[ Total Views: 110795 | Total Replies: 189 | Thread Id: 87437 ]
 Pages:  1  2  3  4  5  ..  7
Author: Subject:  59 11 window Custom Resto
MemberSpecial Air Service
Chief "Gunna"
Threads: 210
posted on January 11th, 2011 at 01:27 PM
Al,
Couple of questions re. the fibreglassing.
When you building the stuff like speaker panels etc
What weight matting do you use?
How many layers of matting / glass do you build up?
Do you use waxed or normal un-waxed resin?
Oh yeah, awesome work on this bus, giving every one a few new ideas I reckon.
Brendan
[size=5]
Click Below
[/size]
[size=6]
Mid North Coast VW
[/size]
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on January 11th, 2011 at 09:29 PM
G'day Brendan, generally I use 450 weight chop mat in areas needing some strength:http://www.fgi.com.au/files/images/stories/pdfs/products/reinforcements/data_sheets/24969-CSMM705Emulsion.pdf
Anywhere from two layers if strength is not needed up to 6 or even 8 in some sub box applications where I can't afford any flex.
I can't recall the exact resin however given it sands fairly easily and doesn't gum up I would say it would be waxed. Will have to check.
This is where I get the f/g products from:
Al
posted on January 11th, 2011 at 10:05 PM
Waxed goes off on the surface so is'nt sticky to touch but therefore needs sanding between layers if allowed to cure, whereas unwaxed stays sticky and no sanding required for the next layer (supposedly, but I believe at least a scuff is required).
Not trying to be a smart arse tho.
Awesome job Al and the crew at Das Resto Haus.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 11th, 2011 at 10:15 PM
Cheers Matt, much appreciated.
Brendan, will check the label tomorrow as I just go in and order the same product (20L at a time) - the rep knows what I use it for and hence gives me the requried stuff :)
I figured it wasn't a laminating resin (unwaxed) but haven't used the term waxed before when ordering the resin previously.
Al
More pics:
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23rearcorners.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23rearcorners2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23rooflining1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23rooflining2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23rears2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23fronts.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23update2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov23update3.jpg
Memberwilderness
Threads: 10
Mood: buggeriffic
posted on January 12th, 2011 at 01:32 PM
:tu::tu::tu:
1958 Beetle (currently restoring)
Mk5 Golf Pacific TDi
Memberbugboymatt
A.k.a.: Matt
Threads: 75
posted on January 12th, 2011 at 01:53 PM
WOW, just looked through this thread. Very very nice.
Great work as ever from Al.
Chief "Gunna"
Threads: 210
posted on January 12th, 2011 at 06:21 PM
Thanks Al,
Appreciate you taking the time to answer my questions as you go through this build.
Brendan
[size=5]
Click Below
[/size]
[size=6]
Mid North Coast VW
[/size]
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 19th, 2011 at 10:03 PM
Originally posted by 5PL1TDCS10N
Are you going to add the fine line around the inside of the curved banner Al?
G'day Wayne, hopefully we'll get the fine line integrated into the CNC cut logo - haven't had a chance to ask why it was omitted on the pictured prototype. Should look very nice polished.
A few more details....
Third brake light was integrated into the engine lid to match the indicators in the bumpers.
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov29enginelidmod6.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov29enginelidmod4.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov29enginelidmod5.jpg
A fair bit of time was spent designing and fabricating the LED mounting plate
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov29enginelidmod3.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov29enginelidmod2.jpg
The extra hole above the number plate will be fore the reversing camera (would be an expensive dent if Armando reversed into something) :)
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Nov29enginelidmod1.jpg
My first prelminary map of wiring for the bus (not including audio system!)
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec3prelimwiringdiagramprogress.jpg
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 19th, 2011 at 10:08 PM
After a couple rounds of high build primer and block sanding the roof was prepped for paint
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec4roofwetrubbed1.jpg
The direct gloss (PPG Deltron) white was applied first - sorry these roof pics are a little blurry
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec4roofpainted1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec4roofpainted2.jpg
This was then guide coated and wet block sanded to flat it out and rectify any imperfections/nibs/dust....then clear coat was applied
A quick shot of the rear bumper during the measurement process to get indicator positions equal
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec6rearbumperindicatormods.jpg
Cheers again
AL
MemberAussie
Threads: 43
posted on January 22nd, 2011 at 08:10 AM
:tu: Super straight. Great job
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 22nd, 2011 at 08:38 PM
A few more photos....first of the fuse holder cover (that will supply power to the two amps) - obviously will be painted
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec13amplifierpowerfusecover.jpg
And the EFI relay holder cover
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec13relaycover.jpg
Lots of time wet block sanding the primer
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec13wetrubbedpanel1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec23doorwetblocksand.jpg
Ready for red
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec30preppedforpaint2.jpg
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 22nd, 2011 at 08:42 PM
When I am not going for an "off the gun" finish knowing the paint will be block sanded, I tend to apply it a little dryer to avoid runs - the orange peel cuts out fairly easily when blocked with 800 then 1200 wet.
The PPG Deltron direct gloss red
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec30red1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec30red4.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec30red5.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec30red2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec30red3.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Dec30red6.jpg
Al
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 22nd, 2011 at 09:40 PM
Yummy:tu:
MemberCamo
A.k.a.: Kev
Threads: 209
posted on January 22nd, 2011 at 10:01 PM
I've said it before and I will say it again, this is pure artwork and I hope you are going to sign it as all good artist do :tu::tu::tu::tu::tu::tu::tu::tu::tu::tu:
Kev
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 29th, 2011 at 08:26 PM
Cheers Craig and Kev :)
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan4bodyguidecoated.jpg
Bumpers primed
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan4bumpersprimed.jpg
Before the white could be applied, the small area of red on the lower part of the swage line had to be rubbed (the red was taken up to this point and not masked to the cut line as its virtually impossible to get a straight mask on the underside of the swage).
