| [ Total Views: 147725 | Total Replies: 151 | Thread Id: 29235 ] |
| Pages: 1 2 3 4 5 6 |
dangerous
Mood: 591
| posted on April 14th, 2009 at 08:12 PM |
| Quote: | Originally
posted by Boostn
ok so what you are saying is Rod bought those parts cheap in the form of an engine instead of boxes.
Yes it was cheap Nick.
Much less than it would cost to buy the separate parts.
David,
when you factor in the lighter car,
no belt and muffler,
and the extra comp that rod has,(I assume yours is less than 14:1!),
you are right there.
I will find the build details and post up some assembly pics.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on April 14th, 2009 at 08:59 PM |
The crank is an 8 dowel 86mm scat with type 4 centre main and 2" rod journals.
Cam is Clay Smith with 280@.050" and has .615" lift at the valve.
(Rockers are the standard cast Autocraft with 1.4 ratio.)
I made an extended pick-up from steel tube,
and silver soldered it on so no leaks.
Sump is 5 quart CB sump.
Case is just an ordinary magnesium AS41 deal with 10mm head studs.
Dizzy is MSD with advance locked at 28 degrees.
Oil pump is an EMPI 30mm cast unit.
I had to machine the back off to align the inlet hole,
and while I was there,
I radiused where the port entrance meets the gears.
I also plugged both the pump and the case at the outlet port.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on April 14th, 2009 at 09:29 PM |
The rod are 5.7 Carrillos.
Replaced the cast FW with a genuine VW steel one and resurfaced the clutch surfaces.
I located the clutch with roll pins before balancing the crank, FW and clutch.
The step height was set to get the correct pressure and geometry.
Note the large hex nut...it needs all the help it can get in the dowel area.
The pistons are Wiseco in AC cylinders with .005" clearance.
(While talking clearances, all crank journals have between 3 and 3.5 thou.)
Gaskets are .040" thick.
Comp ratio was between 17.46 and 18.19...so this has been reduced to 14:1.
Chambers:
Ports:
Valves had been rubbing on notch diameter:
And valve clearance was too close, so this was changed, when comp was reduced.
Valves ,retainers, and collets are Ttanium.
Springs set to travel of .700".
The seal holes in the heads,
for the push rod tubes, needed opening up , and the washers on the tubeswere too large,
thus preventing the seal from seating,
so they were turned down.
No leaks!!
Finished:
(ported some new gaskets ready to fit the 51.5mm IDA's.
Pete says they have 46 vents, 195 mains(F7) , 220 airs and 65 idles.(correct me if I am wrong).
Data says perhaps a larger idle jet, smaller main and smaller airs should be better,
but up around 7800 all is sweet.
| Quote: | Originally
posted by westi
That's mad Alan.
Boostn
Threads: 28
| posted on April 14th, 2009 at 09:51 PM |
Nice work Dave.
Rod now needs to update his plates....hahaha
still one of my favs.
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on April 14th, 2009 at 10:41 PM |
Good one Dave , your pic's are ART for us volksy nuts ! All parts where new on motor except cam (was a secet grind for drag racing ) . Was much
easier buying from well none vw drag racer as a new turn key motor but we had a couple oiling issues so a complete look inside was needed . This when
Dave work his magic again found comp very wrong ( 17.4 not 14.1 as paper work )
We notice the motor pinged on first burnout we did at earlier test & tune we went to . We had low oil pressure once motor good hot so Rod turned
it off ,to come back another day .
Barrels - JayCee long , Melling cast iron oil pump with empi cover . Comp Eliminators ,these heads work well out of box but with hand porting , large
titanium valves ,good cam , 51.5 carbs all add up to sweet allmotor combo .
Carb jetting is correct Dave , carbs came with that setting but a much smaller main jet so I richened it up .
So not perfect yet but a good start . Next - Rod ! I want a drive !
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on April 14th, 2009 at 11:23 PM |
Congrats to all........what a great result.
HS618
Threads: 28
| posted on April 14th, 2009 at 11:33 PM |
Wow - Congratulations to all contributors for the excellent performance - the effort shows!!.
Rod, I don't see anything wrong with the reaction times (it's nearly finished and ready to burn____!)
davidoconnor
Threads: 7
| posted on April 15th, 2009 at 09:06 AM |
Dave,
Thanks for sharing all the details and pics, inspirational stuff! Compression really seems to wake these motors up. I remember reading about the
likes of Mike (?)Smith's drag Bug and Roger Crawford's Bad Company Beetle in the States. With sub 2l engines they were running deep into the 11's.
Over 14:1 compression in both cases and over 8000RPM, yikes!!
Top effort to the Dak-A-Tak team.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on April 15th, 2009 at 12:00 PM |
Love the pics of the build up.
You must be proud of what it is (Rod, Pete, Dave) and the results for its first time out.
westi
what the
Threads: 28
Mood: not blue, pink
| posted on April 24th, 2009 at 12:26 AM |
lookin good,but were's the vid's.not happy jan.
tell rod .may be the best of your life.lol,
the mad texan (Rod) must be happy and you pete must be alittle green with envy.you know you want to have a go.
tell rod that you need to do some more testing in your car before putting it in the black drag car,you know ,just to make sure everything is tip
top.
can't wait to see her in action.
when is that show that you wanted to go to.
down sharon.
reub
VWRX is gone...
| posted on July 7th, 2009 at 06:55 PM |
Gotta ask, was there any video footage of the run??
