| [ Total Views: 10239 | Total Replies: 130 | Thread Id: 102386 ] |
| Pages: 1 2 3 4 5 |
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on September 18th, 2013 at 02:28 PM |
the headnut bosses on the cylinder heads are machined to achieve the desired thread length on the studs as 3 of the 16 headstuds could have been 4mm
longer , but not available in this length when I ordered them
| Error |
| Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 18th, 2013 at 02:33 PM |
I then insert small grub screws (that have been sharpened to a point) into the cylinders & put the heads on to mark where the stud holes need to
be drilled for the 5th & 6th studs
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 18th, 2013 at 03:28 PM |
the 5th headnuts wont clear the spark plus , so I machine down the nut boss area ..... unfortunately the head gaskets supplied by Pauter dont fit
straight over the 5th & 6th headstuds so we will have to hand file the holes to suit as the gasket is very thin in this area . (we did have the
same issue with Bens engine also)
| Error |
| Error |
| Error |
| Error |
Team
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on September 18th, 2013 at 06:34 PM |
Loving it Wayne
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on September 18th, 2013 at 08:40 PM |
Nice work Wayne, thanks for taking the time to detail the build and upload the pics for the benefit of others.
Al
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 18th, 2013 at 09:52 PM |
WOO HOO !! just opened my mail tonight and received an ' OFFICIAL TRACK RECORD ' for Sydney Dragway in the CC/MD class in the WPVW Dragster
10.179@132.9mph .
I backed this up with a pass of 9.888@135.52mph but this was outside the 1% to be validated as a record .....
http://www.sydneydragway.com.au/uploads/60631/ufiles/records/2013_07_13_sd_tr...
| Error |
Team
1916baja
Threads: 176
| posted on September 18th, 2013 at 10:12 PM |
Congrats Wayne! What's class is cc/md??
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on September 18th, 2013 at 10:16 PM |
| Quote: | Originally
posted by 1916baja
Thanks Mick , the class CC/MD is for 4 cylinder supercharged/turbocharged Modified Dragster
Team
cnfabo
Threads: 140
| posted on September 18th, 2013 at 11:04 PM |
Woohoo,stoked for you Wayne...I think it'd be cool holding a record,nice work...
silver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
| posted on September 18th, 2013 at 11:16 PM |
| Quote: | Originally
posted by hypo-vw
| Quote: | Originally
posted by 1916baja
Thanks Mick , the class CC/MD is for 4 cylinder supercharged/turbocharged dragster
How many in the class ??????
Keeping it real !
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on September 18th, 2013 at 11:33 PM |
| Quote: | How many in the
class ??????
not sure how many 4 cylinder supercharged/turbocharged modified dragsters there are in the country ..... the national record for this class is in the
low 7's (powered by Nissan) , but WPVW currently has the quickest one that has run at Sydney Dragway since its opening ....
Team
SuperOwen
Threads: 67
| posted on September 18th, 2013 at 11:43 PM |
National record next?
dangerous
Mood: 591
| posted on September 19th, 2013 at 05:43 AM |
Well done Wayne! Always nice to have a certificate to say you hold a record!
Holy cow, look at that C/MD record at 8.46! (normally aspirated 4 cylinder).
I wonder what that is!?
I see also that Russel Sarten's VW also holds a track record in SS/C!
Well done to you both!
| Quote: | Originally
posted by westi
That's mad Alan.
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on September 19th, 2013 at 07:15 AM |
| Quote: | Originally
posted by dangerous
I see also that Russel Sartens VW also holds a track record in SS/C!
thanks Dave ..... I didn't see that Russel had the SS/C record also , thats awesome !! Well done Russel & team @ CBB
Team
silver
Threads: 162
Mood: In 2 Minds
| posted on September 19th, 2013 at 10:26 AM |
| Quote: | Originally
posted by hypo-vw
class ??????
impressive ,well done
Keeping it real !
matberry
| posted on September 19th, 2013 at 10:53 AM |
Congrats Wayne.
new combo is looking good too :tu;
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2013 at 11:00 AM |
the copper head gaskets are filed at the 5th & 6th stud holes to fit the stud pattern in the Pauter cylinders .... the pistons are installed into
the cylinders & the cylinders are prepared for painting
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2013 at 11:03 AM |
the cylinder heads are cleaned & assembled , the volume of the combustion chambers is measured & the compression ratio calculated , the
cylinders are painted
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2013 at 11:07 AM |
I calculate the compression ratio & choose a 0.030" (0.75mm) shim for under the cylinders to set the comp at 8.75:1 ...... the final assembly
starts with the installation of the pistons & cylinders
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2013 at 11:12 AM |
the heads & cylinders are installed ..... everything has gone together really well so far
| Error |
| Error |
| Error |
Team
55slug
Threads: 22
Theme: UltimaBB Psyche Red
| posted on September 20th, 2013 at 01:19 PM |
Are the 5/6th headstuds just threaded into the cylinder ? Is there no concern with threads at that end of the cylinder with the amount of potential
thermal expansion even with methanol ?
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2013 at 03:59 PM |
| Quote: | Originally
posted by 55slug
the 5th & 6th studs are threaded straight into the top of the extra heavy-duty cylinder spigots as Pauter have designed them to be . There is also
the option of drilling the threads that Pauter have installed there , straight thru the spigot & running studs to the case if the case is suitable
. My mag case is not suitable to do this ......
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 21st, 2013 at 10:26 PM |
I got the engine for the dragster finished last night after Ben installed the pushrod tubes & Daniel linished/polished the plenums . I then
adjusted tappets , painted new fabricated parts for the exhaust & intake , assembled all of the exhaust / turbo etc
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 21st, 2013 at 10:32 PM |
this morning I installed a new 4-puk iron disc , cleaned the flywheel & stage-4 pressure plate prior to Ben Ford assisting me in lifting the
engine into the dragster..... the old clutch disc was 1mm thinner than the new disc & very worn
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on September 21st, 2013 at 10:36 PM |
the oil & breather hoses are all cleaned prior to assembly , the 675cfm Demon methanol carb is installed
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 21st, 2013 at 10:40 PM |
I have purchased a Turbosmart E-Boost street controller for the dragster . This will allow me to adjust the boost pressure accurately for both the
staging boost & max boost , all from the drivers seat .
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 21st, 2013 at 10:45 PM |
the breather box is removed & thoroughly cleaned out along with the breather filters & hoses
with the spark plugs installed there is ample clearance to the 5th headnuts due to machining of the heads
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 21st, 2013 at 10:53 PM |
I really wanted to work on the dragster tonight to get it finished and fire-up the engine , but at 7pm I tried to weld 3 alloy dash-4 nipples to the
new plenums & the bloody TIG ran out of gas !! Oh well , then monday it will be ...
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 22nd, 2013 at 04:59 PM |
a few pics I took of the dragster progress today .....
| Error |
| Error |
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 22nd, 2013 at 05:03 PM |
the boost pressure will now be controlled by a Turbosmart solenoid which is activated by the digital boost controller on the console .....
| Error |
| Error |
| Error |
Team
| Pages: 1 2 3 4 5 |
