| [ Total Views: 10932 | Total Replies: 124 | Thread Id: 97513 ] |
| Pages: 1 2 3 4 5 |
matberry
| posted on September 14th, 2012 at 08:53 PM |
Thanks Carl, a little more done today too. I'll take some more pics
matberry
| posted on September 22nd, 2012 at 11:25 AM |
Photobucket now happy to take my uploads so here's the next set of up date pics.
With the front apron fitted, there were a few detail repairs required in the rh rear wheel arch and rh front around the fuel filler. The rear then got
primed
Then the body work recieved a skim of filler to fine tune the steel work
On to the front 1/4 panel
And now primed
Bizarre
| posted on September 22nd, 2012 at 12:38 PM |
nice work and lovely car
What colour is it going to end up??
matberry
| posted on September 22nd, 2012 at 02:45 PM |
She's not a respray, just repairing the damaged and corroded area's and blending paint.
Carl and Emily
Threads: 38
| posted on September 23rd, 2012 at 10:20 AM |
Looking great!
Thank you yet again.
Have a blast at warrick Matt.
matberry
| posted on October 17th, 2012 at 11:15 PM |
A quick update of pics
matberry
| posted on October 21st, 2012 at 07:00 PM |
My last update was missing a few pics to be true to the time frame due to issues uploading to photobucket. I'll post up the latest but consequently
the order is a little over the shop
Before (well actually after some cutting and pulling)
After
pete wood
| posted on October 21st, 2012 at 07:33 PM |
JohnnyMac
Threads: 7
| posted on October 21st, 2012 at 07:37 PM |
wow great work!
matberry
| posted on October 22nd, 2012 at 08:48 PM |
Thanks guy's, the credit really goes to Max my panel guru.
Carl and Emily
Threads: 38
| posted on November 2nd, 2012 at 06:53 PM |
So,..
With the end of the body work in sight I thought it appropriate to post alittle word about the one that didn't make the cut.
Take your hats off people and bow your head.
It's probably still there, and has probably sunk alittle deeper into the dirt.
You may have read in one of the first posts in this thread that on our holiday down south. ( or north, or east, or west for you depending on where you
live. )
Canberra
We went to look at a bug.
Looks better than ours right?
But actually it is in worse condition rust wise than ours. (rust in the door pillars.)
The floors are pushed upwards,
Damaged rear. Dents in passenger side.
What we did like about it was that it has a red interior which I haven't seen alot in a 1500 bug. And is nice and original.
Anyway, Enjoy your volkies people. Look after them, keep them out of the weather. They are falling off the perch faster than we realise.
but of course if you are looking for a 1500 bug project here's an option for you, go for it.
2 really is our limit.
It's a shame the previous owner didn't see fit to keep this one alive.
Time to go for a drive in our 62.
| Error |
| Error |
Carl and Emily
Threads: 38
| posted on March 18th, 2013 at 06:06 PM |
So Matt,..
Has anything happened with blue 2?
I know you've be busy with a certain blue car of your own.
matberry
| posted on March 18th, 2013 at 07:03 PM |
Hi Carl, I hear you loud and clear, presently Blue 2 is in a holding pattern due to space restrictions on the runway. Max has been kept busy on the
'60 ragtop, and we have a few type 2's that have crash landed into the runway (workshop). We are hoping to split body and pan as soon as we have
some room.
Carl and Emily
Threads: 38
| posted on March 18th, 2013 at 07:23 PM |
Fine with us Matt.
Just curious that is all.
As you know no rush.
Just when you feel so inclined.
We have a volksie to drive so we are fine.
Look after those pour souls who only have one and need their vw back asap.
Sounds like we need to have a chat (when the time comes.) if you've decided to go down the split body and pan route. i.e. what else to do when they
are apart. hmm,..
felix91
Threads: 1
| posted on April 13th, 2013 at 07:55 PM |
wow great stuff! |
Carl and Emily
Threads: 38
| posted on July 21st, 2013 at 12:31 PM |
Big movement forward during the last few weeks.
The decision was made to split the pan and body.
Once repairs have been completed pan will be sent off to powder coat in the factory colour.
Then the process of putting this bucket of bolts back together can begin.
I've been doing a little of the cleaning and prep myself.
I don't think Matt and Max believe me when I say I find it quite satisfying, and actually quite enjoy it.
