| [ Total Views: 7789 | Total Replies: 138 | Thread Id: 104148 ] |
| Pages: 1 2 3 4 5 |
meisterberginteriors
Threads: 7
| posted on June 6th, 2014 at 03:17 PM |
yeah definitely keep me posted on that. I also followed the instructions to a letter.. here's hoping you just had a bad batch! Por 15 is not known to
be a product that gives a bad result.
Threads: 7
| posted on June 6th, 2014 at 03:27 PM |
At some point structural members that impart impact loads to the A pillars from frontal impacts were cut. Probably due to rust. Anyway I HAD to fix
it, there is no way i could sell a car in that condition.
I seam welded the whole structural member to the body originally it was tacked with three 4cm welds along the base on each member.
then i sprayed a mix of lanolin, fish oil and tar into the cavity and i will be sealing it up to avoid any nasty rust.
| Error |
| Error |
Threads: 7
| posted on June 6th, 2014 at 03:29 PM |
lots more paint stripping. everything is going back to bare metal!
| Error |
| Error |
| Error |
Threads: 7
| posted on June 6th, 2014 at 03:30 PM |
starting on the front.
| Error |
Threads: 7
| posted on June 6th, 2014 at 03:33 PM |
Now Ive already built a stock 1600 for the square.. but i now have a turbo kit for a type 3 and some 36 dells so im kinda leaning towards a mild
performance 1916...
thoughts??
Threads: 7
| posted on June 9th, 2014 at 08:50 AM |
when i was stripping the paint off the nose i discovered lots of bog.. i discovered the front must have been hit with a tow bar because there was a
patch that had been welded up and the metal had shrunk with the heat. putting a big well under the license plate. after lots of hammering and swearing
i came to the conclusion i would need to make a relief cut.
as soon as i made the cut the metal popped out.
| Error |
| Error |
Threads: 7
| posted on June 9th, 2014 at 08:54 AM |
after a few hours and a bit of welding this is what i came up with.
| Error |
| Error |
| Error |
Threads: 7
| posted on June 9th, 2014 at 04:01 PM |
just spent an hour today fixing up the small tears in the rear valance ang beating it back into the right shape.
| Error |
| Error |
| Error |
Threads: 7
| posted on June 9th, 2014 at 04:02 PM |
it so close now.. im running out of things to weld
| Error |
Threads: 7
| posted on June 12th, 2014 at 06:45 PM |
I finished stripping the paint out of the boot today. unfortunately its hard to take photos in such a small space. ive done my best.
then i painted it in por15
| Error |
| Error |
| Error |
Threads: 7
| posted on June 12th, 2014 at 06:55 PM |
its pretty hard to see black in low light taking photos with a phone. ill get some more when i roll it outside again.
| Error |
| Error |
Threads: 7
| posted on June 15th, 2014 at 05:06 PM |
here it is in the daylight. its only the first coat still needs to be rubbed back and painted twice more.
| Error |
| Error |
| Error |
Threads: 7
| posted on June 15th, 2014 at 05:12 PM |
I think I'm getting close with the area under the rear seat. Just need to clean up a bit around the edges. It takes so much time!
| Error |
| Error |
| Error |
Threads: 7
| posted on June 16th, 2014 at 07:07 PM |
So another full day of scrubbing..
This is pretty much as good as I got it before paint.
| Error |
| Error |
| Error |
Threads: 7
| posted on June 16th, 2014 at 07:13 PM |
and first coat of POR15
| Error |
| Error |
| Error |
Threads: 7
| posted on June 19th, 2014 at 09:34 AM |
finished stripping the sides and the roof yesterday.
| Error |
| Error |
| Error |
Threads: 7
| posted on June 19th, 2014 at 09:36 AM |
prepped and por15 down by 7pm.
| Error |
| Error |
| Error |
vlad01
Mood: Side ways
| posted on June 19th, 2014 at 03:59 PM |
| Quote: | Originally
posted by meisterberginteriors
yeah here is the pics. starting rusting a year later even though its indoor and 2 coats, 3 where the grommet is.
71 notchback,
Threads: 7
| posted on June 19th, 2014 at 07:40 PM |
Yep that looks like rust. I am using POR15 under the primer so i think i shouldn't have the same problem. Either way i will know eventually and if
rust does rear its ugly head ill post about it. Thanks for putting those photos up.
Threads: 7
| posted on June 19th, 2014 at 08:14 PM |
here is the first coat in the daylight. I was quite hungover today so i just orgainsed the workshop and located all the parts for my turbo 1914 type 3
engine.
| Error |
| Error |
| Error |
Threads: 7
| posted on June 26th, 2014 at 10:37 AM |
I have been building a couple of engines but yesterday I finally had some time to paint the front end of the car. so all that's left are the rear
intakes, front half of the cabin and inside the bonnet area.
Threads: 7
| posted on June 29th, 2014 at 07:04 PM |
here is the bonnet area i have nearly finished cleaning up. i think another day woking on the wheel well and then it will be ready for POR15.
| Error |
| Error |
| Error |
vlad01
Mood: Side ways
| posted on June 30th, 2014 at 11:49 AM |
| Quote: | Originally
mine was completely ground and sandblasted to bare metal, prep as instructions to every detail. I used the POR15 rust preventative paint here.
sat inside the shed never to see the weather.
been using wattyl epoxy etch for years without any rusting or adhesion problem. I haven't found anything better adhesion wise.
71 notchback,
Threads: 7
| posted on June 30th, 2014 at 04:24 PM |
| Quote: | Originally
posted by vlad01
| Quote: | Originally
Honestly I do trust you and I will take your advice on the next car and try out Wattyl's epoxy etch but on this car since i had already painted so
much of it i wont be stripping it again. I will just have to cross my fingers and hope you got a bad batch.
If rust does show up ill start a thread just on por15..
vlad01
Mood: Side ways
| posted on June 30th, 2014 at 07:20 PM |
yeah I m not saying to strip it or anything. Its too late now anyway. Hopefully it wont happen to yours. I'm glad I didn't use it on any projects
that mattered.
The wattle primer is a recommendation if you only using single pak, lots of car restro shops use it. otherwise a 2 pak epoxy is even better but much
more toxic to use.
71 notchback,
Mr Bubble Head
Theme: UltimaBB Powder
| posted on June 30th, 2014 at 08:00 PM |
Wow lots of work done Justin and still plenty to go funny it's Dave's old car
recycle, restore, enjoy
Threads: 7
| posted on June 30th, 2014 at 09:14 PM |
i have a feeling it was resprayed and molested after he owned it.. im pretty sure he wouldnt use the side of a fridge to hide rust! seriously that was
the worst surprise i found.
vlad01
Mood: Side ways
| posted on July 1st, 2014 at 10:31 AM |
haha wow! bits from a fridge lol
71 notchback,
Threads: 7
| posted on July 1st, 2014 at 06:24 PM |
yeah it was a brilliantly pulled off. i had no idea until i pulled the front right fender and about 40-50cm of cut up white goods was left wedged
inside the bonnet disguising a very large hole..
Threads: 7
| posted on July 3rd, 2014 at 06:09 PM |
Por15 in the bonnet area. Ive run out of POR15 now so for anyone thats curious to how much you need to do a shell 1L will almost do one coat of paint
on a square.
| Error |
| Pages: 1 2 3 4 5 |