Reub
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
| posted on July 7th, 2009 at 09:27 PM |
Sorry mate ! no footage on that night , hard to crew and film but we are heading out to willowbank (25th July) part of Dyno Mania 2009. Are you still
coming down for Warwick ,mate ?
reub
VWRX is gone...
| posted on July 8th, 2009 at 08:54 AM |
No stress Pete. Cheers for the reply.
I've a leave of absence approved by Rach - so plan to be there - unfortunately without either of my cars. Look forward to seeing the action and
meeting a bunch of guys I read about all the time
Reub
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
| posted on July 27th, 2009 at 10:39 PM |
Well , I think Rod was a little happy after Dyno Day with new engine making nice power and taking home dyno operators chose award too .
With big chokes engine has a quiet a big lazy window around 4 to 5000 rpm but after that it's an animal . So I'm sure with more tuning this motor
should make the 200hp mark !
vassy66T1
A.k.a.: Marcus Vass
| posted on July 28th, 2009 at 07:06 PM |
Sounded sweet at the track on Sat nite!!
What diff set up does the gearbox have? Open?
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on July 28th, 2009 at 07:31 PM |
aluminium spool back on page 2.......hoping to watch it run hard again for a while again at Warwick 09.......
davidoconnor
Threads: 7
| posted on July 28th, 2009 at 09:32 PM |
Wow thats some RPM on the dyno! If this was done in 3rd gear, thats around 8K!!?
dangerous
Mood: 591
| posted on September 19th, 2009 at 12:49 PM |
Wait to see what happens when it gets a tune up!
| Quote: | Originally
posted by westi
That's mad Alan.
vassy66T1
A.k.a.: Marcus Vass
| posted on September 19th, 2009 at 06:38 PM |
Good figures in the air ... Rod or Pete should spill the beans.
dangerous
Mood: 591
| posted on September 19th, 2009 at 08:58 PM |
218.9
With Muffler...can that be true!?
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 19th, 2009 at 09:04 PM |
Or was that, "I ate a 218.9 gram Muffin".
| Quote: | Originally
posted by westi
That's mad Alan.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
| posted on September 19th, 2009 at 11:44 PM |
Yep!!!!!!! but was a liittle lean guys on that run (we keep no secrets here boys ). We had 13 dyno pulls , trying muffler , clossing up mid range with
top end A/F ratio's , timing up & down , stinger , rev's , heat range oil to motor temp , learned alot today . Quick brake down ; 2387cc , 14to1
comp, racing fuel 14plus,51's IDA's ,comp eliminators 48 x 40 ,msd 6al .All runs done in 4gear too.
1 / From start with muffler 199 hp ( 195m's , 220 airs ,f7 emulsion, 46 ven's, timing 28 deg's
2/ 206 hp 180 m's
4/ 214.3 hp f11 emulions
5/ 218.9 hp full throttle at 100klms ( to lean at mid range A/F )
6/ 214.6 hp made a change to 210 airs , pull at 180f oil , A/F 13.2 mid to 12.5 high end .
7/ 208.1 hp cold motor , oil 150f
8/ 201.7 hp as above change timing up 30deg's & lean at mid range
9/ 211 hp timing back 26deg's ,motor warm & oil 170f (wow)
10/ 207 hp STINGER ON , LEAN !!!!!!!! 14.1 A/F
11/ 209.7 hp changed mains 190 , A/F 12.5 (good)
12/ 204.6 hp changed timing up 28degs
13/ 212 hp Blocked stinger off (half of openning ) more back pressure
We started at 10.30 finished at 2.30 , temp changed from 26degs to 30.6 deg's through out day . All this information could never have happened at
race track conditions .
Over all very happy (Rod spending time and cash ) with results ,now we are looking forward to Warwick .
reub
VWRX is gone...
| posted on September 20th, 2009 at 02:23 AM |
Bloody awesome to hear guys! Can't wait to see it run...
When are you heading to Warwick? I'll be there Friday arvo and look forward to catching up Pete.
Reub
matberry
| posted on September 20th, 2009 at 02:46 AM |
Well done Pete and Rod. Very good results there. Thanks for sharing.
Stanley
Threads: 270
| posted on September 20th, 2009 at 05:46 PM |
awesome stuff guys....
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on September 20th, 2009 at 09:12 PM |
Money well spent I say. Now to sort out running a stinger with a lil more back pressure!!
dangerous
Mood: 591
| posted on September 21st, 2009 at 05:45 AM |
Explains the reverse taper you see on a lot of the stingers.
| Quote: | Originally
posted by westi
That's mad Alan.
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
| posted on September 23rd, 2009 at 01:21 PM |
come on guys wheres the dyno graph...??
chunks54
Threads: 7
| posted on September 23rd, 2009 at 05:08 PM |
I always wondered about the reverse taper on stingers....
Nice results guys.
What are the details on the titanium valvetrain? Where are they from?
Happiness is a Hot VW.
1954 Bug, 2276/Turbo
Turbo lag - that split second when the other guy thinks he has a chance
dangerous
Mood: 591
| posted on September 23rd, 2009 at 05:53 PM |
Titanium valves, for a Chev small block I think, less than 5" overall lengthand 11/32 stems.
I think they are Manley brand.
I think the retainers and collets are crower 10 degree.
| Quote: | Originally
posted by westi
That's mad Alan.
