| [ Total Views: 329458 | Total Replies: 1582 | Thread Id: 58055 ] |
| Pages: 1 .. 40 41 42 43 44 .. 53 |
dangerous
Mood: 591
| posted on May 1st, 2013 at 01:31 PM |
Both Westi
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on May 1st, 2013 at 05:09 PM |
| Quote: | Originally
posted by Sides
Looks cool DB... could almost put a little conveyor in it to act as a warming oven !!!
Doesn't seem to have anywhere for your filters to fit, or do you think just the box will be good enough to keep the stones at bay ???
Also curious on the turbulence side of things... what would be the impact of running ducting directly from the top of the stack up to the side windows
like have seen on some cars ???
I would still like to fit some filters soon Dave,
but being that this version will likely be changed for the new manifolds,
I will leave them out for now.
Yes, side and rear windows is a good option for the intake,
but the pipe should never be near the ram tube.
Perhaps individual ones, but that gets complicated with the close proximity of each bell.
I found a few videos on You Tube of some very old lectures about
air intake boxes,
and without tested dividers built in, some air went in, and some actually was drawn OUT of the intake runner.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on June 21st, 2013 at 09:00 AM |
Tried the dyno with the air box, but had some problems with the dyno surging.
Started trying to jump off the rollers at 7000, so aborted at 240hp.
Looked to be following the previous curves, both power and mixture.
At Leon's "Dino Day" with the engine cold and no air box it went 252hp, so the engine is fine.
http://www.youtube.com/watch?v=XxIBafgJlTU
I had not had a drive for over 3 months, so took it up for a cold night test and tune.
Had some dramas with the clutch setting, (fingers hit the disc)
and once sorted the throttle linkage broke off near the end of the last run!
The whole purpose of the T&T is to get ME and the car ready for race day,
so best these things occur NOW rather than 1000km away!
Maintenance looks good,
and I have double checked and surfaced the clutch and FW,
and sorted out the throttle linkage.
Even the old loose blower barrels have begun to seal up!(leak down AOK).
Jury is still out on the air box,
so may leave it off for Sydney, it certainly runs a whole lot richer with it ON there.
Whether this is because it is restrictive,
or perhaps it is just containing the stand-off as intended, who knows,
but without some form of ducting, it is not worth the reduced access for tuning and maintenance.
Here is a crap run from Wednesday night,(missed 2nd gear bad!) :
http://www.youtube.com/watch?v=wXxzWNOQzCE
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 24th, 2013 at 08:16 AM |
Thought I would update my progress...or lack of progress!
After a thorough think about some oil surge and blow by issues,
I decided to freshen the engine
by adapting my good barrels to this case,
reducing the oil clearances on the crank,
and sleeving the lifter bores.
This enabled me to go back to the ACE 20 oil,
which has helped the oil return to the sump faster (still more to do though if you watch the oil light in the videos)
and also, the ACE20 will flow through the bearings better than the ACE50, now that I have reduced the oil clearance.
Luckily with the journals I chose on this crank shaft, you can purchase bearings that are .001" tighter.
The reason for sleeving the lifter bores was,
at at full lift, the oil slot in the case was becoming uncovered as the lifter went past.
By sleeving with aluminium-bronze, I was able to change oil supply to a hole instead of a slot, which is never uncovered,
and also improve the clearance and wear-ability.
This slot is for the roll pin, that later will stop the roller lifter turning:
The oil hole is the small one at the top.
Formerly it was a slot across the top like the one on the side (for the roll pin).
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 24th, 2013 at 08:22 AM |
The air box arrangement was not practical,
so I removed as much of the top and sides as I could,
and changed the wing to stop the breeze effecting the tune.
After running at the Jamboree(23rd year!),
I seem to be back on a path that is responding to my changes.
Missed the first two qualifiers with a faulty crank trigger,
so plugged the distributor sensor back in, and qualified with a 10.95 @ 124.6mph.
https://www.facebook.com/photo.php?v=217441335088927
Thanks To Bec Roberts for the video!
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 24th, 2013 at 08:26 AM |
In the first round I guessed a dial in at 10.90,
and leaned off the high speed mixtures.(above 7000).
This was a backward step because it slowed to a 10.98 @ 123.02,
but due to the .005 reaction time I was able to take the win.
Thanks to Frosty for the use and install of these videos from his GoPro camera!
http://www.youtube.com/watch?v=ZQ095JGF76I&feature=em-upload_owner
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 24th, 2013 at 08:31 AM |
After a healthy discussion amongst the other VW guys like Macca, Pete, Stanley, Ben, Rod R and Frosty,
I decided to richen up the main pill,(since the sixty foot times were still a little slow at 1.52),
and put the high speed mixture back 'as was'.
This was a huge improvement to the half track marker (6.89 @ 100.4mph),
and I broke out with a 10.81 @ 124.24.
