[ Total Views: 155504 | Total Replies: 188 | Thread Id: 50894 ]
 Pages:  1  2  3  4  5  ..  7
Author: Subject:  *** Tight Arse Turbo...***RETIRED***
MemberStanley
Threads: 270
posted on January 15th, 2007 at 06:59 PM
Didn't get as much completed as I had planned this weekend as i had to prepare an area ready for a water tank, bit I managed to finish thr exhaust fron the headers to the turbo.
Photo 1 is the finished manifold made from 1 1/2 tube. Probably not the best flowing but it wiil do to prove the system.
Photo 2 is the complete exhaust connected to a standard set of Thunderbird extractors. Next time and now I have the TIG, I'll make a custom set of headers to keeep the pipe length shorter.
MemberStanley
Threads: 270
posted on January 15th, 2007 at 07:06 PM
These photo's show it all fitted up. The dump pipe out of the turbo is really only for show although I'll be tempted to give it ago. I''ll make another one out of 1 5/8 tube that will bend down and come out the drivers side exhaust cutout. At this stage I don't plan on running a muffler although I'll make a pipe that will allow one to be fitted at a later date. Remember this isn;t a daily driver although I will need to get it to the track some how.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on January 15th, 2007 at 09:27 PM
Nice work - loving the progress!
Just one question, do you envisage any problems adjusting the timing (using a light) since the exhaust runs up the centre line of the crank pulley - any ideas how to get around this?
Alan
MemberStanley
Threads: 270
posted on January 16th, 2007 at 08:12 PM
Good point Alan. It should be ok I can see the marks ok....maybe a bit of paralex error to avoid...will soon see.
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on January 23rd, 2007 at 11:12 PM
Any news Stanley.....
FUCH your early!
http://www.noh2o.org/
MemberStanley
Threads: 270
posted on January 24th, 2007 at 07:16 AM
Kinda, I've since pulled everything off as it was only there for fabrication purposes. Since the last pics i've pulled everything off cleaned it up painted some bits and started to bolt everything back for good. Also had to make a new bracket for the waste gate actuator. I'll put up some more pics over the weekend. Pretty much just need to fit the pressure reg and fuel and oil hoses to get it going. Aluminium AN hose fittings aren't cheap.
posted on January 24th, 2007 at 09:38 AM
great work. I'm looking forward to hearing what it's like. Are you expecting it to be a bit laggy with the long pipework or is the turbo small enough to spool up quickly?
MemberStanley
Threads: 270
posted on January 24th, 2007 at 02:17 PM
It's only a T2 of a nissan pulsar so i'm expecting it to spool up ok. Only one way to confirm that.
Memberhumpty
Threads: 139
posted on January 24th, 2007 at 03:56 PM
And we wait with bated breath....
FUCH your early!
MemberEuro_67
Threads: 75
posted on January 25th, 2007 at 07:32 AM
Its looking great ! Any reason you didnt go with the under apron turbo header from CB performance ? it might help keep the heat out of the engine bay. Video of the startup for us all to watch is a must !
Wayne
MemberStanley
Threads: 270
posted on January 25th, 2007 at 08:05 PM
Wayne
CB performance = many $
I like to do things my own way....with the help of many people.
It's not a daily driver so heat wasn't a huge issue. Just the concept of a turboed volksy.
and finally its the Tight Arse Tuesday turbo. I'm in my very early 40's and have 4 kids so car funds are tight at times. I'd like to think that what I have done is within the reach of anyone. Mind you, you could do it cheaper but i've tried to balance $ but have spent the money where it counts (I hope).
I've had a lot of fun building this and as you can see it's the best part of 10 months. Must admit i'm feeling the pressure of turning the key (or pressing the button 'cause it doesn't have a key anymore) I've also had to deal with my wife who I might add has finally come around, to the fact that i've taken a perfectly good volksy and made it so it will be difficult if not impossible to use for family outings.
[ Edited on 25-1-2007 by Stanley ]
posted on January 25th, 2007 at 09:28 PM
CB hideaway header is for a blow thro setup
stans is drawthro
i dont like how low the turbo mounts with them
i reckon thered be drainage issues cos its mounted pretty much level with the sump
but i havent seen one in the flesh so it may be different
theres enough of them getting around
-Joel
Memberhumpty
Threads: 139
posted on January 26th, 2007 at 01:50 AM
Keep it coming Stan... You've done us all proud.... And no pressure mate.... Just make sure you are happy with every little thing.... And have a video camera ready for the big day!
FUCH your early!
MemberStanley
Threads: 270
posted on January 28th, 2007 at 07:52 PM
Not a lot to add this weekend although I did get a fair bit done.
Got it all re-assembled then realised I 'd put off a job just a little to long. I made the drain for the turbo only to realise it may foul on the wastegate actuator rod. Everything was closed so I couldn't get any fittings to check. Wired everthing up and mounted the oil filter bracket under the LH guard where the bumper mounts. Also made a brace from the turbo to the body so the exhaust isn't taking all the load. (G force when accelerating..:P)
All I need to run it is the hoses for the oil filter and a fuel line. I also need a press reg but I can probably start it without it but I don't think the Facet pump I have will cut the mustard. It's only goof for 5psi so I will upgrade to a holley blue. I'm concerned the facet might cause a lean situation where as the holley might be an overkill but I would rather have too much fuel, atleast I can get rid of excess fuel through a return line.
I'll need to build up some funds to complete it. Christmas and school holidays have drained the TAT account.
