[ Total Views: 32697 | Total Replies: 563 | Thread Id: 101171 ]
 Pages:  1  2  3  4  5  ..  19
Author: Subject:  What did you do on your VW today ???
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on March 24th, 2013 at 06:56 AM
Yeah passenger would be good Aaron ...... You could tell exactly when their heart stopped :smilegrin:
Membertar76
Threads: 95
posted on March 24th, 2013 at 08:45 AM
You'll only need your nose if their heart keeps going, and they crap themself instead :lol:
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
MemberSebastienPeek
Threads: 89
posted on March 24th, 2013 at 10:37 AM
Pulled apart Zelda, getting ready to sell stuff.
The sold one, '73 VW 1303 - Zelda
The project, '74 VW 1303 - Gretl
MemberMY68VW
Threads: 25
Mood: fresh metal
posted on March 24th, 2013 at 06:34 PM
Like this thread! :tu:
Rolled the wheels into a different position, I don't have the car - just the wheels. :fakesniff:
I should make a trip to WPVW and check there isn't water under the carpets and give the interior some fresh air.
Oh, and put some wheels on it.
Tuned Type IV power - shaking out the rust.
Memberrickp
Threads: 31
posted on March 24th, 2013 at 06:51 PM
took it out for a spin to the local auto store, to get supplies to service my other 2 cars.
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on March 24th, 2013 at 07:04 PM
Started making a battery box to comply with ANDRA. Fixed the door hinges. Sprayed the deck lid. Took some pics. Sat in it making noises with my mouth while pretending to race with my daughter:lol:
Memberhellbugged
A.k.a.: Daimo Pell
posted on March 24th, 2013 at 07:38 PM
Today...... Nothing!!
Yay!
Membertar76
Threads: 95
posted on March 24th, 2013 at 07:43 PM
Finished most of the floor still got a bit to go!
"Obey your Dreams"!
62 Std beetle.
posted on March 24th, 2013 at 07:47 PM
Yay!
yep.. like most others days on vw's i concur :lol:
mostly :rolleyes:
posted on March 24th, 2013 at 08:53 PM
fixed pesky oil leak on Bluey. LH axle boot flange was leaking through the factory spot welds. :(
http://i375.photobucket.com/albums/oo199/mattberry-photo/Blue%2059/DSCN3200_zps23a7262b.jpg
MemberDakDak67
Threads: 15
posted on March 24th, 2013 at 08:57 PM
Left the bus out in a storm. Shit.
posted on March 24th, 2013 at 09:18 PM
^ like.. NOT!!
posted on March 24th, 2013 at 09:25 PM
^^ Dude?
Memberhellbugged
A.k.a.: Daimo Pell
posted on March 24th, 2013 at 10:10 PM
You ok h ?
posted on March 24th, 2013 at 10:14 PM
yeah mate, but chris's bus might not be :mad:
posted on March 24th, 2013 at 10:25 PM
Shit
Membergrogy
Threads: 344
posted on March 24th, 2013 at 11:18 PM
hi, spent 3 hrs yesterday raising the ghia because i cant get the wheels on or off. raised it so high the neg camber wouldnt change. today i spent about 2 lowering it and still too much neg camber. so tomoro i do the same, hopefully i get it right............... and that is only on one side
MemberDakDak67
Threads: 15
posted on March 25th, 2013 at 06:46 AM
Shit
it's fine , just wet...
I don't have any shelter for it , if the cover was on it wouldn't have been so bad. Today is dry out day.
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on March 25th, 2013 at 07:20 AM
Had the same problem on No.8......and what a bastard of a job with the trans. in place. The old one-piece flanges were OK, and didn't need that big 'O' ring......why did they 'improve' them?
MemberSides
A.k.a.: Dave Sidery
posted on March 25th, 2013 at 07:39 AM
Drove it... hard... 50.74 seconds at Mt Cotton, despite track having SFA grip after so much rain.
:D
My toys
Membercolin
Threads: 82
posted on March 26th, 2013 at 04:25 PM
:D
You should be getting used to racing with no track temp Sides, Bathurst had zero track temp and you still raced hard and fast. :tu:
Cheers Col
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on March 26th, 2013 at 10:30 PM
I thrashed the living crap out of our 71 Beetle. Got to 100kph in 3rd. I love slamming the gears no clutch.
Member65standard
Threads: 47
Mood: Only when I'm in it.
posted on March 29th, 2013 at 12:40 PM
This morning adjusted the clutch (front firewall was getting in the way before clutch disengaging) and renewed both rear shocks. The shocks were still good, but the rubber mounts were shot. All good now.
[size=4]If it ain't broke, fix it till it is![/size]
MemberMr Muppet
Threads: 6
posted on March 29th, 2013 at 07:24 PM
Pulled apart my new Beetle project to see, how much rust is too much rust.
Memberbeetle_nut
Threads: 55
Mood: rollin low n rollin slow.65 notch back and 59 beetle
posted on March 29th, 2013 at 08:18 PM
Put new rubbers onto my pop out windows.not fun...:crazy::crazy:
MemberDoug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet :)
posted on March 29th, 2013 at 11:03 PM
Finished rebuilding one kadron.... Doesn't sound much but it had an inch of water in the float bowl when I stripped it....
Memberancientbugger
Threads: 191
posted on March 30th, 2013 at 10:11 AM
Now that the buggy's going I decided to have a look at the cab as to why it sounds like it's only running on 3 cylinders. Pulled off the leads from the dist cap one by one and found it wasn't sparking on 2 cylinders! After pulling out the offending spark plugs (not so easy on a FI engine!) cleaned them up and now appears to sound and run perfectly:cool:
MemberTorxKiwi
A.k.a.: Dean Newell
Threads: 38
Mood: "It's not easy being green"
posted on March 30th, 2013 at 06:41 PM
Bled the brakes ....... again. Until the kids refused to assist with the 'pump, pump, hold' routine.
Got the timing light out to check it as was running a bit hot. Figure that something well in advance of 10 degrees BTDC may have had something to do with it. All sorted now.
Pulled on the handbrake upon arrival back in the garage and it had a mini self-destruct. Release button flew out the end of the handle. Dismantled, cleaned up, coat of paint and back together.
Don't mind the little issues, it's nice to feel like you accomplish something once in a while!!
"Ownership of a Beetle is not a destination it is a journey."
MemberTOPCAT69
Threads: 19
Mood: HAPPY DAYS
posted on March 30th, 2013 at 06:58 PM
Filled up the beetle with petrol. ..
It's just doubled in value. ..haha
shitbox rule:crazy:
You got nothing I want - COLD CHISEL :no:
thread killer :ninja:
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on March 30th, 2013 at 07:19 PM
1m 13.1 at Wakefield Park:yes:
Thanks again, Henry.:tu:
