[ Total Views: 156721 | Total Replies: 204 | Thread Id: 75753 ]
 Pages:  1  2  3  4  5  6  7
Author: Subject:  Ian's Oval
MemberAussie
Threads: 43
posted on September 13th, 2011 at 03:16 PM
Update Time
It has been a LONG time since my last update....... I have gone through the process of buying a house and moving which has slowed things down for a while, however now a few things on the build have started to progress once again.
Left off things at the old house with a load of ancillaries painted up.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_5877.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_5879.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_5881.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_5890.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_5888.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_5885.jpg
MemberAussie
Threads: 43
posted on September 13th, 2011 at 03:28 PM
Lifting frames came in very handy when moving things into the new place. Replaced the jack with a crane to make things quicker + easier when adjusting the height.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6310.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6307.jpg
With the chassis now complete, I decided to start things off on the body at the back by cleaning up under the boot floor area and inner rear arches etc.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6299.jpg
Cleaned up well though will certainly need a lick of paint to keep things protected under here. You can see the primered dimples which were needed to give clearance to the front of the late gearbox.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6341.jpg
MemberAussie
Threads: 43
posted on September 13th, 2011 at 04:41 PM
Rust?
Moving towards the rear and found some rust holes. Nothing too bad but will still need to be sorted.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6328.jpg
Cleaned back the top side of the valance to see how far things might have gone through and found a previous repair which was not the neatest!!!
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6329.jpg
Time to chop out the crap and see what we have left.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6332.jpg
I dont like holes!
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6333.jpg
MemberAussie
Threads: 43
posted on September 13th, 2011 at 04:49 PM
Outer repair piece
Started to mock up the repair piece needed for the outer skin of the valance. Make in card first and then transfer to metal. The sheet metal supplier told me that it would not be possible to mig weld this gauge of steel without blowing holes though everything?? I told him I would try anyway :lol:
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6348.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6350.jpg
Next I bend the repair piece into shape with the help of a vice.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6352.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6355.jpg
Membervassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on September 13th, 2011 at 04:52 PM
Man, your body is in such great nick.
Very neat work too.
MemberAussie
Threads: 43
posted on September 13th, 2011 at 04:55 PM
Only problem is trying to match the curvature of the rear valance to the straight repair piece that I have so far.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6354.jpg
Some pie cuts soon sorted that out.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6370.jpg
Test the fit and things are starting to look closer :no:
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6384.jpg
MemberAussie
Threads: 43
posted on September 13th, 2011 at 05:02 PM
Next up the inner repair piece. Started things off with a card template as previously.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6362.jpg
Bend in the return lip...
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6363.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6364.jpg
Add the pie cuts for curvature and line up with the other side to test lines prior to welding.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6366.jpg
Completed repair section.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6374.jpg
MemberAussie
Threads: 43
posted on September 13th, 2011 at 05:13 PM
Welding
Inner section is welded in first.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6376.jpg
Outer section tacked in to check fit prior to finish welding.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6403.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6404.jpg
Everything looks good so in she goes...
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6408.jpg
Needs a skim of filler to blend the repair out. Also started to sand out the lower portion of the valance. I am hoping this will be the only visible painted area on the outside of the car. Matching the paint was very hard as there are a few different shades ranging from faded original to more recent blow over on the wings and valance. I had to choose a shade of blue which tries to blend with all the different shades that are there.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6492.jpg
Finished with a panel mock up again to check gaps/lines.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6495.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6496.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6497.jpg
Member5lam
A.k.a.: Dave
AKA: BlackBug
Threads: 38
Mood: Slammed
posted on September 13th, 2011 at 07:36 PM
Nice work!! You make it look all too easy!
