
| posted on May 18th, 2010 at 11:05 AM |
this is what Dave's been up to
http://www.youtube.com/watch?v=s1g3jSpenDw
http://www.youtube.com/watch?v=_EMnEzccgIU
http://www.youtube.com/watch?v=28zWoWgdYtQ
[img][/img]
vassy66T1
A.k.a.: Marcus Vass
| posted on May 18th, 2010 at 02:41 PM |
Dusting the big block!!
I love it Good work Dave
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
| posted on May 21st, 2010 at 12:02 PM |
Awesome Dave, Looks like fun. I'm Spewing i couldn't go. had a wedding to go to which the missus had on the calender for months. Next time!
Cheers Dave!
Stanley
Threads: 270
| posted on June 5th, 2010 at 03:57 AM |
Hey dude what's going on. Things seem quiet
dangerous
Mood: 591
| posted on June 11th, 2010 at 06:20 AM |
All quiet here.
I have a broken engine mount to fix up,
but the new heads will be the next engine plan.
I still have many hours left to complete on them,
plus new pistons and all the valve train parts to buy.
So it may not be until next year.
| Quote: | Originally
posted by westi
That's mad Alan.
