| [ Total Views: 7237 | Total Replies: 95 | Thread Id: 99023 ] |
| Pages: 1 2 3 4 |
1303Steve
| posted on January 20th, 2013 at 09:03 PM |
Hi Col
If your not happy with your caster now with the topline bushes let me know and I will give Kevin at KMac a hurry up, I dont live very far from his
shop.
I have his strut tops in my new bug.
Are you allowed to alter your front suspension very much under hill climb rules?
colin
Threads: 82
| posted on January 26th, 2013 at 02:55 PM |
So i took the car into work this morning to give it a wheel alignment again.
I found the d-bushs have given me another 3/4 a degree of caster angle, not a huge difference but a step in the right direction.
Adjusted and evened up the camber and checked toe, all good.
Bring on the first round.
Cheers Col
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on January 26th, 2013 at 09:40 PM |
whats your total caster now ?
colin
Threads: 82
| posted on January 27th, 2013 at 02:42 PM |
| Quote: | Originally
posted by Craig Torrens
Still only have 2 degrees 41 minutes left and 2 degrees 48 minutes right.
Way not enough, but gives me something to work towards.
Cheers Col
colin
Threads: 82
| posted on February 2nd, 2013 at 04:10 PM |
Had a final spanner check and adjusted the clutch up a tad today.
Looked over the car trailer and fixed the brake cable and adjusted it aswell.
All now ready for some fun at Cooperbung Hillclimb.
Cheers Col
1303Steve
| posted on February 2nd, 2013 at 04:56 PM |
Hi Col
Have fun.
You should do a few practice runs with the Go Pro. Worst thing is turning it off when you want it on and vice a versa.
Are you taking any little people that are good with technology?
Sides
A.k.a.: Dave Sidery
| posted on February 2nd, 2013 at 05:15 PM |
| Quote: | Originally
posted by 1303Steve
You should do a few practice runs with the Go Pro...
Yeah - especially when you've got an airstrip to practice on nearby !!!
Got something you could measure out (say) 600 feet with ???
My toys
colin
Threads: 82
| posted on February 2nd, 2013 at 06:52 PM |
| Quote: | Originally
posted by 1303Steve
Hi Col
Have fun.
Unfortunalely my 13 year old daughter is not to keen on racing, So
i,m going to do practice on the Saturday so i can get familiar with the Go pro and my new engine combo.
My 7 year old son however loves the Beetle, and the "revving", as he says.
Maybe i,ll have a pit crew man in a few years.
Cheers Col
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
| posted on February 2nd, 2013 at 09:37 PM |
| Quote: | Originally
posted by colin
Cheers Col
When is this on Col?
From your ole' mate Jeff
colin
Threads: 82
| posted on February 11th, 2013 at 08:34 PM |
Thanks to Jeff and Dylan for giving a good cheer on Sunday.
The car performed really well with only a minor electrical issue giving me a few probs for the last 2 runs.
The ignition fuse was corroded a little making my tacho not work and blinkers go crazy .
Easy fix tonight.
I will check the car over and also check the tappet clearance, but the engine is spot on with no oil leaks or any sign of excess crankcase oil
pressure.
Cheers Col
1303Steve
| posted on February 11th, 2013 at 08:46 PM |
Hi Coil
So how did the car behave with more caster?
colin
Threads: 82
| posted on February 13th, 2013 at 07:56 PM |
| Quote: | Originally
posted by 1303Steve
Hi Coil
Didn,t really notice anything different. However Cooperabung is a fast track, and i beleive the caster improvment will help with the slower tighter
tracks.
Cheers Col
colin
Threads: 82
| posted on February 17th, 2013 at 11:58 AM |
Spent some time in the shed yesterday and this morning checking the car over etc.
All tappetts were virtually spot on with only 3 needing a very slight adjustment, maybe 1 thou.
The engine bay was clean with no signs of crankcase over pressure, and no oil drips on the floor of the shed. After 2 runs at Cooperabung i changed
the mains fron 155 to 150,s and noticed an immediate improvement in run3, i was using the air cleaners as it is very dusty in the pit area.
For Bathurst however i will be racing with no air cleaners on so i have changed back to 155 mains.
I will see how humid it is on the day and make a final choice as i go.
Time to wash inside and out, then clean tyres and store away for Bathurst weekend.
Cheers Col
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
| posted on February 17th, 2013 at 01:23 PM |
Thats good to see Col. Like you I am also getting the bug ready for Bathurst. Have you got the bug targetted scruit done yet?
White Knuckle Racing Team
"Drive it like dirt"
colin
Threads: 82
| posted on February 17th, 2013 at 04:13 PM |
Here is a shot of the dusty pits.
Yes mate my car has had that done.
Cheers Col
| Error |
Craig Torrens
Threads: 347
| posted on February 17th, 2013 at 05:29 PM |
| Quote: | Originally
posted by bat69
What is this ?