MemberAussie
Threads: 43
posted on September 14th, 2011 at 11:29 AM
Thanks Mate! No specialist skills here - just time and patience to get things looking right. :fakesniff:
MemberAussie
Threads: 43
posted on September 15th, 2011 at 07:07 PM
Primer
Finally time for some primer to go on. Used the same PPG primer as went onto the floorpan. Great things to say about this stuff - no issues at all on anything that I have painted with it so far. The only thing I have noted is a tiny bit of cracking if you apply too thick - more of a painter error though than an issue with the paint itself.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6555.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6556.jpg
Got it in and around the boot floor. This underneath section is a pain in the arse to spray - upside down with lots of curves, faces and nooks to get the paint into. Wanted a good even coat for max protection under here. The sanding and prep on this nearly drove me mad!!!:mad:
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6551.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6552.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6546.jpg
Arches came up real nice.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6539.jpg
MemberAussie
Threads: 43
posted on September 15th, 2011 at 07:22 PM
The rear valance repair came up great. Did a couple coats of primer with a bit of sanding and treatment in between to get things to finished standard.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6529.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6542.jpg
This is the inside of the repair which used the second smaller replacement panel. Bit of smoothing etc prior to paint. Really wanted to have good lines on the return lip and also retain the original pressing line which runs parallel.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6537.jpg
This is the untouched other side for comparison. Getting close for some colour now. :cool:
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6549.jpg
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on September 15th, 2011 at 07:35 PM
Nice work Ian, you're doing great. Takes a lot of time to take photos as you go, upload and describe everything hey :)
The DP40 is good - just be aware of the recoat window - normally it should be followed by either high build primer or top coat colour (base coat or direct gloss) within 4 hours maximum. After this you have to sand it so the colour has a mechanical adhesion since the chemical bond (withing the recoat period) has been lost. DP40 sucks to sand sorry to say :sniffle:
Since the top coat is a little less resilient than the epoxy primer, if I have to leave the DP40 for an extended period, I sand it with around 240 grit on the DA then recoat with DP40 and follow that with colour. You can just sand and paint the colour over the hardened primer but there is a slight more chance of delamination.
If you want to borrow my Devilbiss gun which has a collapsible bladder let me know - this enables you to paint upside down as the the gun sucks the bladder down as it goes and forces the paint into the gun rather than relying on gravity feed (until it gets really low on paint).
AL
Memberdangerous
Mood: 591
posted on September 15th, 2011 at 07:46 PM
Super-nice work there Ian!
Originally posted by westi
That's mad Alan.
MemberAussie
Threads: 43
posted on September 15th, 2011 at 08:16 PM
AL
Thanks Al. Man I could have done with that Devilbiss. Had to keep my gravity feed filled to the brim to enable the upside down stuff. How does the bladder work - I dont think I have seen one of these?
Your post beat me to my next update..... I hit the recoat window and got colour on about 20 mins after I finished the primer. Where I had to do some coats of primer with finishing work in between I used 240grit where needed and then used a 3M scuff pad before final primer coat (prior to colour).
You are right about the time it takes to do these updates - uploading photo's is such a pain. I remember reading threads like this one back in the day and getting some useful tips and motovation to do my own build. Hopefully someone out there gets the same from what I am now posting ?????? :dork:
MemberAussie
Threads: 43
posted on September 15th, 2011 at 08:21 PM
Thanks Dave - its been great to get back into it :lol: Still dreaming of a motor.....
MemberAussie
Threads: 43
posted on September 15th, 2011 at 08:37 PM
Colour...
We have colour...... Very pleased with how this came out. It is a heap of graft to get to the paint stage but this is really when all that prep work comes through.
I am liking how this car is coming together. Super clean underneath with original looks from the outside. Looking forward getting paint finished and getting this thing assembled.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6571.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6570.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6568.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6569.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6567.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6558.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6562.jpg
MemberAussie
Threads: 43
posted on September 15th, 2011 at 08:49 PM
Finished repair
Finished repair came up nice..
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6575.jpg
Little bit of orange peel on the valance which is annoying. I am guessing that even though it is direct gloss paint I can still colour sand it as you would a normal clearcoat??
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6560.jpg
Colour match on RHS is good - this corner of the decklid had a blow over in the past.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6596.jpg
Not so good colour match on LHS as this is original paint on the decklid.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6593.jpg
You can see all the different shades of blue here - this is why it was hard to get a paint match that would blend with everything!!! The rear bumper will help hide the bits that don't match so well :lol:
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6592.jpg
Memberdangerous
Mood: 591
posted on September 16th, 2011 at 05:11 AM
You will need something that has high compression and short con rods to fit in that oval engine bay!
That's mad Alan.
Memberreub
VWRX is gone...
posted on September 16th, 2011 at 08:38 AM
I knew of one too... :cool:
Reub
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on September 16th, 2011 at 10:22 AM
Sorry to jump the gun mate - thought you left the primer over night or something but good to hear you got in on in time.