Grease, dirt and grime, wire wheeling, body seal goop,etc,.. fantastic!!
| Error |
| Error |
pete wood
| posted on July 22nd, 2013 at 08:38 PM |
Keep at it.
matberry
| posted on July 22nd, 2013 at 09:50 PM |
Thanks for the update pics Carl. Here's some more. The first one is showing the repairs to the passenger door. A few bubbles in the paint can become
quite a bit of the panel being replaced once properly investigated.
We cut out any thinning metal and visually check inside the panel in all the nooks and crannies.
Thanks Carl for your help knocking up the set of stands for the body on parting day.
And as usual, there's always a surprise, a sneaky hole in the heater channel that was directly under the pan seal will need repair.
matberry
| posted on August 19th, 2013 at 01:39 PM |
So the last welding jobs are near completion.
The pan has rust in the LH floor and inside the tunnel the clutch tube was broken away from it's mountings and snapped in two pieces in the centre,
all of which needed repair.
here's the broken clutch tube at the rear
and at the front
and in the centre, snapped and no longer mounted
Here is the centre repaired and remounted
and front and rear clutch tube repaired
Then the access holes got repaired
So the LH pan 1/2 ended up being rusty and requiring replacement
spot welds drilled and pan removed
weld through primed prior to welding
New pan 1/2 installed
benny_acko
Threads: 32
| posted on August 19th, 2013 at 01:59 PM |
Looks great!
Whereabouts do you source your pan halves?
Ben.
1967 VW Beetle Deluxe
matberry
| posted on August 19th, 2013 at 03:40 PM |
Hi Ben, I was blown away by that pan 1/2. It's quality is so good, you could mistake it for original VW. I try for the best available and when I
don't know better, ie. used myself, I go to the guy's who do know, straight to Vintage. Not cheap, but you get what you pay for, and proof was
during the installation, brilliant!
benny_acko
Threads: 32
| posted on August 19th, 2013 at 04:09 PM |
Yeah it looks great!
Thanks.
LUFTMEISTER
Threads: 119
| posted on August 19th, 2013 at 05:12 PM |
I have found it easier & quicker to remove the pans halves by cutting close to the spline edge and removing the rest with an air chisel and
grinding the spot welds back to flat.
My2c
Carl and Emily
Threads: 38
| posted on October 10th, 2013 at 07:01 PM |
Any update pics Matt?
matberry
| posted on October 10th, 2013 at 07:38 PM |
No pics yet Carl, been back onto it this week. The OG paint has been colour sanded and buffed and has come up a treat. Pan and suspension components
have returned from the powder coaters too, it's looking great in the charcoal, just like the OG colour . I'll get some pics posted soon.
ps. Engine bay looks like new, og tar boards have tidied up sweet
Carl and Emily
Threads: 38
| posted on October 25th, 2013 at 05:59 PM |
So,...
A little update.
Wagged work for a morning this week and went and saw Matt.
It's getting very close to putting colour on the repairs.
Rather than simply getting the paint made to code. The new paint will be colour matched to what the car actually is now.
So to do that it had to be cleaned up.
Very difficult to photograph, and looks so nice in person, but you get the idea where this is going.
Mmmm,.. shinny.
It was a nice sight to see our little bucket of bolts surrounded by some high class machines. Matts awesome blue to the front , and a certain yellow
bug to the side. (I know who you are mr yellow bug owner,.. I bought my very first bug from you way back in the beginning of time, if you are on here
how about a thread on it? I like it, and am sure others on here would appreciate it too.)
The pan also has returned from the powder coater.
Pics of that once it comes out from where it is stored.
Hope you enjoy.
| Error |
| Error |
| Error |
matberry
| posted on October 25th, 2013 at 11:01 PM |
Nice update Carl, thanks. I'm glad you like the way the paint has come up. your right tho, hard to get the finish in a pic.
Carl and Emily
Threads: 38
| posted on October 26th, 2013 at 10:54 AM |
Yes Matt, may I suggest a light stage for photography when Berry Motorsports Headquarters expands.
When not in use you can park bluey in there under lights 24/7 with a nice big glass wall from the workshop.
Mmm,.. dream on.
matberry
| posted on October 26th, 2013 at 12:09 PM |
^^ me like alot
matberry
| posted on November 23rd, 2013 at 03:44 PM |
Well to bring you up to date, all rust repairs have been completed, all the panels have been resurected yet we've retained as much original paint and
patina but metal prepped and painted underneath and the edges where the surface rust had become a little more
| Error |
| Error |
| Error |
| Pages: 1 2 3 4 5 |
