| [ Total Views: 19744 | Total Replies: 164 | Thread Id: 78992 ] |
| Pages: 1 2 3 4 5 6 |
20bkombi
Threads: 26
| posted on May 16th, 2010 at 12:53 PM |
Thanks Guys and gals, and Troy for the pic's.
I've been a little busy lately in the shed. It was time to fit bigger tyres, this ment moving the spring plates inboard 75mm and an entirely new air
bag
arrangement inboard of the chassie, modifying the trailing arms, brake lines, thottle cable, radiator pipes, barrel cooler pipes, 1 fuel pump, filter
and lines.
Oh the oil cooler lines and all the wiring that you forget thats under there.
So much work just for 50mm more tyre each side. The tyres are Micky Thompson ET Street radials 275x50x15, which measure 295mm o/a not like my old
235x60x15 that measure 235mm o/all.
I didn't think how good it would look with such big rubber, i was thinking more traction, more traction.
This brings wheelie bars to to mind. So i borrowed next doors to see where i could mount them.
They are just sitting there in the photo.
The exhaust has an electric butterfly mounted near the rear of the race pipe,(4''). The standard exhaust no longer goes forward around the
transmission
and back. Now is comes straight off the race pipe near the turbo using 3'', under the scatter shield (bellhousing) 90' in to a 20''x 11''x
6'' tri pass muffler
exit through 4'' tip. 800mm of pipe in total.
This means i have 2x 4'' exits and 1x 3'' wastgate exit. The ability to have full power without excessive back presure and only have to change
sparkplugs on race days.
Now i'm working on a new shifting system.
While Troy is moving house his lathe is being stored (used) in my shed. First job done, machine alternator pully central, second job?????
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
| posted on May 16th, 2010 at 05:17 PM |
hey aaron, weres the pics of the first lathe job
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 16th, 2010 at 07:26 PM |
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 16th, 2010 at 07:27 PM |
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 16th, 2010 at 07:29 PM |
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 16th, 2010 at 07:31 PM |
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 16th, 2010 at 07:33 PM |
i have posted these for aaron so he can now comment on what he has done in the above pics
20bkombi
Threads: 26
| posted on May 16th, 2010 at 07:54 PM |
Thanks for the pics, the first two are of the alternator pully which never ran true. now the v groove is a bit deeper but now centre.
The other is of the gear shifter bushes and short shift modification for the new rod system, no more cables (yay!!!).
Ph 0402 233 027
20bkombi
Threads: 26
| posted on May 30th, 2010 at 07:49 PM |
Well Bec and I were ment to be at a car show today for a sunday cruze and some dyno fun but,
I went out last night to check every thing was right. While under full throttle 3rd gear the boost went sky high!!!!! 20+psi
So i took some data the next run and wound the air reg down to 0 = 10pound (spring presure only).
Straight up again, and i couldn't back off quick enough, then it did two big back fires and stalled.
The problem with such a big turbo is when is comes on it does so, MEGA quick. This high boost causes high heat on these
tiny seals and they weaken, causing then to bend or break.
The fault was a rip in the wast gate, which controls turbo presure.
Ph 0402 233 027
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on May 30th, 2010 at 09:35 PM |
so rotor housings suffer any damage?? Rotors ok ? Or just some new seals etc etc??
20bkombi
Threads: 26
| posted on May 31st, 2010 at 05:37 PM |
Sad to have to open it up. Looking at the wear it was not even 1/4 of its life.
This would be the cleanst engine i have pulled down yet.Every thing is just as it was 3 years ago. I will replace the corner and side seals with after
market ones, as there were only
mazda (i hate that word!!) items at the time of the build.
This means i will have (South Coast Rotary) SCR 3yr old apexes, new SCR side and corner seals. All with new factory springs.
All up $450
Ph 0402 233 027
| posted on May 31st, 2010 at 05:39 PM |
Well kinda of a cheapish rebuild of sorts considering the punishment it gets every now and then ....
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 31st, 2010 at 05:52 PM |
gee aaron, i wish i could pull my engine down after that happening and only spend that much, mine would be a pile of scrap i think if that happened
colonel mustard
Threads: 51
| posted on May 31st, 2010 at 06:13 PM |
| Quote: | Originally
posted by 20bkombi
I will replace the corner and side seals with after market ones, as there were only
hmmm you and me both.
20bkombi
Threads: 26
| posted on May 31st, 2010 at 06:54 PM |
This is the 2nd wast gate diaphrame I have split in 4 years.
So, It will be changed every 2yrs from now.
from this
to this
to this
Ph 0402 233 027
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on May 31st, 2010 at 06:56 PM |
WOW..... glad you labelled the Dril.......
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
20bkombi
Threads: 26
| posted on May 31st, 2010 at 07:09 PM |
Just checking youre looking, but it's a drill not a dril im a dill.
I use it for the sump bolts.
Ph 0402 233 027
colonel mustard
Threads: 51
| posted on May 31st, 2010 at 07:27 PM |
Hey Aaron, are they all genuine 20b bits? (i remember that the housings are... but the other bits too?)
20bkombi
Threads: 26
| posted on June 1st, 2010 at 09:44 PM |
Yep all factory 20b parts, only the dowells apex seals, and balancing of the rotating assembly.
But, all the springs and inner, outer oil control rings are from 5 different rotary engins for different reasons.
This is the twin plate clutch, will try and grind it on the lath.
Ph 0402 233 027
reub
VWRX is gone...
| posted on June 1st, 2010 at 09:45 PM |
Dude, out of interest, what is the assembled length of a 20b?
Reub
20bkombi
Threads: 26
| posted on June 1st, 2010 at 09:51 PM |
600mm in from pully nut, to end plate.
And the g64-21 is 950mm
I think it would be to heavy for a beetle. What u think'n?
Ph 0402 233 027
reub
VWRX is gone...
| posted on June 1st, 2010 at 09:54 PM |
cheers dude... Thinking you're right - unless mid mounted?
They that heavy? 130-150kg or so?
Reub
20bkombi
Threads: 26
| posted on June 1st, 2010 at 10:03 PM |
I think just the block is that. I'll weigh it and the tranny befor they go back in.
I've measured the notch and it fits with 100mm gap behind the front seats. (YOU CAN DO IT MAN!!!!)
Ph 0402 233 027
reub
VWRX is gone...
| posted on June 1st, 2010 at 10:06 PM |
Love your work dude. Can't wait to see vid of it out with the new rear bags.
Reub
20bkombi
Threads: 26
| posted on June 1st, 2010 at 10:31 PM |
This is now
Long way to go!
Ph 0402 233 027
| posted on June 2nd, 2010 at 07:46 PM |
Aaron like i have said before You are a machine!!
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on June 2nd, 2010 at 07:56 PM |
hey aaron that empty engine bay looks like my car...haha
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on June 2nd, 2010 at 08:48 PM |
Hope all goes well on the rebuild Aaron.
20bkombi
Threads: 26
| posted on June 3rd, 2010 at 04:48 PM |
Thanks. The rebuild Won't be for a while, I have other work to get out the way first.
Alsow I want to do more on the ports.
The gear box will be getting pulled down this weekend to try some syncro
mods for better shifting.
Ph 0402 233 027
13b type 3
Threads: 3
Mood: happy
| posted on June 16th, 2010 at 10:37 PM |
| Quote: | Originally
posted by LIFE IN THE LOW LANE
Yes he sure is but that machine has no stop or pause button on him.
next week at the lastest i rekon and it will be driving down the road again.
determination
