| [ Total Views: 6822 | Total Replies: 72 | Thread Id: 97354 ] |
| Pages: 1 2 3 |
eXraycer
Threads: 27
| posted on May 10th, 2013 at 07:08 PM |
Update.
Picked up the rear sub-frame from the welder. See pics below.
5.5 hrs worth of welding and fabrication in addition to all the prep work I did. It's really a far better welding job than I could have done.
I am very pleased with the results. The reinforcing plates next to the pivot boxes were an addition. So was the additional welding
welding of the Empi HD rear trans mount. Although it's heavier guage steel it was a little light on welds we thought.
Here's the pics. The Mohr mid mount is just placed under the frame. They don't require any welding. Was going to use a Berg mid mount but to be
honest
I like the simplicity of the Mohr style one.
vlad01
Mood: Side ways
| posted on May 11th, 2013 at 09:16 PM |
thats very nice work, I see you got all the other weak areas welded too.
71 notchback,
eXraycer
Threads: 27
| posted on May 19th, 2013 at 08:10 PM |
This is me tonight.
One small step for veedub,
One giant leap for sandkind.
vlad01
Mood: Side ways
| posted on May 19th, 2013 at 10:10 PM |
must be so good having your own blaster. I bet you would save a heap by having it done your self.
71 notchback,
eXraycer
Threads: 27
| posted on May 19th, 2013 at 10:33 PM |
| Quote: | Originally
posted by vlad01
Biggest advantage is you get to do things at your own pace.
Ebay for the blaster $165 cheap.
Aluminium oxide. 3 x bags. $60 each. It's exxy but you can use it at least 10 times. I started with a heavier grit on yhe chassis and reuse. Do
chassis first then by the time you need to do any panels it's clearly finer grit. you can buy fine grit from the start but I plan to down grade it
for finer use the more I use it.
Edit: I should mention, you need a good air supply to run this sand blasting rig. About 80-90 psi. Also you need to fiddle with the lower supply lever
under the tank which lets out the pressurized sand from the tank into the jet stream of the gun hose. At first it was just pouring bucket loads of
sand at low velocity until I reduced the amount of sand coming out of the tank. After that it worked fine.
Also the rubber hose blew open right at the lower exit of the tank feeder after a couple of hours. admittedly I wasn't aware but I had a bit of a
tight bend coming out of the tank so I probably should have kept the hose straighter. Its a thick hose so I imagine this sand is very abrasive and the
hose will be a consumable item.
eXraycer
Threads: 27
| posted on May 20th, 2013 at 11:45 PM |
Gonna be a long night. Last night finished late sandblasting and tonight got a late start after my day job and did some final prep work. No point
waiting any longer to get paint on. Using up some POR 15 I had bought already but I think I might do the underside with KBS cause its a little less
shiny and I want to top coat the underside with satin finish polyurethane.
Doing the pan floor with a brush cause its a little pitted and I want to get an extra coat in this area. The rest I'm gonna spray. Two more spray
coats over the whole lot. The tunnel I didn't strip cause was not rusty. I just sanded a little and sprayed with POR acid etch primer.
eXraycer
Threads: 27
| posted on May 21st, 2013 at 02:45 AM |
Not much else to do between coats. May as well update photos.
First full spray coat. Thinned down 10%. Seems to spray well.
Underside will have to wait for another day cause I'll have to use the metal ready rust converter to re-apply the zinc phosphate coating. Its been a
while since I sandblasted the underside. I spoke with the supplier of POR 15 a while back when I realized I needed to do a bit of welding after I
sandblasted the underside. Knowing it was gonna be delayed a while before I could paint I asked him about the procedure. He said no prob, just do the
work then reapply the metal-ready coating before painting.
eXraycer
Threads: 27
| posted on June 1st, 2013 at 11:18 AM |
Did the old 'strip-n-flip' last couple of days, preparing to paint the underside.
All things going well I'll get some paint on the underside today.
shaven
Threads: 67
Theme: UltimaBB Powder
| posted on June 1st, 2013 at 08:46 PM |
mate great job... love reading this thread.
"When the character of a man is not clear to you, look at his friends"
eXraycer
Threads: 27
| posted on June 3rd, 2013 at 05:13 PM |
A productive weekend. Achieved that OEM look with satin black but I doubt VW ever layed this much paint on the chassis.
I also sprayed over my front beam which I did in grey gloss a while back. Wasn't a fan of the glossy grey so I went for satin black. It's the UV
stable top coat you paint over the rust sealing paint. $80 a litre for top coat is not cheap but if you spray it in the same paint session as the rust
paint you can get away doing 2 coats black rust paint sealer followed by one coat of black Top coat satin.
eXraycer
Threads: 27
| posted on June 19th, 2013 at 12:03 PM |
Update.
Put dimples for cv joint clearance.
And did more sand blasting.
Took parts to powdercoaters. Have no time to paint atm.
Damn engine tins have a couple of cracks in them apparently where everybody gets cracks. Slight design flaw i'm told so got to weld that up and
reinforce before I get tins powdercoated.
Would have been nice to drop them all off at the same time.
eXraycer
Threads: 27
| posted on June 22nd, 2013 at 11:59 AM |
Fresh powder coat on the rear subframe and a few other parts. Looks very close to the satin black I sprayed under the car and should be a little
tougher. I try to save money and do work where I can but I just wanted this done so I could move on. Good choice too cause today would have been my
first chance to spray paint and its a miserable, rainy day here in Sydney. I'm itching to start work on the body soon. Kills me to let it just sit
there while I'm preoccupied with other jobs.
Once I bolt these front and rear ends on the pan I can have a big clear-up and get back onto the body.
eXraycer
Threads: 27
| posted on August 18th, 2013 at 06:31 PM |
Just an update. I've been spending some time with small parts prep, rust removal and such. I purchased a nice bench grinder with a wire wheel. Can't
believe I've lived so long without one of these. I also constructed an electrolytic rust removal bath. Works a bit like molasses except its a lot
quicker and no sticky goop to contend with.
Anyhow, I recently turned my attention to zinc plating. Wanted to set up a little hobby style tank and plate a few nic nacs on the car.
After much trial and error I've got a reasonably good finish on my first few parts.
It uses vinegar and epsom salt as the electrolytic solution and sugar as a supposed brightener but the finish is quite dull straight out of the tank
and it requires a hit on the wire wheel to get the finish I want. Overall I'm pleased that I didn't spend a tonne of cash on a DIY kit considering
I'm only doing a few parts and not requiring a 'copy-cad' yellow zinc finish.
| Pages: 1 2 3 |
