[ Total Views: 291885 | Total Replies: 1034 | Thread Id: 67295 ]
 Pages:  1  ..  27  28  29  30  31  ..  35
Author: Subject:  58 Beetle - Subaru WRX STI bug - The Bug That was...BYE BYE
MemberOllie
A.k.a.: Ollie Clarke
Yeah Buddy
Threads: 122
posted on November 15th, 2009 at 07:50 PM
I definitely need to see this this on the Street!
I caught it up at Warwick and used an entire memory card taking pictures of this car and this car alone. I only got about three of the drag racing!
RTA can be a killer, but at least you don't have to see them again for an entire year!
Follow the Photo Fun:
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on November 23rd, 2009 at 06:32 PM
Have been off the site for a while and just spent half the day reading your post from start to finish....got to page 27 and had to do some work...just finished the last 8 pages.
SENSATIONAL job mate.
Its great that you took your time with each section and the results speak for themselves....neat!
With respect to the turbo..there are two choices for an ej20t. You can buy a brand new tdo5 with a 16g wheel for $500 on ebay from a guy on sydney...i thinks his name is AUTURBO...or get a VF34 which is pretty much the best of the IHI turbos. There is a second hand one on Rexnet today for $750 of new they range between $1150-$1300.
They will both flow similar cmf and will also spool up quickly. The vf34 is ball bearing and thats why its ultimately better. It will spool up quicker and easier, will last a little longer(one of the only real reasons we have blow off valves..is to stop pressure trying to push back on the turbo from where it came when you close the throttle body)..... Oh and to make the cool high pitch whistle when spooling. I have the vf24 from the version 5sti which has the same exhaust compressor as the 34 although much smaller intake and thus flows alot less at any given psi.
Again awesome work...we will have to get the other boys together and go waste some evo's.
I also had a little bingle in mine 3 weeks ago..rear ender with a bitch who slams on the brakes when she dropped her smoke. Tip...have a little give in the radiator mounts and not nearly so hard to fix. Bonnet screwed, aero cracked and headlight destroyed. Upsetting..but fixed.
Matt
MemberSTIDUB
Over it.
Threads: 57
posted on November 25th, 2009 at 10:32 PM
hey mick, turns out we will be running the same engine. turbo however will likely be different though, picked mine up early today to match the box from DB sarvo, out of curiosity could you possibly PM me the price you got yours for? (feel i got an awesome price for mine & just wanted to compare thats all)
Oh, you better be out driving it heaps now its rego'd!:D
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on December 3rd, 2009 at 10:40 PM
So Mick hows that smile going ?!
Give the readers an update !!:)
MemberMick058
posted on December 4th, 2009 at 09:49 AM
Funny you should ask Craig!
MemberMick058
posted on December 4th, 2009 at 09:54 AM
Error Codes
P0102 MAF SENSOR LOW INPUT
P0458 EVAP PURGE VALVE CIRCUIT LOW
P1230 FUEL PUMP CONTROL UNIT MALFUNCTION
P0037 REAR 02 SENSOR LOW INPUT
P0245 WASTEGATE SOLENOID A LOW
Im having issues with the engine as i get towards the higher rev range - maybe about 4000rpm and up, it starts to spit and cut out, kinda splattering. I usually can warm it up a little, get one good run at full revs and then after that it starts to spit and carry on when i get on the throttle.
Memberian.mezz
Threads: 280
posted on December 4th, 2009 at 10:57 AM
I would just unplug those things and check connection.
disconnect battery put it back on and just start it then drive again see what it does.
some codes don't make car run bad,
put a fuel pressure gauge on it , check spark plug colour to see if fueling up.
mine has speedo and idle valve code but doesnt cause any trouble.
:lol::crazy::lol::crazy::lol:
Member71-BEETLE-SEDAN
AKA Josh
Threads: 108
posted on December 4th, 2009 at 11:35 AM
I heard joel saying that some rexy motors start to do what your describing if their speeno sensors arent moving, like are you driving it up the street, on a dyno or just in neutral.
