[ Total Views: 4803 | Total Replies: 66 | Thread Id: 90030 ]
 Pages:  1  2  3
Author: Subject:  Rear disc brakes.
Memberancientbugger
Threads: 191
posted on June 3rd, 2011 at 07:07 PM
Well still no reply even to my 2nd email so I'm not happy at all as my son has so far wasted all that money so the best thing I can do is no longer use Classic Veedub and tell friends to do the same thing:mad:
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on June 3rd, 2011 at 08:35 PM
Don't give up on them yet, try bleeding them again, bleeder pointing up, even take the calipers off, you must still have air in them.
The ones I have in my Ghia are great, pedal is getting better and better the more I drive it.
FAHRVERGNUGEN;
Membercnfabo
Threads: 140
posted on June 3rd, 2011 at 09:39 PM
did u try another m/c..i remember i bought a dual t1 m/c once and i could not at all bleed the rear brakes.changed back to the single m/c and it was fine....then bought another dual and all was good......
surely of all the years of vw mechanics has been going on someone would of had this problem before....hhhmmmm...im feeling u dude.....frustrating....
posted on June 3rd, 2011 at 10:29 PM
Well I had a stock system come this week with similar issues. Came to me after another shop could not get the brakes right, a stock type 3 disc/drum combo. The workshop before me had sleeved and rekitted the m/c and overhauled both front calipers. The car had only rear brakes operating with a dangerously low pedal. I thought ...easy, bleed, sus out, replace with a new Ate m/c and bleed, bleed, bleed.....we pressure bled, vacuum bled, manual bled, manual bled under vacuum, nothing we did could get the air out !!! The master seemed low in output fluid but the issue ended up being air trapped in a caliper, as the caliper o/haul was sus, I threw on a new pair of calipers and the pedal was awesome in about 4 pumps !!!! The caliper that had the trapped air was inspected and nothing unusual was found!!! No blockages or dirt of any kind!! Go figure !!!!
In 25 years of Volkswagen repairs I've not had this happen before?%*#???:dork:
Memberancientbugger
Threads: 191
posted on June 4th, 2011 at 09:43 AM
We will have another attempt down the line when we have a bit more patience as Mick is now happy that at least he can use his car. My gripe now is with Classic not bothering with customer relations I suppose. Anyway the m/c Mick has on his car is a new one so he'll not be in too much of a rush to buy another BTW when we were bleeding them there was no issues with low output from the calipers it was, I think as you said, the caliper capacity was more than the m/c could handle but if that is the case then the kit is only 'part' of a kit. Again as you stated Matt and I've been playing with VWs for nearly 40 years (groan!) and not had this before.
posted on June 4th, 2011 at 11:45 AM
I don't believe the problem is a mismatch of components, there are plenty of these kits worldwide without issues, I believe it has to be an air lock, most likely in a caliper.
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on June 4th, 2011 at 09:07 PM
Yep I agree Matt, my kit is fine and there are 100's of these kits out there.
FAHRVERGNUGEN;
 Pages:  1  2  3
[ Queries: 40 ] [ PHP: 13.4% - SQL: 86.6% ]
