[ Total Views: 329479 | Total Replies: 1582 | Thread Id: 58055 ]
 Pages:  1  ..  36  37  38  39  40  ..  53
Author: Subject:  What has Dave Been Up To? 29th AUG 2015: 10.66@126.09mph!!
Memberdangerous
Mood: 591
posted on June 29th, 2012 at 08:01 AM
Originally posted by Stanley
What's doing DB......been quiet at Reedy Creek
Been very busy with work since racing in Sydney,
but found some time at nights, to work on some improvements.
With some discussions with Roger Crawford at Heads Up performance,
and his valve train analysis program,
the momentum of the pushrods was out stripping the valve spring tension by 7200 to 7400rpm. (800lbs).
So I have reduced the mass slightly, without sacrificing the desired stiffness,
and am looking at making an improved rocker arm to reduce the flex.
I tried a lighter pushrod, made from 3/4" 7075 aluminium, but lift loss was a further .010".
While the rocker arms were not at fault for the failures,
(Mr Crawford uses these up to 11000 rpm and nearly 1" of lift,),
there is some flex within the arm as seen from the loss of lift from light "checking springs" to the actual race springs.
I have made one of each as prototypes,
and will do a production run of one set, once the clearances are worked out on the engine.
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012079.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012090.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012085.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012087.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012084.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012081.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012076.jpg
Here is an original arm, set on the jig as a guide, to curve the tops of the new ones.
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012073.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012082.jpg
Originally posted by westi
That's mad Alan.
Memberdangerous
Mood: 591
posted on June 29th, 2012 at 08:04 AM
Here you can see the comparison of the originals, and the new versions.
http://i113.photobucket.com/albums/n216/dangerous_05/28thJune2012078.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012005.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012004.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012003.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012002.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012001.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/30thJune2012001.jpg
That's mad Alan.
Member66deluxe
Threads: 139
posted on June 29th, 2012 at 08:09 AM
Holy shit, good work Dave.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
Membervassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on June 29th, 2012 at 10:11 AM
Very clever Dave :yes:
Memberian.mezz
Threads: 280
posted on June 29th, 2012 at 10:19 AM
you should give Ron Flemming a call , I was telling him about your big arse push rods :crazy:
He told us heaps of stuff about push rods , valve , and rocker when we was at fAT Performance .
his on face book to.:blush:
:lol::crazy::lol::crazy::lol:
Member1916baja
Threads: 176
posted on June 29th, 2012 at 12:09 PM
Wow Dave! Is there anything you can't make?
http://i432.photobucket.com/albums/qq43/1916baja/BigAssWing22.jpg
Member20bkombi
Threads: 26
posted on June 29th, 2012 at 12:53 PM
I think Dave has it all covered if its engineering, baking in the oven or a good impression on a mature lass:D
Nice work man!!!
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
MemberStanley
Threads: 270
posted on June 29th, 2012 at 02:51 PM
Nice work man!!!
I'm sure last time I was down there, there was a working model of a scaled down nuclear reactor
Member1916baja
Threads: 176
posted on June 29th, 2012 at 03:31 PM
I think Daves next challenge should be machining parts for an entire engine! although i dont know if that would really be much of a challenge for him.
Memberwesti
what the
Threads: 28
Mood: not blue, pink
posted on July 4th, 2012 at 01:19 AM
:crazy::crazy::crazy::crazy::crazy::crazy::crazy::crazy:
u crack me up dave.
amazing as always.
down sharon.
Memberdangerous
Mood: 591
posted on July 4th, 2012 at 05:11 AM
That's mad Alan.
Membermactaylor
Mood: even my dog is german
posted on July 4th, 2012 at 07:58 AM
did I read that dial indicator correct?
EVERLAST CONCRETE TANKS
1800 552 123
Memberdangerous
Mood: 591
posted on July 4th, 2012 at 08:16 AM
yep, all valves have .800lift plus or minus a couple of thou. :lol:
That's mad Alan.
posted on July 4th, 2012 at 08:58 AM
wow....nice one Dave :tu:
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on July 4th, 2012 at 11:31 AM
I'd love to see what you could come up with if you had alot of time of your hands!!
Membermactaylor
posted on July 5th, 2012 at 07:39 AM
very cool dave!
1800 552 123
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on July 5th, 2012 at 08:35 AM
To be able to make a rocker like that is mind-boggling.........but to then make another 7 identical!:tu::tu::tu::tu::tu::tu::tu::tu:
Memberdangerous
Mood: 591
posted on July 10th, 2012 at 07:29 AM
That challenge remains, those ones are the prototypes.
I checked every cylinder to see the gains in lift...about .030" through reduced flex.
Now the chore begins:
http://i113.photobucket.com/albums/n216/dangerous_05/RKRS014.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/RKRS015.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/RKRS016.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/RKRS020.jpg
That's mad Alan.
Memberdangerous
Mood: 591
posted on July 10th, 2012 at 07:53 AM
Yes, Ron rings me for advice all the time.
That's mad Alan.
Membervassy66T1
A.k.a.: Marcus Vass
posted on July 10th, 2012 at 09:32 AM
Make sure you sweep up all that swarf :spin::spin:
Memberdragvw2180
Threads: 33
posted on July 10th, 2012 at 10:22 AM
Wow .030 gained just turning it over by hand, just imagine how much you were losing at 8000 rpm's !!!!!! Mike McCarthy
Member20bkombi
Threads: 26
posted on July 10th, 2012 at 01:05 PM
Awesome Dave!!
Love your work!
How did you hold and clamp them for the fist cut, a vice??
Ph 0402 233 027
MemberStanley
Threads: 270
posted on July 10th, 2012 at 07:28 PM
Nice.
Memberian.mezz
Threads: 280
posted on July 10th, 2012 at 07:33 PM
Nice.
thats good to hear yous blokes keep in touch :blush:
MemberSuper1302
posted on July 11th, 2012 at 05:18 PM
nice work, i like my shed, but wish it was filled with all the tools you have.:tu:
Memberdangerous
Mood: 591
posted on July 13th, 2012 at 04:09 PM
How did you hold and clamp them for the first cut, a vice??
Initially I do as many facets as I can
using the vice and parallel strips underneath.
But eventually I had to make a jig and spacers to bolt each rocker down for the final shaping of the sides.
http://i113.photobucket.com/albums/n216/dangerous_05/RKRS031.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/RKRS030.jpg
That's mad Alan.
MemberRISKY4LIFE
posted on July 13th, 2012 at 05:54 PM
i don't think i would know how to turn on most of Dave's
gear !!
Membermactaylor
posted on July 14th, 2012 at 03:22 PM
gear !!
I bet rub it gently and wisper sweet volks porn in his ear!
1800 552 123
Member1916baja
Threads: 176
posted on July 14th, 2012 at 09:43 PM
:lol:
Memberdangerous
Mood: 591
posted on July 18th, 2012 at 07:50 AM
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012089.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012090.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012093.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012095.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012096.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/1stJuly2012097.jpg
That's mad Alan.
[ Queries: 40 ] [ PHP: 11.5% - SQL: 88.5% ]