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
| posted on February 17th, 2013 at 06:28 PM |
All cars running at state level have to be what they call targeted scruit. And it has to be done every 4 or 5 events. Its a full on look over the car,
jacked up, wheels off etc to make sure the car complies with safety rules and regs. Once regoed for the state champ you then have to organise the
check with someone on the list of state wide regional scruitineers.
colin
Threads: 82
| posted on March 10th, 2013 at 02:33 PM |
After a long week and a big let down from Bathurst i got into the shed this weekend and started checking over the car.
I had a small oil leak problem out of the breather tower so i removed it and found my rubber chair leg bungs had gotten brittle and leaked oil.
I will take it to my mate who works in an engineering shop to weld two nipples onto the ends then i,ll put caps on them.
All tappetts were also checked with none needing any adjustment
The car copped a floging this last weekend but i,m very pleased it came through with flying colours.
The improved caster angle i felt helped with the cars high speed stability with zero understeer all weekend despite the low track temp.
Cheers Col
| Error |
Craig Torrens
Threads: 347
| posted on March 10th, 2013 at 06:43 PM |
| Quote: | Originally
posted by colin
Your car did everything you asked it to do, it didn't break, and you achieve 2 PB's........sounds like a successful weekend to me, not a 'big let
down'.
Sides
A.k.a.: Dave Sidery
| posted on March 10th, 2013 at 07:06 PM |
Good to hear all in order Col !!!
As to the "big let down", I took it as the horrible coming back down to normal from such a huge high... that's definitely how I felt through the
week !!!
My toys
colin
Threads: 82
| posted on March 10th, 2013 at 07:55 PM |
| Quote: | Originally
posted by Sides
week !!!
Sorry Craig poor choice of words, spot on Sides, huge high of weekend then back to reality and the mundane things in life.
Cheers Col
Craig Torrens
Threads: 347
| posted on March 10th, 2013 at 09:46 PM |
ah ok
colin
Threads: 82
| posted on April 13th, 2013 at 04:13 PM |
My mate Rob finished brazing on the bungs for my Berg style breather tower, and today i picked it and the rear breast plate up from Al at Alan Barnes
Smash Repairs.
I thought it was leaking out the rubber chair leg bungs but when Rob cleaned it up ready for brazing he found a 2 inch hairlin crack down the breather
box. Now that makes sense.
I fitted the pieces back on and am now cleaning the car inside and out as i have been invited to display the car at the Shannons Country Classic Car
Show.
It is held here in Tamworth on the weekend of the 27th and 28th of this month. It,s an invite only show, so i need to clean up the Beetle real
good.
During last weekend when i was cleaning i managed to stumble across a few items that i replaced or removed to lighten the rear end.
I,ll post a few pics of the show later.
Cheers Col
fullnoise
Threads: 103
Mood: Middle of the road.
| posted on April 13th, 2013 at 06:36 PM |
Hey Col,
I picked up those items for you which may give you the record breaking edge you've been looking for. I'll post them to you on Monday. Not that you
need them for hillclimbs.
CYA CT
esratrams
colin
Threads: 82
| posted on April 13th, 2013 at 08:06 PM |
| Quote: | Originally
posted by fullnoise
Hey Col,
CYA CT
  onya CT.
Cheers Col
Craig Torrens
Threads: 347
| posted on April 13th, 2013 at 09:49 PM |
| Quote: | Originally
posted by fullnoise
Hey Col,
CYA CT
Testicle inplants ?
just joking Col, no need to send me a PM
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on April 14th, 2013 at 04:25 PM |
Very cool to get the invite to the Shannons event Col! Legend
colin
Threads: 82
| posted on April 14th, 2013 at 04:49 PM |
| Quote: | Originally
| Quote: | Originally
posted by fullnoise
Hey Col,
CYA CT
Testicle inplants ?
That actually damn funny
Cheers Col
colin
Threads: 82
| posted on April 27th, 2013 at 05:34 PM |
The Shannons car show kicked off today with a good crowd of people coming through all day.
We had lots of interest with the 3 Tamworth Sporting Car Club Cars on display.
The highlight today for me was when i spotted the man i bought my car from many years ago. He was gobsmacked when i pointed out that it was his old
beaten up car. His smile was absolutely priceless, he kept opening his mouth but no words came out, Gold.
Cheers Col
| Error |
colin
Threads: 82
| posted on April 29th, 2013 at 07:31 PM |
Had another great day at the Shannons Show.
Could have made a fortune charging little and big kids for a sit in the Beetle, people jusy love to sit in one. Lots of adults and mostly females
loved the snug fit, and getting a feel of being in a race beetle strapped in with the harness.
A big surprise was i was lucky enough to be awarded best European car at the show.
Hears a few pics.
Cheers Col
| Error |
| Pages: 1 2 3 4 |
