| [ Total Views: 7367 | Total Replies: 78 | Thread Id: 83840 ] |
| Pages: 1 2 3 |
cb john
Threads: 6
| posted on May 30th, 2010 at 06:14 PM |
Here is the promissed photo of the device...
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on May 30th, 2010 at 08:13 PM |
Thanks John, but rather than a 'Band-aid' fix, I will most probably be using Type 3 drums (genuine VW ones).
The chassis is OK and so are most of the suspension bits. Engine and gearbox look good - not even a bent axle.
A roll cage is a definite for the re-build!
Cheers, Greg
71-BEETLE-SEDAN
AKA Josh
Threads: 108
| posted on May 30th, 2010 at 08:53 PM |
I noticed all three mirrors are all good two greg,
cb john
Threads: 6
| posted on May 30th, 2010 at 09:15 PM |
| Quote: | Originally
posted by HappyDaze
Cheers, Greg
That's OK Greg, this applies to F Vee only, because of regulations...they can not use other than type 1 components../ as you would know /
chequer57
Threads: 15
Theme: UltimaBB Psyche Red
Mood: Moody
| posted on May 30th, 2010 at 09:26 PM |
| Quote: | Originally
posted by johny rotten
not many 1200 / drum brake vees running any more
most are 1600cc disc brakes etc now
Yes most Formula Vee cars have gone to disc packages even many of the 1200's. The Historic guys still run drums and the other "problem" we battle
with is left stub axles .... this we solve be bolting through the speedo cable hole.
Regards,
Ian
Formula Vee, preserving engineering museum pieces in Australia since 1964
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on May 30th, 2010 at 09:49 PM |
| Quote: | Originally
posted by HappyDaze
Cheers, Greg
A VERY smart move Greg.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on May 31st, 2010 at 07:06 AM |
| Quote: | Originally
posted by 71-BEETLE-SEDAN
Yeah Josh, that's so that I can LOOK BACK on all this and say "What a great bunch of people the VW crowd are - all those offers of help, and good
wishes were very much appreciated".
Cheers, Greg
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on May 31st, 2010 at 07:17 AM |
| Quote: | Originally
posted by chequer57
| Quote: | Originally
Regards,
Ian
I know Vees need to comply with the rules, but as I CAN up-grade, the stronger drums are a better option.
Thanks for the stub-axle-bolt tip Ian, I like the idea.
Cheers, Greg
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
| posted on May 31st, 2010 at 08:33 AM |
May I ask why your not going to go to rear discs?
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on May 31st, 2010 at 08:52 AM |
| Quote: | Originally
posted by trickysimon
Just 'Oldschool' stubbornness, I suppose!
Camo
A.k.a.: Kev
Threads: 209
| posted on June 6th, 2010 at 09:06 PM |
Hi all,
Greg Mackie has sent me these photos and asked me to post them up. These are obviously photos of his fractured brake drum/hub. I will just explain
that Greg has manufactured and fitted a cooling system to the drums to radiate heat, hence the cooling vanes.
You will also see the baking plate is extensively bent fromt he fractured hub, yet has not caused any damage to the axle or the axle tube.
Regards, Kev
HotRodMatt
If it's old or rare - cut it!
Threads: 361
| posted on June 7th, 2010 at 08:56 AM |
Im guessing that the outer ring and vanes are aluminium and an interference fit to the drum?
sander288
"Bolt-on Master"
Threads: 183
| posted on June 7th, 2010 at 11:59 AM |
The rings I know are aluminium, as far as I know from what greg told me they are just heat shrunk onto the drums.
Someone correct me if i'm wrong though..
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
Correct guess! The cast aluminium rings are machined to suit the drum O.D., -0.035". Drums do not need to be machined.
The first time I did this mod. was in 1962 and it kept the drums nice and round, as well as improving the cooling.
If I had known about Frank Klienig's ' safety disc ', there may have been a better result when the drum collapsed, perhaps?
Cheers, Greg
HotRodMatt
Threads: 361
| posted on June 7th, 2010 at 12:47 PM |
| Quote: | Originally
posted by HappyDaze
Cheers, Greg
No chance to research it yet or run it past some metalurgists but I'm wondering about the thermal expansion rates of the aluminium vs the steel. The
aluminium would also be sitting at a different temp to the steel so even if the expansion rates are the same there would still be a difference in the
growth of the metals.
I've seen similar set ups on drums that end up glowing red during racing, but the finned metal has always been the same as the drum.
I'm curious if your drums would ever get hot enough that the aluminium starts to "choke" the drums expansion. Even still, I would expect the
aluminium to fail before the steel stresses excessively in the middle.
Just thinking out loud...
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on June 7th, 2010 at 01:52 PM |
For a start the drums aren't steel, they're cast iron. As aluminium expands at a greater rate than iron, the ring would probably be more likely to
come loose than 'choke' the drum.
I ran that set-up for many road and race miles in the early '60s on a Beetle (100MPH stops at Bathurst, Warwick Farm etc.) without a single problem.
Also the present car has done almost 4 years of racing, on the original (50 years old) drums, with the fins fitted, without any trouble. The drum that
failed was brand-new Zimmerman, fitted for the Nats. Supersprints
Cheers, Greg
HotRodMatt
Threads: 361
| posted on June 7th, 2010 at 04:37 PM |
Just a thought Greg. Got anyone lined up to look at the shards?
Had a metallurgist look at some failed "forged" name brand pistons which turned out to be simply cast and hot pressed on the crowns. I think you
might find some rather ordinary casting in those drums.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on June 7th, 2010 at 07:29 PM |
'rather ordinary casting' is probably being kind, Matt. A friend of mine has been in the industry for many years, and he will be 'checking it out'
for me. This could take a little time, but meanwhile it is important for us to think carefully about the 'repro.' bits that we are using. I
certainly have learned a lesson from this.
Cheers, Greg
vlad01
Mood: Side ways
| posted on June 21st, 2010 at 03:46 PM |
geez this is scary. life relying of a piece of cast iron.
71 notchback,
| Pages: 1 2 3 |
