[ Total Views: 6780 | Total Replies: 61 | Thread Id: 107283 ]
 Pages:  1  2  3
Author: Subject:  Cooling problem with my ej22 kombi
posted on October 19th, 2014 at 04:05 PM
In fact, a thermostat will also slow the coolant down enough to cool it properly in the radiator(s).
Just to add an extra bit of thinking to your fine tuning...
Ricola (do a search to find his cabrio) did some serious testing and computer modelling re radiator scoops and ducting a few years ago. He discovered that to get your radiator working effectively, it needs a scoop that has a surface area of 40% of the radiator surface. Any less than that and it doesn't supply enough air. Additionally, that scoop has to be placed in a position where is gets laminar airflow. That is, uninterupted, smooth airflow like you'd expect at the front of a vehicle.
Memberian.mezz
Threads: 280
posted on October 20th, 2014 at 06:21 PM
cool running it wont hurt your motor that you got out of a $500 car with 200k :blush: is better then over heating and cooking your engine '
don't take the scoops off .
you can test your cooling system by driving around in 2nd or 3rd gear at high revs , eg 100kph in 3rd for a long time and see what the temp does .:blush:
vlad01 would know about getting heat into commodore by driving around in 2nd gear , as it was how you tested for a bad crank angle sensor . but the motor wouldn't over heat .
Dual flow :blush: radiators work good
This simply means the coolant passes through TWO times instead of ONE. Which, even more simply put means TWICE the cooling and half the size radiator
:lol::crazy::lol::crazy::lol:
 Pages:  1  2  3
[ Queries: 40 ] [ PHP: 8.4% - SQL: 91.6% ]
