[ Total Views: 3355 | Total Replies: 74 | Thread Id: 92110 ] |
Pages: 1 2 3 |
Gracey
Threads: 17
Mood: Itchy
posted on August 18th, 2011 at 09:29 PM |
Quote: | Originally
posted by waveman1500
Hi guys,
I have a question to ask on this thread.
My car is currently getting the carbs set up. I have a stock 1600cc twin-port with a Pertronix distributor (009 style), sidewinder exhaust and a pair
of 36mm IDF Webers on CB Performance manifolds. What size venturis would you recommend for the Webers? The carbs currently have something like 32mm
venturis in them. I want it to run nicely on the stock 1600 at this stage, but in the future I may upgrade the engine with heads, cam and who knows
what else.
I've got a set of 36 IDF's with 32mm venturi's on a stock 1600 with extractors and it runs fine and get good mileage.
Bizarre
posted on August 18th, 2011 at 09:44 PM |
^^^^^ agreed
I had the same.
32 vents 135 mains F11's and 45 idles
waveman1500
Also rides a Honda
posted on August 18th, 2011 at 09:54 PM |
Really? Bob at Volkscare is suggesting that they are too big, and the basic research which I have done on the internet is suggesting that I should go
for 28mm venturis. I'm happy to try it with the big venturis as it will save me buying new ones! Those things aren't cheap when you're buying four!
matberry
posted on August 18th, 2011 at 09:59 PM |
28's will be much better low speed drivability.
HoneyAbba
Threads: 1
posted on August 18th, 2011 at 10:34 PM |
As a general rule the venturis need to be smaller than the intake valve buy around 3mm, for a strong signal from the engine to the carby.
Also a E100 cam will work OK, a std cam will work better.
Bizarre
posted on August 19th, 2011 at 06:31 AM |
its not just the venturis you need to buy - as the mains match the vents
28 vents - 115 to 120 mains
32 vents - 135ish mains
I believe the CB SuperDellorto book and the Haynes Weber book suggest 32's if you check their graph
Whatever - I have never used 28's but have been VERY happy with 32's on IDF 36's on both a 1600 and a 1776
Following the same story - I have 34's in my DRLA 40s in a 1916
Just make sure you dont have that stoopid E57
HoneyAbba
Threads: 1
posted on August 20th, 2011 at 02:00 AM |
It goes without saying that if you change the size of the venturies/chokes then rejetting will be required, that formula vents x 4 is just a guide or
starting point, every engine is different . The Only way to get it right is to use a wide band air /fuel ratio meter and put the car on the road or
better still on a dyno .
Seat of pants jetting or checking plug colour is from last century..
HoneyAbba
Threads: 1
posted on August 20th, 2011 at 02:02 AM |
is E 57 a dellorto E-tube number ?
JonR356
Threads: 4
Mood: Optimistic
posted on August 23rd, 2011 at 03:57 PM |
If it helps the OP on the sort of numbers to expect, I've got a 1641 with Scat C25 cam, 36 Dells, extractor exhaust and a 009 with Pertronix ignitor,
makes 52.6 RWHP
Bizarre
posted on August 23rd, 2011 at 04:10 PM |
Quote: | Originally
posted by HoneyAbba
That is what the Alfa's were supplied with
Could never get that f&$ker to work
t_tuffnut
Threads: 70
Mood: Rust free for 12 months
posted on August 23rd, 2011 at 05:02 PM |
Thanks Jon - useful to know. Mine will be 1600, but it is good to know that your getting similar numbers to those suggested earlier in the thread.
matberry
posted on August 23rd, 2011 at 07:43 PM |
I think you'll find the emulsion to be a F57. I haven't have a big problem with them. Marcus has a set on a 1641 with port and chamber work on 043
40x35 heads, mild cam similar to a W100 and with the F57's we jetted it to run beautifully. Yet to be confirmed by A/F meter, but great to drive so
not far wrong. I'm sure Marcus will be going thru the jetting in detail soon.
Bizarre
posted on August 23rd, 2011 at 07:57 PM |
Sorry - correct
F57.
I hated them
Bloody glad some likes em
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on August 23rd, 2011 at 11:29 PM |
Hey tuffnut, don't worry too much about HP mate just build your 1600tp 110 36s, massage the stock heads a bit, get a good exhaust and you will not be
able to get the silly grin off your face every time you drive your car, that's what its all about in the end.
Let us know exactly what carbs you are going with cause 36 IDF need a bit of tweaking before being used on beetle.
HoneyAbba, there are plenty of people in this and VW forums all over the world that are highly more qualified, experienced and respected than
yourself, that openly share their knowledge and engine recipes and back up their HP claims.
AFAIC, you can keep your cam and C/R combo a secret.
cnfabo
Threads: 140
posted on August 23rd, 2011 at 11:32 PM |
my mate had a 1640,110 cam ,idfs, masaged heads etc..drove superb....lovely daily driver and still fun...
Pages: 1 2 3 |