Based on the MPH, and comparing it to the previous day's 124.6, it is probably now a tad rich above 7000.
But it is a good base line for the next time I run.
And no, I do not back off for the win, even when I know it is in the bag.
That is just a waste of good data.
http://www.youtube.com/watch?v=P-1lvQphrkc&feature=em-upload_owner
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 24th, 2013 at 08:37 AM |
OH, and the car weighs 1808lbs.
That is 820kg.
| Quote: | Originally
posted by westi
That's mad Alan.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on September 24th, 2013 at 08:38 AM |
"And no, I do not back off for the win, even when I know it is in the bag.
That is just a waste of good data."
I laughed when watching the video and saw that you were way ahead and foot nailed to the floor!! Knew you would.
dangerous
Mood: 591
| posted on September 24th, 2013 at 08:43 AM |
That guy won the event you know!
Even with .499 lights!
| Quote: | Originally
posted by westi
That's mad Alan.
Sides
A.k.a.: Dave Sidery
| posted on September 24th, 2013 at 10:11 AM |
Love the vid's DB !!!
Great to see consistently in the 10's like that too.
Oh and is your 820kg with or without driver ?
My toys
dangerous
Mood: 591
| posted on September 24th, 2013 at 02:27 PM |
1808lbs or 820kg with driver Dave.
| Quote: | Originally
posted by westi
That's mad Alan.
20bkombi
Threads: 26
| posted on September 24th, 2013 at 02:35 PM |
| Quote: |
I love it!!!!
Good work Dave.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
dangerous
Mood: 591
| posted on September 24th, 2013 at 02:38 PM |
Thanks "Data Man".
Thought DataMan sounds better than LogMan.
| Quote: | Originally
posted by westi
That's mad Alan.
andrewmurphy
Threads: 22
| posted on September 24th, 2013 at 05:32 PM |
Awesome Dave!
FROSTY
Threads: 65
| posted on September 24th, 2013 at 07:48 PM |
| Quote: | Originally
posted by dangerous
Thanks for the props... But Dave I have no idea when it comes to that sort of talk. I was checking out the girls from the "just insurance"
booth and didn't know what you were mumbling about..
20bkombi
Threads: 26
| posted on September 25th, 2013 at 06:13 AM |
| Quote: | Originally
posted by dangerous
Thanks "Data Man".
I can't help it I'm addicted to information.
So be it... Data Man
Thanks for the machining pics, always great to see.
Ph 0402 233 027
dangerous
Mood: 591
| posted on September 25th, 2013 at 07:14 AM |
| Quote: | Originally
posted by 20bkombi
Me too !
(mad scientist picture)
| Quote: | Originally
posted by westi
That's mad Alan.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on September 25th, 2013 at 07:20 AM |
There's no such thing as "too much information".....or something being "too good".
modnrod
Threads: 50
Mood: Old School Volksies!
| posted on September 29th, 2013 at 08:42 AM |
| Quote: | Originally
posted by dangerous
Better to be lucky than good.
Great times and lights Dave.
20bkombi
Threads: 26
| posted on October 15th, 2013 at 12:47 PM |
Any progress on those billet manifolds, or pics???
Surely you'd be itching to see the difference.
Ph 0402 233 027
dangerous
Mood: 591
| posted on October 15th, 2013 at 01:10 PM |
Nothing yet man!
Still mowing through a heap of work jobs,
and as soon as my credentials return from ANDRA,
will be going for another test and tune to sort out the last half of the 1/4 mile.
Yes, manifolds are next cab off the rank!
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on October 15th, 2013 at 01:16 PM |
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on October 15th, 2013 at 01:22 PM |
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
Mood: not blue, pink
| posted on October 15th, 2013 at 03:25 PM |
oh ohhhh.
the scrap bin is guna be full of swaf.
down sharon.
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on October 15th, 2013 at 04:16 PM |
modnrod
Threads: 50
| posted on October 16th, 2013 at 05:24 AM |
Those manifolds already have a pretty big hole.
Perhaps you should try the "Biodynamic" approach Dave?
Cut the ends off 4 bloody great bull horns and glue them to the heads! I rekn the taper would work too!
Of course, whether you fill them full of poop and bury the things at full moon to help even more is up to you man........
dangerous
Mood: 591
| posted on October 16th, 2013 at 07:41 AM |
ha-ha,
Heard of people using aluminium baseball bats for manifold taper, but a cow horn is a new one!
At least it is organic!
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
| posted on October 16th, 2013 at 10:35 PM |
heheheheh.
little birdy told me dave just ran.
10.72 @125.86
well done for the lead sled .i reakon.
down sharon.
andrewmurphy
Threads: 22
| posted on October 17th, 2013 at 04:23 AM |
C'mon Dave......out with the details
