| [ Total Views: 291886 | Total Replies: 1034 | Thread Id: 67295 ] |
| Pages: 1 .. 28 29 30 31 32 .. 35 |
jzk25
Threads: 3
| posted on December 8th, 2009 at 06:33 AM |
You don't need subaru to check live data or codes, any aftermarket scanner like Coda, Hanatech, OTC, carmann etc will do it. Most workshops will have
one of these. It's more likely a setup problem though.
jzk25
Threads: 3
| posted on December 8th, 2009 at 06:45 AM |
P0102 MAF SENSOR LOW INPUT - Is the MAF sensor still fitted to a std size tube(~60mm ID)?
P0458 EVAP PURGE VALVE CIRCUIT LOW- Unplugged or has been unplugged.
P1230 FUEL PUMP CONTROL UNIT MALFUNCTION - Did you get one of these? It is necessary. If you did get one then make sure the fuel pump body is
insulated and the power and earth for the pump only go to the control unit. Bosch pumps will ground through the pump body and the control unit will
not work properly in this case.
P0037 REAR 02 SENSOR LOW INPUT - This could be a positioning problem. The front sensor is an A/F ratio sensor(like a wideband) the rear is a normal O2
sensor and the ecu uses the two to check catalyst efficiency. If the sensor is too close or too far away from the cat it can cause issues.
P0245 WASTEGATE SOLENOID A LOW - Probably from being unplugged.
Firstly, most of these codes could be in memory and just caused by the ecu being powered up with the sensors unplugged. Clear the codes and wait for
the engine light to come back on, then recheck.
The Maf code is most likely to be cuasing the problem but it could simply be overboosting. They are pretty sensitive to this sort of change to the
exhaust and intake and will overboost easily. (And don't you have a TDO4 on it? This will also not match the boost control mapping).
Mick058
| posted on December 8th, 2009 at 06:53 AM |
Thanks for the info Al! Wish you were down here - i will send it on to westside and pulse racing also (they tuned the car).
I took photos last night for you of the engine bay - just uploading so will send shortly.
Mick058
| posted on December 8th, 2009 at 06:56 AM |
| Quote: | Originally
posted by STIDUB
| Quote: | Originally
posted by Mick058
| Quote: | Originally
posted by Craig Torrens
just sell it
35k and its yours!! Though it owes me a bucket load more.
that fact should be obvious to anyone thats looked at the thread that isnt a clueless dreamer
the world is full of those!
Mick058
| posted on December 8th, 2009 at 07:22 AM |
ian.mezz
Threads: 280
| posted on December 8th, 2009 at 12:16 PM |
shit Mick looking at that motor and its a bit dirty it looks like a big job just to polish all that alloy.
Mick058
| posted on December 8th, 2009 at 12:28 PM |
haha, residue from a lazy clean attempt. Flash doesn't help - geez you like to whinge Ian    we don't all like
junka sleepers!
ian.mezz
Threads: 280
| posted on December 8th, 2009 at 01:34 PM |
| Quote: | Originally
posted by Mick058
junka sleepers!
come on Mick.
If you not going to keep it nice and clean, Youll miles well sell it to Craig Torrens.
His got lots of time for polishing things.
Mick058
| posted on December 8th, 2009 at 01:40 PM |
Too much power for Craigy boy! His gone soft and turned Jap on us - plus, Craig wouldn't pay 35k for a veedub without a pobjoy in it
ian.mezz
Threads: 280
| posted on December 8th, 2009 at 01:54 PM |
| Quote: | Originally
posted by Mick058
next thing youll know is that Craigy boy wil be on here saying atleast Pobjoys dont have error codes
Bizarre
| posted on December 8th, 2009 at 01:58 PM |
| Quote: |
Mick058
| posted on December 8th, 2009 at 02:01 PM |
| Quote: | Originally
posted by ian.mezz
| Quote: | Originally
posted by Mick058
HAHAHA - only cause their still leaving in the 70s and can't work out EFI!!!
(no disrespect to Stan! The engines still kick Butt)
Camo
A.k.a.: Kev
Threads: 209
| posted on December 8th, 2009 at 02:14 PM |
Gee's you guys are hard on a bloke. I hope Craig has broad shoulders.
colonel mustard
Threads: 51
| posted on December 8th, 2009 at 02:15 PM |
Thats one way of putting it.
Mick058
| posted on December 8th, 2009 at 02:19 PM |
Camo, this is to keep Craigy boy within Earths orbit! Craigy is a very confident old man
nah, Craigs a pretty good bloke - at least he was always helpful and generous to me, been the most willing guy re. VWs to me - loves a stir though, so
you got to give it right back...
71-BEETLE-SEDAN
AKA Josh
Threads: 108
| posted on December 8th, 2009 at 05:57 PM |
Hey, i joined a rexxy forum today so could try get some seats i reckon you should join it because there is a whole section on sensor errors here is
the link it might work without being a member.
http://www.rexnet.com.au/forum/index.php?showtopic=100882
jzk25
Threads: 3
| posted on December 8th, 2009 at 07:41 PM |
| Quote: | Originally
posted by Mick058
That plug is for the cannister purge control solenoid. Find it and plug it back in and that code will go away.
The airflow meter looks to be in a larger tube than std but if it was retuned by pulse that shouldn't matter.
