| [ Total Views: 11188 | Total Replies: 121 | Thread Id: 45206 ] |
| Pages: 1 2 3 4 5 |
TRENT_DEMOS
Threads: 0
| posted on November 19th, 2005 at 08:24 PM |
DAVE talking about engine damage .....say you have engine trouble during a pass....you pull off the heads ....ooohhh melted pistons.....no
logging....you put new pistons in and assume it was tune up...back to the dyno..
same senario this time with logging... end of the run ....pull out logging......oops lost fuel pressure....that is why it was lean.......start
checking fuel system ......this time fuel pump has shit itself .....found problem
motec logging did not find feul pump was dead ...but narrowed it down to fuel system this time and we found the problem before we spent more time and
money on the dyno.....
TRENT_DEMOS
Threads: 0
| posted on November 19th, 2005 at 08:29 PM |
HEY BUS they do a great job ...it must be perfect or it does not leave the shop....they are a great bunch of guys ..ther is a guy they call SHEETIE
there he has done the fab work there ...he is building a sik kombi streeter v6 nitrous....TOP BLOKE...
Craig Paton
Threads: 68
Mood: Absolutely Gratefull..!
| posted on November 20th, 2005 at 09:13 AM |
Hi Trent
Car looks Great! Are you looking to come and race in Queensland at some stage?
I sure hope so!
That would be a great F4's, Rot & VW with you, Rod, Dave Butler (Pro-Stocker), Mike Nash (Pro-Stocker) Pagey, Wally & a few quick turbo & n/a
Streeters!
What HP do you currently have, and, what are your HP goals?
Cheers Craig
TRENT_DEMOS
Threads: 0
| posted on November 20th, 2005 at 09:59 PM |
Thanx Craig ... love QLD ....on the way up tonight to go camping ..will definately race there one day.....lots of work to do before that though...more
seat time and car development, want to put on a good show for you guys...long trip to get there and have problems..
current hp ...have no idea could only guess.....need a good full pass to estimate....probably somewhere between 400 to 500hp currently.
running no water circulation in intercoolers...and 22-23psi....hope to evetually get car putting down about 38-40 psi and 3 stages of
nitrous...depending on how car reacts...to power increases...but i will go as hard as i can
10x10x
Threads: 6
| posted on November 24th, 2005 at 07:38 PM |
Hi trent any more photos.
You are committed to go fast. Good luck.
Dave, I wish you all the best as well. comments are always constructive.
turbobug56
Threads: 0
| posted on December 20th, 2005 at 04:20 PM |
| Quote: | Originally
posted by TRENT_DEMOS
does anyone know the current record for PRO-MOD ...PRA RULES ....think they are HOT VWS RECORDS not VW TRENDS ?
Trent
There are new Pro Mod rules starting in 2006.
For turbo, injected, intercooled and nitrous your car must weight 14.04 lbs per cu. in. So 78x98=2353cc = 143.6 cu. in. x 14.04 = 2016 lbs.
Without the nitrous the min weight would be 143.6 x 13.01 = 1868 lbs.
The best e.t. for a 2005 Pro Mod was our car at 8.87 @ 157.76. That was at 1760 lbs with a 2276. For 2006 we will need to weight 1800 lbs. We
should be running 8.60's at 160 this next year with a 2276 @ 1800 lbs
Scott
dangerous
Mood: 591
| posted on December 20th, 2005 at 06:46 PM |
Welcome to the forum Scott....love the cars,
especially the streeter with the Revmaster engine!
Yes we know who you are!
| Quote: | Originally
posted by westi
That's mad Alan.
10x10x
Threads: 6
| posted on December 21st, 2005 at 03:07 PM |
Hi scott
Trent will have to add to much weight into the car to get even close to those figures. He ais approx 1700lbs, there is only so much weight you can
add.
Looks like two of our top cars will have no class to run in. Trent is too light and rod penrose does not currently fit into a class with his new car.
turbobug56
Threads: 0
| posted on December 23rd, 2005 at 11:09 AM |
| Quote: | Originally
posted by dangerous
Thanks for the warm welcome. I was not aware of this website. It is always great to chat with VW people.
turbobug56
Threads: 0
| posted on December 23rd, 2005 at 11:11 AM |
| Quote: | Originally
posted by 10x10x
Hi scott
add.
Sometimes the weight is a good thing. 1700 lbs is a safe weight.
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
| posted on December 23rd, 2005 at 02:22 PM |
Hi scott, welcome to the forum. Can you let us know which car is yours (for all us west aussie guys who only know about the VW drag scene by way of
rumour and gossip that is) ?
sounds like a serious weapon....
sean68
Threads: 40
| posted on December 23rd, 2005 at 03:34 PM |
Welcome Scott
plenty of vw drag nuts in here
your car wouldn't be the red baron by any chance
68 Beetle - rebuilding
65 beetle - driving
turbobug56
Threads: 0
| posted on December 23rd, 2005 at 05:07 PM |
| Quote: | Originally
posted by Doug Sweetman
I have a 56 blue choptop street car with a 2965cc Revmaster engine, EFI, Turbo and Air/Water IC. This new engine combo has been running for about 8
months. Best pass to date is 9.79@150.68 with a car/driver weight of 1995lbs. I am freshening up the engine over the winter and hoping to lower that
e.t. significantly.