Direct gloss is okay to colour sand as per clearcoat, just a little messier :)
Devilbiss gun (and other brands do them too) looks like a standard gun but instead of a rigid pot, it has a casing that houses a thin plastic bladder - so instead of filling it from the top like a normal gun, you remove the housing fill the bladder then connect it to the gun....as the paint runs out the bladder sucks down to the gun so there is never an air pocket regardless of gun position (within reason). Can't find a pic but it makes sense when you see it - a little late now sorry :)
AL
MemberAussie
Threads: 43
posted on October 9th, 2011 at 08:57 AM
Shell front end
Been busy on the car again and made some more progress. Motivated by seeing some of the cars at Warwick even though I only went on the Saturday which ended a bit early with the rain...
Started the prep work on the front end of the shell in a similiar way to how the rear end was done. Cleaned off the remainder of the flaking underseal from the front arches and under the valance/front bulkhead area. No nasty surprises again though I did have to go back to bare metal again in some areas to get things properly clean.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6610.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6613.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6632.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6635.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6627.jpg
Masked everything for the first coat of primer to show any imperfections/areas which need work.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6625.jpg
MemberAussie
Threads: 43
posted on October 9th, 2011 at 09:06 AM
Ended up also having to paint the bonnet seal trim as the old seal had disintergrated after years of fish-oiling and took off the paint when I tried to remove it. New seals will cover most of the new paint so hopefully wont stand out too much.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6640.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6642.jpg
After various bits of prep work, primer goes over everything prior to the colour going on.
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6647.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6649.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6650.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6651.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6652.jpg
MemberAussie
Threads: 43
posted on October 9th, 2011 at 09:11 AM
Colour
My favourite part - colour goes on.. :cool:
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6654.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6667.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6661.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6665.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6660.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6673.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6674.jpg
MemberAussie
Threads: 43
posted on October 9th, 2011 at 09:20 AM
Get rid of all the masking and the shell is now complete. Still need to do a cavity wax treatment and not completely sure what to do with the wiring yet - apart from these things its ready for assembly. Only the inside of the 4 wings left to paint and then I can finally retire my sanding arm for a while..... :fakesniff:
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6682.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6684.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6688.jpg
http://i103.photobucket.com/albums/m153/aussie1977/Aussieveedubbers/IMG_6686.jpg
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on October 9th, 2011 at 11:51 AM
Wow!
MemberOldTimer
Threads: 30
Mood: In constant awe
posted on October 10th, 2011 at 09:29 AM
This is a great build. Excellent work, excellent quality.
Thanks for sharing.
Old Timer
air is cool, but air-cooled is cooler!
1967 Aussie Built Type 1 1915 Deluxe
MemberAussie
Threads: 43
posted on October 10th, 2011 at 07:37 PM
Wow!
Cheers! How is that 5 speed going? I was going to go for one of these originally but went for the 4 speed in the end. Do you have a stock ratio 5th?
MemberAussie
Threads: 43
posted on October 10th, 2011 at 07:39 PM
Thanks for sharing.
Old Timer
Thanks Old Timer. It is moving along nicely now and I am trying to keep the momentum going for a while. More updates to follow shortly.
Cheers, Ian
Memberhellbugged
A.k.a.: Daimo Pell
posted on October 10th, 2011 at 07:56 PM
Hi Ian
luvin the plan here.....clean underneath and original above. few hot rods been to Valla rod run over the years done like that and i love it, dream of the time and patience to do a car the same. great direction choice!
surprised you didn't make the rear apron detachable whilst working around there. was never a fan of this set up, but now i've done it, for sure can see major benefits to it.
yeah 5 speed hasn't turned much in the last 18 months........ 0.82 top gear which the torquey lil 1776cc pulls well. (from memory:rolleyes:).......big believer in learning an engines delivery on the road before choosing ratios as this final drive ratio would not suit loads'a other motors. but yeah i would recommend the conversion as it is UNBELIEVABLE to have both the close race ratios AND the ability to run freeway touring.
will be good when Craigy Torrens' 5 finally arrives for some more input and testing of times at the track from him as he has chosen a more even spread of ratios throughout all gears
keep up with the progress :tu:
[ Queries: 40 ] [ PHP: 11.5% - SQL: 88.5% ]