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan5beltlinesanding2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan5beltlinesanding1.jpg
More red on the panels
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan5cargodoorspainted.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan5doorspainted1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan5doorspainted2.jpg
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 29th, 2011 at 08:30 PM
The deluxe trim was then reinstalled to ensure the two tone cut line was parallel especially on the nose
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan6beltlinetrim1.jpg
White guide coat was to assist with wet rub of red areas prior to clear
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan6beltlinetrim2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan6beltlinetrim3.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan6beltlinetrim4.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan7panelson3.jpg
Prepped for white direct gloss
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan10prepped1.jpg
White going on
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan10white1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan10white2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan10white4.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan10white5.jpg
Al
MemberannosL
Threads: 43
Mood: need to win lotto
posted on January 30th, 2011 at 12:39 AM
amazing pics, shows top-drawer skills, thanks for sharing
Memberbaghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on January 30th, 2011 at 04:43 PM
OMG. Just got on after a break ans saw this amazing build. Wish I had half the skills you guys had. Love the interior work especially. Thanks for sharing.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 31st, 2011 at 05:51 PM
Thanks annosL and baghall :)
Demasked and ready for the next process of wet block sanding the entire exterior to flatten the direct gloss colour in preparation for clear
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan12innerarchespainted.jpg
Lots of masking just to paint the inside of the wheel arches - these couldn't be painted when the underside was done as the side panels and doglegs had not been bodyworked yet (shrinking etc required)
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan12masked.jpg
The number of times we have sanded this bus is pretty crazy but that is the labour required to achieve a deep show quality gloss - here the nose has been rubbed with 800 then 1200 by hand block (wet)
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan13wetrubbed.jpg
The bumpers received some white direct gloss as well
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan19bumperspainted1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan19bumperspainted2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan19bumperspainted3.jpg
Member11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on January 31st, 2011 at 05:57 PM
Who wants to open their chrissy pressy??.......
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
MemberGolde60
Threads: 73
posted on January 31st, 2011 at 07:07 PM
I dont think I could afford too!
even though, I think it would be worth every penny!
great job Al
and congrats on the logo - looking good now that I see it in the final form.
Membervwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on February 1st, 2011 at 07:40 AM
very nice al, i remember painting flockes splitty two tone, sooooooo much work involved isnt it!
bet you are sick of masking up stuff
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
MemberTurbo54
Mood: Boost'n
posted on February 2nd, 2011 at 06:32 AM
Killer job Mate,
T54
C'mon kids gather round,
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 2nd, 2011 at 09:43 PM
Thanks gents. Steve you are right, we have both sanded and masked this bus what feels like a hundred times!
The PPG Deltron D800 clear was applied next - again with a bit of peel to ensure no runs - fairly easy to block out during colour sanding.
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan20clearcoat1.jpg
The booth lights always make the orange peel look worse than it does in natural light (in the next pic below)
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan20clearcoat2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan21cargodoorsoutside1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan21cargodoorsoutside2.jpg
MemberFlintstones
Threads: 69
posted on February 2nd, 2011 at 10:35 PM
nice work there Al:tu::tu:
that's not the cyclone in the reflection is it:!::?:
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 2nd, 2011 at 10:40 PM
Haha...just the very tail of it maybe - it is a big, nasty sucker up there!
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 12th, 2011 at 08:17 PM
The body before clear:
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan22bodypreppedforclear1.jpg
and after clear was applied:
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan22bodycleared1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan22bodycleared3.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan22bodycleared4.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan22bodycleared5.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan22bodycleared6.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan22bodycleared7.jpg
I intentionally lay the three coats of clear on fairly dry to prevent any runs as the orange peel is much easier to cut out and buff than runs (esp on the edges of all the vents)
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 12th, 2011 at 08:43 PM
The colour sanding process is where all the previous year's worth of work is realised and demonstrated - it is a very labour intensive process especially when all the cutting is done by hand (1200, 1500, 2000 grits) rather than by DA sander (I only use 3000 grit Trizact pads on a small orbit DA for the final step before buffing starts) - buffing cuts the scratches out (quite a long process to get right), then swirl remover to remove any holograms....and finally a wax.
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan29rightrearcornercoloursand2.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan29rightrearcornercoloursand1.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan29rightrearcornercoloursand3.jpg
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/Jan29rightrearcornercoloursand4.jpg
Since still photos can often deceive (as I have seen many times in the past when photos are seen of cars vs seeing them in the flesh) so I do a quick walk around on each panel after buffing to ensure the owner (and others) that the panel work is straight (when he is not able to inspect it in person)
Here is a quick vid
http://i10.photobucket.com/albums/a145/Dasdubber/Armandos%2059%2011%20window/th_Jan29rightrearcornercoloursandinspection.jpg
Al
Memberbaghall
Threads: 131
posted on February 12th, 2011 at 09:36 PM
Looking so good in colour!
posted on February 12th, 2011 at 09:41 PM
Seriously Al you never cease to amaze me. awesome work again. :tu:
[ Queries: 40 ] [ PHP: 15.5% - SQL: 84.5% ]