[ Edited on 23-12-2005 by turbobug56 ]
turbobug56
Threads: 0
| posted on December 23rd, 2005 at 05:11 PM |
| Quote: | Originally
posted by sean68
Welcome Scott
The Red Baron is my friend Eric Calabrese's car. Eric built the car, engine and trans and I setup the engine combo (heads, cam, turbo, efi, IC) and
tune the car for him. Basically, I am the crew chief for his car at the races.
dangerous
Mood: 591
| posted on December 23rd, 2005 at 07:50 PM |
Scott,
Perhaps you could start post with some pics of your engine, (and Erics) while they are appart for freshen.
I ran a 2965cc Pauter in my drag car but it was supercharged using crankshaft, cylinders, cam and clutch that I made from scratch...I am very
interested in your combo.
Regards, DB.
[ Edited on 23-12-2005 by dangerous ]
| Quote: | Originally
posted by westi
That's mad Alan.
turbobug56
Threads: 0
| posted on December 27th, 2005 at 03:55 PM |
Here is a pic of the water/air IC on the package tray along with the throttle body and most of the sensors.
[ Edited on 27-12-2005 by turbobug56 ]
| Error |
turbobug56
Threads: 0
| posted on December 27th, 2005 at 04:00 PM |
Here is a pic of the case with the bottom sump removed, a pic of the header and the engine almost complete. The header is a 4-2-1 designe made of
321SS.
| Error |
| Error |
| Error |
turbobug56
Threads: 0
| posted on December 27th, 2005 at 04:03 PM |
Here are some pics of the heads. 54 intake x 41 exhaust, angle flow design, 1.5 ratio rockers with 4 mounting studs, single Bee Hive springs.
| Error |
| Error |
| Error |
turbobug56
Threads: 0
| posted on December 27th, 2005 at 04:08 PM |
More engine pics
| Error |
| Error |
pete wood
| posted on December 27th, 2005 at 04:42 PM |
Dude your car is awesome. I saw it featured in a mag (can't remember which one) a while back and it is the buso. 9.7 is damn fast for a street car. I
bet there are alot of jealous people wishing they could get even close to that in dedicated strip machines.
Keep up the good work.
HotRodMatt
If it's old or rare - cut it!
Threads: 361
| posted on December 27th, 2005 at 09:35 PM |
Now they are damn serious rockers!
10x10x
Threads: 6
| posted on January 12th, 2006 at 01:02 PM |
some photos of trents car I took today with my phone.
| Error |
| Error |
| Error |
10x10x
Threads: 6
| posted on January 12th, 2006 at 01:09 PM |
and Some more. New front brakes , motec etc
[ Edited on 12-1-2006 by 10x10x ]
| Error |
| Error |
| Error |
10x10x
Threads: 6
| posted on January 12th, 2006 at 01:19 PM |
last one
| Error |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on January 12th, 2006 at 04:48 PM |
That is certainly some serious kit - great to see the bare bones of it all. :thumb
10x10x
Threads: 6
| posted on February 4th, 2006 at 06:47 AM |
Trents re-build has taken much longer than they expected. The work is nearly finished with the car to be stripped next week so the chasis can be
repainted. It appears a lot have changes have been made. New gearbox, chasis strengthening, new fire wall, garrett turbo, nitrous set up, motec engine
control and full logging, front brakes and more. The chasis will be painted next sat then off to the dyno. C&V will tune the car on a hub dyno with
the help from city performance. There is a lot of information that can now be logged with the motec including chasis control. There are hours of track
time and dyno time before the car will be sorted.
Every time i go to city performance there is another vw there. They now have 4 in different stages of development. Have not met the owners of these
cars so will not comment on their build plans. One street car has all the bits to do extremely well, I hope it all comes together for him.
Some more photos of trents car I took the other day before it was to be fully stripped for painting
[ Edited on 3-2-2006 by 10x10x ]
| Error |
| Error |
| Error |
dangerous
Mood: 591
| posted on April 1st, 2006 at 05:22 PM |
Ouch!
I will let Trent fill in all the details, but I heard he damaged his car last Wed night at WSID test session.
Glad to hear that he is OK....The car is only metal and can be fixed or replaced.
Don't do what I did Trent...get back into it...get back on that horse.
I sat out for two and a half years, but wish I had not been away for so long.
| Quote: | Originally
posted by westi
That's mad Alan.
10x10x
Threads: 6
| posted on April 2nd, 2006 at 06:44 AM |
trent is fine car not so good, rolled at the finish line. Chasis is untouched , needs new body.
HotRodMatt
Threads: 361
| posted on April 2nd, 2006 at 09:02 AM |
That is sad to hear. The car has some seious potential.
Let's hope Trent chooses to run the car with a bit less power for a while, when he rebuilds. Give him a chance to really tune the chassis then turn
on the power to show us another single figure ET drag car in Oz.
All the best Trent.
Craig Paton
Threads: 68
| posted on April 2nd, 2006 at 06:53 PM |
Glad Trent is OK! Was really looking foward to seeing his car in the flesh up here in QLD this year.
| Pages: 1 2 3 4 5 |