I'd say the boost control solenoid is probably missing too seeing as you are using a bleed valve. This will cause a fault code which could be the
cause of the cut.
Is the fuel pump controller in use? It needs to be there.
1303Steve
| posted on December 9th, 2009 at 07:47 AM |
| Quote: | Originally
posted by psimitar
It's actually not an entirely bad idea Jason. If the diagnostic port is still within the wiring loom then they can connect it to their diagnostic
machine and see all the voltage levels etc for the sensors.
The problem would be convincing them to work on a none std vehicle
Every time I speak to anyone at a Subaru dealer about what I'm doing, they really seem interested.
david777
Threads: 26
| posted on December 9th, 2009 at 08:51 PM |
Mick,
I'd try these guys, who are out your way.
http://www.alldrivesubaroo.com.au/subaru_diagnostics.html
Norrie is a Subaru Factory trained technician and used to run Noztune that specialized in modified cars at Peakhurst for many years.
I conducted his wedding some years ago when I was working at Hurstville
Mick058
| posted on January 6th, 2010 at 02:20 PM |
Should be picking up the old girl tonight - supposedly error codes were due to a faulty fuse holder which held fuses for fuel pump and fan. Will see
how we go...
Be good to go for a blast again. Been too busy to get to using it and taking it/picking it up from Westside.
MAy aswell get them to fix any hick-ups, thats why i paid them
lifes too damn busy. Looking forward to a veedub event soon.
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on January 6th, 2010 at 04:23 PM |
Bring it up for a drive Mick....then we can go for a cruise
STIDUB
Over it.
Threads: 57
| posted on January 6th, 2010 at 05:28 PM |
wlecome to come to me up the f3 if not ill be in syd fri/sat
Volkswagen Drivers Club of Queensland - member
Mick058
| posted on January 7th, 2010 at 08:18 AM |
yeh give me a buzz dave, Saturday is generally free.
Took it for a little spin last night - frig its fun, and fast. Scared the crap out of some guys in an MR2. They caught up at the next lights and
asked, What the ***** in that - they loved it. Feels quicker then before now, but that might be because i havent driven it in a while.
All seems good though
reub
VWRX is gone...
| posted on January 7th, 2010 at 08:28 AM |
Nice toy to have in the shed dude... the face on the MR2 dudes would
have been priceless
Reub
psimitar
Threads: 148
| posted on January 7th, 2010 at 10:19 AM |
Glad you managing to have some fun in her
So looking forward to the day when I can leave the V8 Ute boys for dead
Hope your electrics play ball. Kinda why I decided to bring my electrics into the 20th century with relays doing the switching and better contacting
modern fuses. Hopefully will be more reliable
madness is in the eye of the beholder
surfbeetle
Threads: 1
| posted on January 16th, 2010 at 05:14 AM |
Simply amazing! I very much liked the way the engine compartment was expanded into the tire area. I plan to do the same with my car. How is the
rear bumper attached? Is it possible to post photos of this? Is your rear apron removable? At this point, I have an ej20 from a 93 JDM Legacy in
the car, with a Link ECU. Still working on the cooling and such. I can only hope mine turns out half as nice as yours. Enjoy your car!
Craig Torrens
Threads: 347
| posted on January 16th, 2010 at 01:03 PM |
I reckon he might sell if you twist his arm !
psimitar
Threads: 148
| posted on January 16th, 2010 at 01:23 PM |
| Quote: | Originally
posted by surfbeetle
Do you have a thread for this? I'm wanting to do an EJ20 norm asp sometime in the near future
ian.mezz
Threads: 280
| posted on January 16th, 2010 at 03:23 PM |
| Quote: | Originally
it would be a good buy for you Craig we know you realy like it and the subaru power.
Mick058
| posted on January 26th, 2010 at 09:00 AM |
Well, unfortunately the time has come, way too early really! I've been pondering over this the last few months as some of you know and circumstances
means that at this time i need to sell the bug.
My wife and i bought a house in August last year and 'other' things are on the cards. I really really want to keep it, but its just not practical
and its too much money sitting there not doing anything. I've also started a small side business which has consumed any time that i did have to work
and play with the bug.
I think this thread speaks for itself - im realistic, i know i wont get my money back and i always set out to build the best car i could knowing that
i was throwing money away - it was never my intention to sell, but things and priorities change. I have taken no short cuts on this car - everything
done is top dollar. The condition and panel work on this car is immaculate and amazing. I have seen a lot of brilliantly restored cars, but for an
early 58 this car is extremely straight. No bog, no rust, none of that crap.
I've come up with what i believe is more than a fair price:
Car complete as is: $33,000
Car without conversion: $22,000
If you are interested in the car without the conversion, its easy to go back to aircooled, there is even more room in the 36hp engine bay. Cutting on
the car is minimal, thats the way we did it - alternatively you can stick in another suby, one that isn't done to the extreme like mine.
As a complete car you get all you see in the thread - it has been completely engineered, it has rego until November. The ECU is completely tuned by
pulse racing ($1500 worth) - the later model suby engines need a whole bunch more done to them.
If you want to know what the car cost me i will tell you - only if your interested in the car. Pretty obvious it cost me a bucket load more than the
asking price. I also have receipts. Even minus the conversion, you'd get no where near the quality for 22k - TRUST ME!
My loss, your gain.
PM me 0r call me on 0425 291 825