Anyhoo, enough waffling about nothing. Here's a pic of what the finished product should look like. The dump pipe will go eventually when I get around to making the rest of the exhaust but it looks cool and will do to start it.
Jobs to complete.
Locking the dizzy
needle mods on the SU
accelerator cable to the SU
[ Edited on 28-1-2007 by Stanley ]
Memberhumpty
Threads: 139
posted on January 28th, 2007 at 08:10 PM
top stuff....
FUCH your early!
MemberStanley
Threads: 270
posted on February 3rd, 2007 at 08:14 PM
worst fear relised. Turbo drain fouled on wastegate actuator. Had to reposition wastegate actuator by making a new baracket. Did that today and painted ready for fitment tomorrow. As long as I get the last fittings for the oil filter I'll try and start it next week end. The facet pump will do for running without the reg.
i'll post some pics for those interested tomorrow
MemberGracey
Threads: 17
Mood: Itchy
posted on February 4th, 2007 at 02:55 PM
Looking good, betcha can't wait to start it.
MemberStanley
Threads: 270
posted on February 10th, 2007 at 07:42 PM
Well, reached a milestone today. Finally got everything hooked up. Have been waiting for some various fittings for the fuel system and the oil filter. They finally turned up y'day. Filled it with oil and bled the system best I could by filling all the lines and blowing some low press air through to get as much oil into the system as possible.
Then turned it over and within a several seconds the oil light went out...whoo hoo. no oil leaks so far. Mind you it could still all turn to shit.
Tomorrow I will check the float level in the SU tidy up some wiring and If all goes well i'll light the fire and see if it runs. I haven't got the throttle hooked up yet but I can still give it a start.
Once it is running and doesn't handgrenade i'll finish off a few niggly bits and start the running in process.
This is pretty much how it will look. Just need to get a an air cleaner, a breather can and i'll change the fuel pump when funds allow.
Memberdangerous
Mood: 591
posted on February 11th, 2007 at 08:54 AM
DOES IT GO YET??!!!!
Originally posted by westi
That's mad Alan.
Memberhumpty
Threads: 139
posted on February 11th, 2007 at 04:51 PM
Wot Dave said......
FUCH your early!
MemberHertz
www.melburgluft.com
Threads: 84
posted on February 11th, 2007 at 05:03 PM
Great thread:thumb
Click the Beetle
Memberkoolkarmakombi
enkarmarising
Threads: 158
Mood: do you see the bats?
posted on February 11th, 2007 at 06:24 PM
lots of us are waiting news!
kkk
MemberStanley
Threads: 270
posted on February 11th, 2007 at 07:26 PM
Sorry guys...didn't think there were that many people interested.
Well....I wanted to fit a new GT40 coil so I went and bought one only to find when I got home one of the terminals was broken. Thought about fixing it but took it back to get it replaced.they didn't have any more in stock so went to automart and to superchaep stores and they don't stock gt40s any more only the gt40r (with resistor) you believe that?.
So back home and fitted the old one wired it up and found I had spark at the right time at the right plug...whoo hoo.
Fitted a choke cable to the carb. Cheated and mounted it so I can get at it through the deck lid. It's Qld right, who needs a choke anyway.
Up to the petrol station and got some fuel back home and put some in the tank and tested all the fuel lines...all good...whoo hoo.
Reset the float level and hooked the fuel line to the SU, got the fire extinguisher ready, turned on the electric fuel pump and.............................fuel pissed out a connection which goes into the fuel bowl. took it apart and found there is a ferrul and seal missing which seals the pipe for the jet. No go fast shops a gonna keep SU parts on a Sunday. So tomorrow there is a local guy who specialises in mini's so I hope he'll have the bits I need. Maybe tomorrow.
So I have spark in all the right places and more importantly when I turned it over this morning I pulled off the drain line from the turbo and had a nice flow of oil from it. so all in all another sleppless night but all is good so far.
Memberpenguin
A.k.a.: Chris
ackkkkkk thhhhhpt!
posted on February 11th, 2007 at 07:50 PM
Sweet,
so I can look forward to this being a daily driver to the Base soon?????
MemberStanley
Threads: 270
posted on February 11th, 2007 at 07:59 PM
Only on test and tune night
Memberhumpty
Threads: 139
posted on February 12th, 2007 at 01:11 AM
Gettin' giddy ova here!!!! :lol:
FUCH your early!
MemberJeza
Threads: 23
Mood: Spinning
posted on February 12th, 2007 at 04:59 PM
Yep, also watching quietly from the back of the room....
Good work, betcha can't wait to start it up and give it a run :thumb
Jeremy
......random gibberish for today.......
MemberStanley
Threads: 270
posted on February 12th, 2007 at 07:11 PM
Well I fired it up this afternoon after getting the carb bits I needed.
All was going well until I realised although I had spar in all the right places it easn't at the right time. A small adjustment later I fired it up.
First go and away it went. Had the good turbo whine and ran ok. I need to tune the SU abit but other than that all was good.
No oil leaks (so far) and a good 40psi of oil pressure.
I've just loaded some footage onto youtube which I'll post a link to tomorrow when it clears.
Memberhumpty
Threads: 139
posted on February 12th, 2007 at 09:36 PM
Top stuff.... Brilliant news.... Can't wait for the vid....
FUCH your early!
posted on February 12th, 2007 at 09:37 PM
:tu:
You legend!!
[ Queries: 40 ] [ PHP: 3.7% - SQL: 96.3% ]
