[ Total Views: 9099 | Total Replies: 211 | Thread Id: 78253 ]
 Pages:  1  2  3  4  5  ..  8
Author: Subject:  Sid Vicious the soon to be volksrod
MemberDirtbag
What the hell does standard mean?
Threads: 22
Mood: boobtastic
posted on August 22nd, 2009 at 01:48 AM
Thanks go to Glen for ordering our 2 sets of beam adjusters. They arrived today. I'm going to do a narrowed adjustable beam for "Jack" the '68 semi auto beetle and a standard width adjustable beam for Sid. Can't wait.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 23rd, 2009 at 06:39 AM
Here's old Sid with the new decklid and the rear guards and running boards removed.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 23rd, 2009 at 06:41 AM
It's a bit annoying that progress at the moment is so slow but I hope it will pick up in the next week or two.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 23rd, 2009 at 06:42 AM
Here's a bodgy bug selecta picture I then volksrodded in photoshop. It gives some idea as to what I'm aiming for.
Member11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on August 23rd, 2009 at 07:00 AM
Great job on the decklid
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Memberdonovan
Threads: 37
posted on August 23rd, 2009 at 07:18 AM
nice work with bugselecta and photoshop. didnt quite capture the crustyness that is "sid blue"
now lets see the real thing. i say take the week off work and do it.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 24th, 2009 at 04:24 PM
Thanks again 11CAB for the decklid. Looks a bit different now hey? : )
I haven't been able to do much lately but today I ordered my new hubcaps and white wall inserts from classic vee dub. I figured I'd better get the wheels ready so at lunch time today I wire wheeled one of the back wheels down to metal. Took ages, sucky job. I think donovan should come over and do the other 3 : ) Oh well, it's a start. I've also tracked down some 235/70/15 tyres to squeeze on the back. Should have a good rake with the little cheese cutters on the front.
Hopefully tomorrow I can get the other back wheel cleaned up, then I can chop the front wheels up and change the offset like I did on "Jack" the '68.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 25th, 2009 at 05:28 PM
After cleaning the back wheels inside and out they got a coat of two of etch primer.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 25th, 2009 at 05:30 PM
Once the etch dried I gave the insides a few coats of 2 pac Holden Sting Red. It's left over from a previous job, so I figured I may as well put it to use. Tomorrow I'll do the outsides, then I can look at the front wheels.
Membercolonel mustard
Threads: 51
posted on August 25th, 2009 at 07:09 PM
Thats a nice red there. How did you apply the finish? Do you have to clear coat them afterwards???
What other project car have you got going there?
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 25th, 2009 at 08:35 PM
Hi colonel. I just used a 1mm touch up gun to paint the wheels. Being so small it didn't seem worth loading up a full sized gun. As for clear coat, no, this is a one step colour, not a COB (clear over base) process. I don't usually bother with clear on solid colours. I leave the clear for metallics and pearls etc.
The car in the background is a 1963 Pontiac Bonneville 2 door. It's in for a LOT of work. It's very rusty and it's getting modified a bit too. It'll be running 20x14 rear wheels.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:20 PM
Here's the back wheels with a coat of red on the outsides. Now I can turn my attention to the front wheels.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:23 PM
Luckily for me I had one of my best friends Keith come over today and he wire wheeled my front wheels after I'd cut the centres out. What a bloody legend. I cut the centres out so I can weld the centres back in with less dish. I actually want the centre of the wheel to stick out past the edge of the rim. This is mainly to make the back wheels look bigger than they actually are. Plus, I like cutting and welding things : )
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:28 PM
Here's one wheel welded. I put one of the back wheels next to it so I could see the offset difference. The front tyres will only be 165's, but the rear will be 235/70/15s so should have a good hot rod rake.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:30 PM
If you're going to try this yourself, make sure your welder has the guts to get the penetration needed, other wise just leave them alone. Too dangerous.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:32 PM
This weld isn't too pretty, but it sure as hell isn't going anywhere.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:35 PM
Once cleaned they got a bit of etch primer. The wheels look a bit weird now with the strange offset, but I did the same modification to Billybobs '68 and once the hubcaps went on they looked great.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:36 PM
Some more red. I'll do the outside of the front wheels tomorrow, then they're all finished.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:39 PM
No turning back now. I decided the time was right to lop the back end off. I really need to get a better looking exhaust. I've posted a wanted ad on this site. Can anyone help me?
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 03:42 PM
Well unfortunately I probably wont get any more done until I've moved the shop to caloundra, as I want to have the beetle in the shed before I rip the front end out. Fingers crossed it wont be too long. It's really starting to bug me (pardon the pun) that I can't just get right into the build of this thing. Oh well, I'll keep you posted.
Threads: 51
posted on August 26th, 2009 at 03:54 PM
Hey dirtbag, have you still got the bumpers and brakets floating around? Can you tell me the condition of these items..... :)
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 04:28 PM
Hi colonel. The guy I got the car from still has the bumpers and brackets, as we knew I wouldn't be needing them. Sorry mate.
Threads: 51
posted on August 26th, 2009 at 05:33 PM
Dang it. is it the original front one.... totally chasing genuine german front bumper with the indicators in the bar.... the search continues. Car is looking really good mate, not my thing, but interested to see where it goes. keep it up :)
Memberglencsiro
Threads: 22
posted on August 26th, 2009 at 08:55 PM
CG
Hey mate, love the work and progress your making on your volks, I quickly knocked up a render from a model I made for my own project.
http://img132.imageshack.us/img132/1179/sidaee.jpg
http://img132.imageshack.us/img132/9716/sid2.jpg
http://img22.imageshack.us/img22/4708/sidside.jpg
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 26th, 2009 at 09:30 PM
Hey Glen, nice work. You read my mind!!!! I've even been looking for tail lights like that. Give it some bigger back wheels and some old dodgy 40's bullet headlights and that's exactly what I'm trying to build. Bloody nice work on the rendering. I have no idea how you do that, but I like it : )
Memberdonovan
Threads: 37
posted on August 27th, 2009 at 08:48 AM
Gday GlenCSIRO,
My son is a 3D animator and loved your 3d model. He was just wondering if you could email him the exact VW model (with no wheel-wells) to him in either 3ds. lwo, or C4d format?
He said he used cinema 4d, and wants to do some stuff with it.
His email address is lukehedges1@yahoo.com
Thanks in advance.
Don
Memberglencsiro
Threads: 22
posted on August 27th, 2009 at 04:48 PM
Hey mate, do you have any reference pics for 40's headlights, not sure exactly what they look like.
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 27th, 2009 at 05:06 PM
Hey Glen. There is a pic of the actual headlights I'm using on page 2 of this thread. They're from an early 40's commercial.
Memberglencsiro
Threads: 22
posted on August 27th, 2009 at 05:33 PM
You want them forward or level with the front wheel axle and are you happy with the blue or do you want to experiment with colour or rat rust any ideas?
MemberDirtbag
Threads: 22
Mood: boobtastic
posted on August 27th, 2009 at 05:56 PM
Hi Glen. The lights will either be in front of or on top of the shock towers. I wont know for sure until I've extended the front and can eye ball it both ways.
As for colour, I think your blue looks awesome, but the paint on Sid is what I'm keeping. I'm even going to paint match it in where the guards were and on the new decklid - complete with crusty stripe of course : ) The rear quarter panel on the drivers side will also ge a blow over with some crap blue to cover all the primer that's on that panel. Other than that, the paint and panel work is finished : ) Hooray for rat rods!!!
[ Queries: 40 ] [ PHP: 7.7% - SQL: 92.3% ]
