[ Total Views: 267635 | Total Replies: 249 | Thread Id: 69847 ]
 Pages:  1  2  3  4  5  ..  9
Author: Subject:  ¨Im keeping it!¨ izac's '65 Square... Some VW pics from Peru aswell
Membercolonel mustard
Threads: 51
posted on April 5th, 2009 at 11:43 AM
Well... I may give it a blast. Im thinking dyno day would be fun/ny. :) could be sweet.
Memberizac
Threads: 39
Theme: UltimaBB Powder
posted on April 6th, 2009 at 08:55 PM
ok heres some pics with the carbs off...
http://i722.photobucket.com/albums/ww225/izac_photos/100_2786.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2787.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2788.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2790.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2791.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2792.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2793.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2795.jpg
and with some of the tin ware on.. gave the case a clean with some oven degrease and kero and looks a lot better.
http://i722.photobucket.com/albums/ww225/izac_photos/100_2796.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2797.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2798.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2799.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2800.jpg
Memberizac
Threads: 39
posted on April 6th, 2009 at 08:58 PM
does anyone have any ideas on cleaning the ports up on the heads? they look pretty dirty/ gritty..
Threads: 51
posted on April 6th, 2009 at 09:13 PM
Use solvent (workshop solvent is clear and kinda like petrol but dissolves grease and other crap) or carby cleaner. use can use it all over the engine as long as you dont run it for a few hours to be safe. it evaporates within a few minutes. solvent is very good... cleaned many gearboxes and rocker covers at mazda with it. :) looking good mate.
Memberizac
Threads: 39
posted on April 8th, 2009 at 09:00 PM
thanks man yeah i used a bit of kero on them which seemed to work alright.:rolleyes:
got the parts yesterday! o h yeah now the fun begins... :cool: i love parts stashes
http://i722.photobucket.com/albums/ww225/izac_photos/100_2801.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2802.jpg
started a mock up of carbs on the manifolds on one side of engine...
http://i722.photobucket.com/albums/ww225/izac_photos/100_2803.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2804.jpg
do i locktite these studs to the manifolds or what?
http://i722.photobucket.com/albums/ww225/izac_photos/100_2805.jpg
the throttle shaft spring/ butterfly opener mechanism was just catching on the manifold so had to do some clearancing with the file...
http://i722.photobucket.com/albums/ww225/izac_photos/100_2806.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2808.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2809.jpg
went to test fit tops and air filters but there is a thing sticking up that stops the air cleaner base plate from sitting down flat...
http://i722.photobucket.com/albums/ww225/izac_photos/100_2810.jpg
cant see it in the dellorto tech book.. does anyone know what its for? or hjow i can get it off?
Threads: 51
posted on April 9th, 2009 at 08:22 AM
is the one of the sticky up things on each carb??? can you swap the plates around to find a hole for it..... might just be a silly thing that you missed...
Memberizac
Threads: 39
posted on April 11th, 2009 at 10:54 PM
getting close
ok have finished bolting it all together tonight... now just have to adjust linkage and add the fuel lines and shes ready to go.
changed the venturis over to 28mm from 32mm and set idle and mixture control so hopefully the jetting will be ok
http://i722.photobucket.com/albums/ww225/izac_photos/100_2814.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2815.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2818.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2819.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2820.jpg
regarding the chokes i dismantled them and then screwed the cover piece back on seperately to cover the hole
http://i722.photobucket.com/albums/ww225/izac_photos/100_2816.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2817.jpg
Membermatara
Threads: 255
Mood: 356'd
posted on April 11th, 2009 at 11:04 PM
If your converting to beetle axles can we get some pics of that too please!
Memberizac
Threads: 39
posted on April 11th, 2009 at 11:08 PM
yep sure Steve. il make sure i take some when i get around to doing them.:)
MemberPeter_D_C
Threads: 20
posted on April 15th, 2009 at 11:33 AM
Lookin good Izac. let us know how she goes with the dells. Saw you drive past on Kelvin Grove Road a number of weeks back. I was stuck in traffic going the other way.... :(
1969 Type 3 Squareback
Memberizac
Threads: 39
posted on April 16th, 2009 at 08:09 PM
im suprised i didnt see you if you were in the square... hope i get to see it in the flesh one day. will let you know how the dells go when i get it back in the car :cool:
posted on April 16th, 2009 at 08:21 PM
Why would you do that?? :crazy:
Threads: 51
posted on April 16th, 2009 at 08:25 PM
cause its a 1500....
Memberizac
Threads: 39
posted on April 16th, 2009 at 08:51 PM
i think there is more chance it will run smoother with the 28mm vents rather than the 32's as it is only a stock engine with the stock cam. we'll see how it goes and if it is too tame i might switch to the 32s then..
what do you think?
Threads: 51
posted on April 16th, 2009 at 08:53 PM
well.... its a stock motor..... you will kill it if you give it too much. then you can go all out. YAY!!
Threads: 51
posted on April 16th, 2009 at 08:56 PM
Also, do you ever wear closed in shoes.....:S
Memberizac
Threads: 39
posted on April 16th, 2009 at 09:02 PM
nup :no:
Threads: 51
posted on April 16th, 2009 at 09:12 PM
you havent dropped a darn mazda 3 box on your foot to learn... hahahahah.
