| [ Total Views: 112844 | Total Replies: 107 | Thread Id: 91646 ] |
| Pages: 1 2 3 4 |
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
| posted on January 1st, 2012 at 10:27 AM |
Looking good Rod !!
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
| posted on April 13th, 2012 at 07:50 PM |
Hey Rod. How about an update?
tar76
Threads: 95
| posted on April 13th, 2012 at 10:04 PM |
That motor is insane
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
dangerous
Mood: 591
| posted on April 14th, 2012 at 05:16 AM |
should be just about running I reckon!
| Quote: | Originally
posted by westi
That's mad Alan.
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
| posted on April 24th, 2012 at 06:54 PM |
Due to the amount of people that have told me that the engine looks shit hot apart from the rusty turbo housing , I have now received it back from HPC
in Vic . I will bolt the turbo and dump pipe on tomorrow , and if I finish polishing the nitrous fuel tank and the catch can I will try to start this
tomorrow . I will post some pic's then . I have also received the initial tune from Paradise Motorsports in the US and have installed it into the
Motec ecu ready to go , ROD.
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on April 25th, 2012 at 07:49 AM |
oohhhh how exciting
Flintstones
Threads: 69
| posted on April 25th, 2012 at 07:59 AM |
Vid's please
D
Ollie
A.k.a.: Ollie Clarke
Yeah Buddy
Threads: 122
| posted on May 8th, 2012 at 09:50 PM |
Rod, I would love to race you in my 1500 Single Port.
NO but seriously Im excited for this!
RodPenrose
Threads: 330
| posted on November 24th, 2012 at 08:24 AM |
DYNO'D AND RUN
I have installed this engine into my new car and it has been on the dyno for a couple of days to sort out the tune . After 3 days I ended up with 475
HP @ the wheels on 18 lb's of boost . According to the Dyno operator this equates to 680 HP , but I would say closer to 630 HP . We tuned it on 7
lb's , 10 lb's , 14 lb's and finally 18 lb's of boost and the tune is perfect according to the lambda sensor . This is about half way of where I
will finally end up with in the regards to power .
On it's first outting on the 1/4 mile a couple of weeks ago the engine was perfect and never missed a beat . I have a crank pulley seal that is
leaking and will now be replaced and all of the pressures and temps look good . The car went 9.26 @ 141 mph and I am happy with the engine at this
power level . I will run the car again in a couple of weeks and I will increase the boost by another 5-10 lb's once I am comfortable that the clutch
settings will handle it . I will also try to dyno the car before I go out in a mid December , ROD.
h
| posted on November 24th, 2012 at 08:46 AM |
cool but INSANE
DubLeg
A.k.a.: Lewis Templar
Threads: 46
Theme: UltimaBB Psyche Red
| posted on November 24th, 2012 at 07:55 PM |
That's how you build engines. Any videos yet?
VollyWaffle
tar76
Threads: 95
| posted on November 24th, 2012 at 08:41 PM |
Couldn't squeeze this motor in with the manifolds you send up to me next week Rod???
"Obey your Dreams"!
62 Std beetle.
TorxKiwi
A.k.a.: Dean Newell
Threads: 38
Mood: "It's not easy being green"
| posted on November 24th, 2012 at 09:06 PM |
| Quote: | Originally
posted by DubLeg
There are a couple on YouTube, search Rod Penrose. That thing is a beast!!!
"Ownership of a Beetle is not a destination it is a journey."
RodPenrose
Threads: 330
| posted on February 17th, 2013 at 10:10 PM |
More Dyno Time
I have spent all week on the dyno and have sorted a few issues that have been thrown my way . After breaking the drive shaft , damaging the car and
suspension a little , popping out the pinion bearing seal in the differential , over heating the diff and hosing oil everywhere , I ended up with 550
HP at the wheels and over 1000 ft/lb's of torque . This was the end result with over 25 dyno runs and finally just over 31 lb's of boost . The new
dyno is reading really low according to the operator and he says about 750 HP is where we are at now . I would calculate it to be around 680 , but I
will know more when I hit the track for the Sydney Showdown this weekend . I have done the usual maintanance and found some fine metal flakes in the
oil filter , so I have removed the engine and dismantled it for a precautionary inspection . I will post pics of what the inside of the engine looks
like , ROD.
RodPenrose
Threads: 330
| posted on July 29th, 2013 at 08:59 PM |
Tune up-date
I have now found that I have been running the engine way too lean so I have added some 35% more fuel and it looks like the reliability I am after is
finally here . I ran the engine 2 weeks ago and had some fuel pressure issues that turned out to be an incorrectly installed fuel pump . I have fixed
this and will now give it another run this Saturday at WSID . I am now using somewhere in the region of 13 litres of fuel per minute at full throttle
. I have been looking @ some more data and now with just over 600 hp @ the wheels and 32 lb's of boost the intake temps are still around 76 degrees
before the intercooler and 36 degrees after the cooler . I have not yet started to fill the cooler with water or ice , ROD.
Doug Sweetman
Threads: 58
Mood: sweeeeet
| posted on July 29th, 2013 at 11:03 PM |
Wow killer intercooler....
Allbones
Threads: 58
| posted on July 30th, 2013 at 11:11 AM |
So when will this be available for street use? Ahhhhhhahahahahaha.
RodPenrose
Threads: 330
| posted on May 17th, 2014 at 11:53 AM |
Up-date
Well , it has been a long time between up-dates here so I will let you know where I am up to . I have ran the car a few times and with about 40 odd
runs on the engine it seems to be very reliable . I did have an issue with the rockers with one breaking on me that I cannot find a reason why . I
have installed a new set of the next generation Pauter rockers and went down from the 1.5 ratio to the 1.4 . I have upgraded to some larger diameter
pushrods that are now 1/2" - 9/16 ' - 1/2' one piece swaged units due to the pushrod flex I was getting from the 900 lb's of spring pressure .
The main bearings are perfect and I have now replaced the conrod bearings due to normal wear . I have also changed the piston rings to a new custom
total seal combo that is working well also . The engine is now @ 38 lb's of boost and around the 800 HP mark . The engine in a car that weighs 2013
lb's or 915 kg's , is now going 5.13 @ 135 mph on the 1/8 mile and 8.12 @ 164 on the 1/4 mile . I am still yet to use the intercooler and with more
runs and more tuning I am sure there is at least another 100 + HP left in the combo before I start to increase the boost again . The engine tune
according to all of the data is actually getting richer at the top end of the track and this is starting to restrict the power and speed of the car .
With every run we are learning about more about the engine and last time out Owen accidently added 1 degree extra of timing and the car went 6 mph
faster . I am still probably about 6-7 degrees away from where I should be , but we will be slowly sneaking up on it to prevent any failures . ROD.
| Pages: 1 2 3 4 |