MemberMick058
posted on December 4th, 2009 at 11:40 AM
usually happens around 4000rpm or so - just driving around
AKA Josh
Threads: 108
posted on December 4th, 2009 at 11:43 AM
Okay, dunno then , but i would do what ian.mez said and take those sensors out give em a clean and disconnect the battery again see what happens.
Memberian.mezz
Threads: 280
posted on December 4th, 2009 at 08:22 PM
yeah I had a loose hose from intercooler to throttle body and my car would lose power etc.
posted on December 5th, 2009 at 07:09 AM
sounds like its going into limp mode
loooking at that list i'd be checking for a dodgy earth
Al and Miles setup the earlier ones to ground the whole system through the manifold, im guessing later ones would be the same
Memberian.mezz
Threads: 280
posted on December 5th, 2009 at 03:37 PM
I put all my earths in the one spot easier to check that way:crazy::no::crazy:
limp mode normally doesnt make it, spit and cut out, kinda splattering
MemberMick058
posted on December 5th, 2009 at 07:46 PM
i'm just going to drop it back at Westside to work it out - i have no time to muck around with it - happy for any opinions though and ill forward to Westside. Thanks for ideas so far - This is the reason why i paid for someone to do the conversion, because i have no time to play around with this stuff - car is freaken awesome otherwise!!! so fun, so quick and people love it - people have stopped me heaps and waved and even ricers give me the big grin and thumbs up!
posted on December 5th, 2009 at 07:55 PM
Hi Mick
Did you use one of your pumps from work on your car?
MemberMick058
posted on December 5th, 2009 at 07:58 PM
haha, no mate - different types of pumps!
posted on December 5th, 2009 at 08:02 PM
Bugger, at least you would have spoken the lingo
Memberjzk25
Threads: 3
posted on December 6th, 2009 at 06:36 AM
Hi Mick, if you need help sorting the engine management give me a call. Subaru management is pretty fussy, you need to have it all working correctly or it will do silly things like cut out at 4000rpm.
Post a pic of the current engine bay layout showing the MAF sensor, boost sensor etc and I can also see if there is anything obvious. In any case it shouldn't be a big deal to fix.
Al @ AM Auto.
MemberMick058
posted on December 6th, 2009 at 08:33 AM
Thanks Al, I'll take some photos tonight and post them.
Membercolonel mustard
Threads: 51
posted on December 6th, 2009 at 12:53 PM
take it to a subaru service centre... just for a laugh.
MemberCraig Torrens
Threads: 347
posted on December 6th, 2009 at 07:13 PM
just sell it :tu:
Memberpsimitar
Threads: 148
posted on December 7th, 2009 at 10:24 AM
It's actually not an entirely bad idea Jason. If the diagnostic port is still within the wiring loom then they can connect it to their diagnostic machine and see all the voltage levels etc for the sensors.
The problem would be convincing them to work on a none std vehicle :lol:
Threads: 51
posted on December 7th, 2009 at 11:11 AM
I think they would charge a fair bit as its not even a standard subaru setup....
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on December 7th, 2009 at 02:49 PM
Could be the cars way of rejecting the transplant LOL
Tough break Mick. I'd check earth's first then do an ECU reset and go for a drive to see what happens.
MemberMick058
posted on December 7th, 2009 at 06:29 PM
just sell it :tu:
35k and its yours!! Though it owes me a bucket load more.
MemberMick058
posted on December 7th, 2009 at 06:30 PM
Hey mate, yeh, gonna check it out tonight - booked it in to Westside next week nonetheless to double check things.
MemberSTIDUB
Over it.
Threads: 57
posted on December 7th, 2009 at 07:13 PM
Originally posted by Mick058
just sell it :tu:
that fact should be obvious to anyone thats looked at the thread that isnt a clueless dreamer :tu:
Threads: 51
posted on December 7th, 2009 at 07:17 PM
id guess that all up its coming close to double that
MemberMick058
posted on December 7th, 2009 at 07:20 PM
:lol::lol::lol: you'd hate to see the receipts!
MemberCraig Torrens
Threads: 347
posted on December 7th, 2009 at 08:14 PM
No.... I'd love to see them ;)
come on Mick, enter the confession box and tell all !!! :blush:
[ Queries: 40 ] [ PHP: 8.1% - SQL: 91.9% ]