Its looking awesome mate. I started target this week... so carbies on the list of things to do. Need to get my guitar serviced before i go north next month. Normanton here i come... :)
Memberizac
Threads: 39
posted on April 16th, 2009 at 09:15 PM
thanks man, yeah i hope to put it back in in the next couple of days
posted on April 17th, 2009 at 08:17 AM
really??
I would have thought a 1500 was a single port??
Memberizac
Threads: 39
posted on April 17th, 2009 at 09:54 PM
yeah it is actually a 1600 dp not a 1500. i think jason was just going by the original engine it is supposed to have
Memberizac
Threads: 39
posted on April 17th, 2009 at 10:02 PM
ok it is already to go back in and i have a few questions about jetting the carbs correctly for the engine...
the carbs are setup at the moment with 28mm venturis, 180 Main/air, 135 Main/Gas, 52 Idle Gas, 33 Acc/Pump.
does this formula sound alright for a mostly sock 1600?
here is the engine ready to go back in..
http://i722.photobucket.com/albums/ww225/izac_photos/100_2822.jpg
http://i722.photobucket.com/albums/ww225/izac_photos/100_2825.jpg
also what do i do with this pipe coming from the oil filler that originally went to the oil bath air cleaner?
http://i722.photobucket.com/albums/ww225/izac_photos/100_2821.jpg
fuel lines done
http://i722.photobucket.com/albums/ww225/izac_photos/100_2824.jpg
is this fuel filter suitable?
http://i722.photobucket.com/albums/ww225/izac_photos/100_2823.jpg
blocked off the right side double banjo with a screw with a piece of fuel hose and a hose clamp..
http://i722.photobucket.com/albums/ww225/izac_photos/100_2827.jpg
planning to put it back in tomorrow so we'll see how it goes!
Threads: 51
posted on April 17th, 2009 at 11:13 PM
Eh. I thought you told me it was a 1500..... nevermind.
Is that fuel line the same as the original??? I much prefer the genuine stuff.... i think it lasts longer... If the filter ends fit in the lines.... your all sweet. that filter is from a carby laser/323 :)
looks good. why dont you paint your exhaust while its out?
Membermatara
Threads: 255
Mood: 356'd
posted on April 17th, 2009 at 11:21 PM
Put some wire on those fuel lines whilst you can. Last thing you want is one of them slippling off (especially if its had E10 in it).
Looking good
Threads: 51
posted on April 18th, 2009 at 06:57 AM
Wire??? I'm failing to know what you mean by that....
Izac, you could put a breather box off the oil line... Of a breather of some kind. Don't block it off.
I can probs get you one second hand for cheap...
posted on April 18th, 2009 at 08:05 AM
"my opinion" for a 1600 i would have left the 32's in there
If is also Jon from ACnet's opionin as well
1600 Option - http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=FSK0020&c...
"We will configure your dual 40 or 44 IDFs for optimum use. We change the venturis to 32mm, and rejet the idle, main, and air jets for this price"
For some reason others promote 28 in there but i have never seen a set run properly set up that way
Main should be 4 to 4.2 x the venturi size
so .........
28 = 115 main
32 = 130-135 main
Airs - add 50-60 to this
Idles is what your engine wants
My webers wanted 45's
Personally i reckon 52's is a tad big - when you find "best lean" you wont turn out as far.
See how that goes - maybe the idles wont block up as much as mine did
So - your jets are set up for 32 venturis not 28's
You should either change back or get some different main jets and air jets
Have a read here as well
http://www.aircooled.net/gnrlsite/resource/articles/jetting.htm
Get your self a goos synrcometer as well
like the "new style" one listed here
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=TZE0021&c...
then read here
http://www.aircooled.net/gnrlsite/resource/articles/dualcarb.htm
Have fun
Memberizac
Threads: 39
posted on April 18th, 2009 at 01:20 PM
thanks for your help Bizzare
i am considering changing the vents back to 32s before i put it in... so you dont think 32s with this jetting combo will be to much for the little whippersnapper do you?
thanks Steve, i will pur some zip ties round the fuel lines if thats what you mean..
Memberizac
Threads: 39
posted on April 18th, 2009 at 01:22 PM
jason, no the fuel line is just rubber hose not the original braided fuel line unfortunately
Threads: 51
posted on April 18th, 2009 at 01:55 PM
Would you rather the rather the genuine fuel line?? Its only like $8 a meter... Its heaps better for VW's IMO.... I used the single braid/ double rubber line for a few months, and its not really that great... but lucky its not a huge deal to change it over. Was I right about the filter??? (im sure its the old KE model filter...)
http://media.share.ovi.com/m1/large/0740/33320e113e8c4103bd17f151677ee721.jpg this is what im going to have for my oil breather setup ..... im going a bit different to usual, its not going to vent the tappet covers, just from the filler and one air cleaner.... cheap and easy :)
posted on April 18th, 2009 at 06:37 PM
not at all - i ran that exact set up on a 1600 and a 1776 with excellent economu and performance
